Version: 8.3
system.file.readFileAsString
Opens the file found at path filename, and reads the entire file. Returns the file as a string. Common things to do with this string would be to load it into the text property of a component, upload it to a database table, or save it to another file using system.file.writeFile function.
note
This function is scoped for Perspective Sessions, but since all scripts in Perspective run on the Gateway, the file must be located on the Gateway's file system.
system.file.readFileAsString(filepath, [encoding])
StringfilepathThe path of the file to read.
StringencodingThe character encoding of the file to be read. Will throw an exception if the string does not represent a supported encoding. Common encodings are "UTF-8", "ISO-8859-1" and "US-ASCII". Default is your system's default. [optional]
String - The contents of the file as a string.
Example #1 - Reading File as String
# This code would prompt the user to choose a text file. If the user chooses a file, it would then set a text area on the screen to display the file.
path = system.file.openFile("txt")
if path != None:
contents = system.file.readFileAsString(path)
event.source.parent.getComponent("Text Area").text = contents
