system.dataset.fromCSV
Descriptionβ
Converts a dataset stored in a CSV formatted string to a dataset that can be immediately assignable to a dataset property in your project. Usually this is used in conjunction with system.file.readFileAsString when reading in a CSV file that was exported using system.dataset.toCSV.
The CSV string must be formatted in a specific way:
#NAMES
Col 1,Col 2,Col 3
#TYPES
I,str,D
#ROWS,6
44,Test Row 2,1.8713151369491254
86,Test Row 3,97.4913421614675
0,Test Row 8,20.39722542161364
78,Test Row 9,34.57127071614745
20,Test Row 10,76.41114659745085
21,Test Row 13,13.880548366871926
The first line must be #NAMES.
The second line must list the names of the columns of the dataset separated by commas.
The third line must be #TYPES.
The fourth line must list the type of each column of the dataset in order, separated by commas.
| Data Type | Alias |
| byte.class | byt |
| short.class | s |
| int.class | i |
| long.class | l |
| float.class | f |
| double.class | d |
| bool.class | b |
| Byte.class | Byt |
| Short.class | S |
| Integer.class | I |
| Long.class | L |
| Float.class | F |
| Double.class | D |
| Boolean.class | B |
| Object.class | O |
| Color.class | clr |
| Date.class | date |
| Cursor.class | cur |
| Dimension.class | dim |
| Rectangle.class | rect |
| Point.class | pt |
| String.class | str |
| Border.class | border |
The fifth line must be #ROWS followed by a comma and then the number of rows of data (i.e. #ROWS, 6).
The following lines will be your data, each column value separated by a comma, and each row on a separate line. The number of rows must match what was specified on line 5.
Syntaxβ
system.dataset.fromCSV( csv )
Parametersβ
| String | csv | A string holding a CSV dataset in the format outlined above. |
Returnsβ
Dataset - A new dataset.
Scopeβ
Code Examplesβ
# This example assumes the CSV file being read was a dataset exported
# using system.dataset.toCSV with the forExport flag set to True
# Specify file path.
file_path = "C:\\my_dataset.csv"
# Read in the file as a string.
data_string = system.file.readFileAsString(file_path)
# Convert the string to a dataset and store in a variable.
data = system.dataset.fromCSV(data_string)
# Assign the dataset to a table.
event.source.parent.getComponent('Table').data = data
