system.tag.move
Descriptionβ
Moves tags or folders to a new destination. The new destination can be a separate tag provider. If interested in copying the tags to a new destination, instead of moving them, please see the system.tag.copy page.
Moving Across Tag Providersβ
When moving UDTs to a different provider, the destination provider must have a matching UDT definition. This function moves folders/tags sequentially, so definitions can be placed earlier in the list, with instances following after.
Note that moving tags with this function will not move or otherwise update prior Tag History or Alarm Journal entries: the old records will persist in the database at the old path, while future entries will be based on the new paths.
Remote Tag Providersβ
Additionally, this function can move tags to or from a Remote Tag provider. In this case, the Tag Access Service Security settings on both providers must be set to ReadWriteEdit.
Permission Type: Tag Editing
Syntaxβ
system.tag.move(tags, destination, [collisionPolicy])
Parametersβ
| List | tags | A List of tag paths to move. |
| String | destination | The destination to move the tags to. The destination tag provider must be specified: i.e., [default]Folder/myTag. |
| String | collisionPolicy | The action to take when a tag or folder with the same path and name is encountered. Defaults to Overwrite. [optional]. Possible values include:
Returnsβ
List - A List of QualityCode objects, one for each tag in the list, that is representative of the result of the operation. See Scripting Object Reference.
Scopeβ
Code Examplesβ
# This function moves a folder in a Tag provider to a new folder.
# Since both paths are at the same node, the "Old_Folder" will be placed at the root of the provider, and the name changed, effectively renaming the folder.
tags = ['[default]Old_Folder']
destination = '[default]New_Folder/'
# Move the folder.
system.tag.move(tags, destination)
# This function moves an entire folder of Tags to a new destination.
# Define the source and new path.
tags = ['[default]Old_Folder', '[default]Another_Folder' ]
destination = '[default]New_Folder/Imports'
# If there are any conflicts with the new destination, then abort the operation
policy = 'a'
# Move the folder
