system.print.createImage
Descriptionβ
Takes a snapshot of a component and creates a Java BufferedImage out of it. You can use javax.imageio.ImageIO to turn this into bytes that can be saved to a file or a BLOB field in a database.
Syntaxβ
system.print.createImage(component)
Parametersβ
| Component | component | The component to render. |
Returnsβ
BufferedImage - A java.awt.image.BufferedImage representing the component.
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
from java.io import File
from javax.imageio import ImageIO
component = event.source.parent.getComponent('TestPieChart')
bufferedImage = system.print.createImage(component)
rawPath = system.util.getProperty("user.home") + system.util.getProperty("file.separator") +"chart_createImage.jpg"
formattedPath = File(rawPath)
ImageIO.write(bufferedImage , "jpg", formattedPath)
