system.dataset.appendDataset
Descriptionβ
Takes two different datasets and returns a new dataset with the second dataset appended to the first. Will throw an error if the number and types of columns do not match.
Syntaxβ
system.dataset.appendDataset(dataset1, dataset2)
Parametersβ
| Dataset | dataset1 | The dataset that will come first in the returned dataset. |
| Dataset | dataset2 | The second dataset that will be appended to the end in the returned dataset. |
Returnsβ
Dataset - A new dataset that is a combination of the original two datasets.
Scopeβ
Code Examplesβ
Code Snippet
# This example pulls in the datasets from two different Vision table components,
# combines them, then writes the results to a third table.
# The two source datasets must have the same number and types of columns.
data1 = event.source.parent.getComponent('Table 1').data
data2 = event.source.parent.getComponent('Table 2').data
comboData = system.dataset.appendDataset(data1, data2)
event.source.parent.getComponent('Table 3').data = comboData
Code Snippet
# This code takes datasets from two Vision Power Tables and appends them onto a regular Table.
# Get dataset from first power table
dataset1 = event.source.parent.getComponent('Power Table 1').data
#get dataset from second power table
dataset2 = event.source.parent.getComponent('Power Table 2').data
#use system.dataset.appendDataset() to combine datasets
dataset3 = system.dataset.appendDataset(dataset1, dataset2)
#assign data to third table
event.source.parent.getComponent('Table').data = dataset3
