system.tag.copy
Descriptionβ
Copies tags from one folder to another. Multiple Tag and folder paths may be passed to a single call of this function. The new destination can be a separate tag provider.
Copying UDTs Across Tag Providersβ
When copying UDTs to a different provider, the destination provider must have a matching UDT definition. The function copies Tags sequentially, so definitions can be placed earlier in the list, with instances following after:
# The '_types_' part of the path denotes the Data Types folder. You can retrieve the path to your UDT definition with right-click on
# on the Tag in the Tag Browser > Copy Tag Path.
udtDef = '[default]_types_/Motor'
udtInstances = '[default]UDT_Instances_Folder'
# When building the Tag list, place the definitions in list before the instances.
tags = [udtDef, udtInstances]
Tag Groupsβ
Tag Groups will not be copied to the new provider, so the copied Tags may not initially execute. This can be remedied by creating a matching Tag Group in the destination provider, either before or after the Tags have been copied.
Remote Tag Providersβ
This function can move Tags to or from a Remote Tag provider. In this case, the Tag Access Service Security settings on both providers must be set to ReadWriteEdit.
Permission Type: Tag Editing
Syntaxβ
system.tag.copy(tags, destination, [collisionPolicy])
Parametersβ
| List | tags | A List of tag paths to move. |
| String | destination | The destination to copy the tags to. All specified tags will be copied to the same destination. The destination tag provider must be specified. |
| String | collisionPolicy | The action to take when a tag or folder with the same path and name is encountered. Defaults to Abort. [optional]. Possible values include:
Returnsβ
List - A List of QualityCode objects, one for each tag in the list, that is representative of the result of the operation. See Scripting Object Reference.
Scopeβ
Code Examplesβ
# Define the tag/folder path(s).
tags = ['[default]Old_Tags/Subfolder' ]
# We'll move the tag/folder above to the new path.
destination = '[default]New_Tags'
# If there is a collision with the destination, we'll abort the process.
policy = 'a'
# Copy the Tags.
system.tag.copy(tags, destination, policy)
