Version: 8.1
system.project.requestScan
Requests a manual scan of the projects directory in order to refresh projects and their resources. If a scan is currently running, this method has no effect and will return when the in-progress scan has finished. This function blocks the current thread until a scan has completed.
system.project.requestScan([timeout])
IntegertimeoutThe amount of time, in seconds, to block the current thread before timing out. Default is 10 seconds. [optional]
None
Gateway, Perspective Session
Code Example​
Code Snippet
# This example requests a manual scan of the project directory
# while blocking the current thread for 30 seconds before timing out.
system.project.requestScan(30)
