system.dataset.deleteRows
Descriptionβ
Takes a dataset and returns a new dataset with one or more rows removed.
note
Datasets are immutable, which means they cannot be directly modified once created. Instead, this scripting function returns a new dataset with some modification applied, which must be assigned to a variable to be used. See Altering a Dataset.
Syntaxβ
system.dataset.deleteRows(dataset, rowIndices)
Parametersβ
| Dataset | dataset | The starting dataset. Please be aware that this dataset will not actually be modified (datasets are immutable), but rather will be the starting point for creating a new dataset. |
| List[Integer] | rowIndices | The indices (starting at 0) of the rows to delete. Will throw an IndexError if any element is less than zero or greater than the number of rows in the dataset - 1. |
Returnsβ
Dataset - A new dataset with the specified rows removed.
Scopeβ
Code Examplesβ
Code Snippet
# This example would remove several rows from a Vision Table component, by re-assigning the Table's data property to the new dataset returned by the deleteRows function.
ds = event.source.parent.getComponent('Table').data
rows = [0,2,3,4]
ds = system.dataset.deleteRows(ds, rows)
event.source.parent.getComponent('Table').data = ds
