system.secsgem.copyEquipment
Descriptionβ
Creates a copy of an equipment connection and places it in the Gateway > Config > SECS/GEM > Equipment. Common settings can be overridden for the new connection.
An exception is thrown if the new equipment connection cannot be created.
Permission Type: SECS/GEM Management
Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when called in the Gateway scope.
Syntaxβ
system.secsgem.copyEquipment( equipmentSource, newEquipmentName, enabled, activeAddress, activePort, passiveAddress, passivePort, deviceId [, dbTablePrefix] [,description])
Parametersβ
| String | equipmentSource | Some new equipment settings will be retrieved from this equipment connection. Specify the source equipment connection name. |
| String | newEquipmentName | The name of the new equipment connection. |
| Boolean | enabled | If set to false, the new equipment connection will be disabled after it is created. |
| String | activeAddress | IP Address of new equipment. Must be specified if the SECS/GEM module is used in Active mode. Otherwise, do not use this parameter. |
| Integer | activePort | Port number of new equipment. Must be specified if the SECS/GEM module is used in Active mode. Otherwise, do not use this parameter. |
| String | passiveAddress | IP Address of new equipment. Must be specified if the SECS/GEM module is used in Passive mode. Otherwise, do not use this parameter. |
| Integer | passivePort | Port number of new equipment. Must be specified if the SECS/GEM module is used in Passive mode. Otherwise, do not use this parameter. |
| Integer | deviceId | Unique identifier of new equipment. This value must be an integer, and is specified within the equipment. |
| String | dbTablePrefix | SECS/GEM database table names will use the specified prefix for the new equipment connection. If no prefix is specified, the description of the source equipment will be used. Optional. |
| String | description | The description for the new equipment connection. If no description is specified, the description of the source equipment will be used. Optional. |
Returnsβ
Nothing
Scopeβ
Vision Client
Address and Port Parametersβ
When calling this function, only one set of address and port parameters need to be specified: Either activeAddress and activePort, or passiveAddress and passivePort. Optionally, both sets of parameters may be specified, but the function will throw an exception if neither are specified.
Code Examplesβ
system.secsgem.copyEquipment(equipmentSource="ToolOne", newEquipmentName="ToolTwo", enabled=True, activeAddress="192.168.1.5", activePort=15500, deviceId=0)
