system.opcua.callMethod
Descriptionβ
Calls a method in an OPC UA server. To make the most of this function, you'll need to be familiar with methods in the OPC UA server.
Syntaxβ
system.opcua.callMethod(connectionName, objectId, methodId, inputs)
Parametersβ
| String | connectionName | The name of the OPC UA connection to the server that the method resides in. |
| String | objectId | The NodeId of the Object Node the Method is a member of. |
| String | methodId | The NodeId of the Method Node to call. |
| List | inputs | A list of input values expected by the method. |
Returnsβ
Tuple - A tuple containing the following:
- 0 Resulting StatusCode for the call
- 1 A list of StatusCode objects corresponding to each input argument
- 2 A list of output values.
Scopeβ
Gateway, Perspective Session
The StatusCode Objectβ
This function returns multiple StatusCode objects. StatusCode is a tuple, containing the following:
| Index Order | Description |
| 0 | The value of the code |
| 1 | The name of the code |
| 2 | A description of the code |
Code Examplesβ
Example #1
# Call the Server object's GetMonitoredItems method.
result = system.opcua.callMethod(
"Ignition OPC UA Server",
"ns=0;i=2253",
"ns=0;i=11492",
[1]
# Below we print the various elements in the results. The print statements could easily be replaced by something more useful.
# Prints the StatusCode for the call.
print result[0]
# Prints the list of StatusCodes, one for each input argument passed to system.opcua.callMethod.
print result[1]
# Prints the output values from the call.
print result[2]
