system.secsgem.getToolProgram
Descriptionβ
Returns a process program from the Gateway that was previously sent by a a tool in an S7F3 message.
Syntaxβ
system.secsgem.getToolProgram(ppid)
Parametersβ
| String | ppid | The PPID that was sent from the tool when the S7F3 message was saved. |
Returnsβ
Dictionary - A Python Dictionary containing the following keys: [editDate, ppbody, bodyFormat].
editDate- holds the last date the program was saved.ppbody- holds the actual program.bodyFormat- holds the format ('A', 'B', 'I', etc) of the original message PPBODY.
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
# Retrieve information on all programs.
results = system.secsgem.getToolProgramDataset()
for program in results:
# If the format of the program is ASCII...
if program[2] == "A":
ppid = program[0]
# Retrieve more information on the program.
programData = system.secsgem.getToolProgram(ppid)
# Print the program. Writing to a file would most
# likely be a better practice here.
print "Program %s: %s" % (ppid, programData[1])
