Version: 8.3
system.tag.deleteTags
Deletes multiple tags or tag folders. When deleting a tag folder, all tags under the folder are also deleted.
Permission Type: Tag Editing
system.tag.deleteTags(tagPaths)
ListtagPathsA List of the paths to the tags or tag folders that are to be removed.
List - A List of QualityCode objects, one for each tag in the list, that is representative of the result of the operation. See Scripting Object Reference.
Example #1 - Deleting Tags
# This example will delete several Tags. Modify the paths argument to change which Tags will be deleted.
# Note that a confirmation isn't automatically included, so be cautious when calling this on a production server.
paths = [
'[default]A_Tag',
'[default]Folder/Some_Other_Tag'
# Delete the Tags.
results = system.tag.deleteTags(paths)
# We could expand this example further by examining the list of quality codes...
for index in range(len(results)):
# ...check if a returned anything except Good.
if results[index].isNotGood():
# ...and do something if we failed, such as retrieve the Tag path from earlier, and pair it with a quality code.
print 'Could not delete tag at path: %s \n Reason: %s' % (paths[index], results[index])
