system.dataset.dataSetToHTML
Descriptionβ
Formats the contents of a dataset as an HTML page, returning the results as a string. Uses the <table> element to create a data table page.
Syntaxβ
system.dataset.dataSetToHTML(showHeaders, dataset, title)
Parametersβ
| Boolean | showHeaders | If true, the HTML table will include a header row. |
| Dataset | dataset | The dataset to export. |
| String | title | The title for the HTML page. |
Returnsβ
String - The HTML page as a string.
Scopeβ
Example Outputβ
Expand the panel below to see an example of the resulting HTML this function returns.
Table Data
<HTML><HEAD><TITLE>Table Data</TITLE></HEAD>
<BODY>
<TABLE border='1'>
<TR>
<TH>Col 1</TH>
<TH>Col 2</TH>
<TH>Col 3</TH>
</TR>
<TR>
<TD align='right'>58</TD>
<TD align='left'>Test Row 3</TD>
<TD align='right'>27.524042612227795</TD>
</TR>
<TR>
<TD align='right'>87</TD>
<TD align='left'>Test Row 10</TD>
<TD align='right'>43.48674729787205</TD>
</TR>
<TR>
<TD align='right'>29</TD>
<TD align='left'>Test Row 15</TD>
<TD align='right'>82.46334440414927</TD>
</TR>
<TR>
<TD align='right'>3</TD>
<TD align='left'>Test Row 120</TD>
<TD align='right'>15.07317567946509</TD>
</TR>
</TABLE>
</BODY></HTML>
Code Examplesβ
Code Snippet
# Get dataset from a Table component
dataset = event.source.parent.getComponent('Table').data
# Format dataset as HTML string
showHeaders = True
title = "Table Data"
html = system.dataset.dataSetToHTML(showHeaders, dataset, title)
# Choose filepath for output
filePath = "C:\\output\\results.html"
# Write the HTML to a file
system.file.writeFile(filePath, html)
Code Snippet
# This snippet would run a SQL query against a database, and turn the results into a string containing HTML. It then writes the string to a file on the local hard drive.
results = system.db.runNamedQuery("Fetch Records",{})
html = system.dataset.dataSetToHTML(1, results, "Production Report")
