system.roster.createRoster
Descriptionβ
Creates a roster with the given name and description, if it does not already exist.
This function was designed to run in the Gateway and in Perspective sessions. If creating rosters from Vision clients, use system.alarm.createRoster instead
Syntaxβ
system.roster.createRoster(name, description)
Parametersβ
| String | name | The name of the roster to create. |
| String | description | The description for the roster. May be None, but the parameter is mandatory. |
Returnsβ
Nothing
Scopeβ
Gateway, Perspective Session
Code Examplesβ
Code Snippet
# Create an empty roster with a description.
system.roster.createRoster("rosterEast", "East plant user roster")
# Create an empty roster roster without a description.
system.roster.createRoster("rosterWest", None)
