system.secsgem.sendResponse
Descriptionβ
Sends a JSON-formatted SECS response message to a message sent by a tool. An equipment connection must be configured for the tool in the Gateway, and this must be used within a Message Handler to create a Custom Message Response Handler.
Syntaxβ
system.secsgem.sendResponse(transactionID, systemBytes, streamFunction, body, equipment)
Parametersβ
| Integer | transactionID | The TxID of the response. The TxID from the received request in the payload of the message handler must be specified here. |
| Integer | systemBytes | The SystemBytes of the response. The SystemBytes from the received request in the payload of the message handler must be specified here. |
| String | streamFunction | The stream and function of the SECS message to send. Example: "S1F14" |
| Any | body | This contains the body of a SECS response. The argument can be a Python Object or JSON string representing the body of a SECS message. If this argument is a string then it will be converted to a Python Object using the system.util.jsonDecode function. |
| String | equipment | Name of the equipment connection to use. |
Returnsβ
Nothing
Scopeβ
Gateway, Perspective Session
Code Examplesβ
Code Snippet - Sending a S1F1 Message
# This will create a logger that will print to the console that a custom response is happening for S6F12.
# It will then send the response with system.secsgem.sendResponse().
equipment= payload['Equipment']
txId = payload['TxID']
systemBytes = payload['SystemBytes']
message = payload['Message']
msg = "Equipment=" + equipment
msg += ", TxID=" + str(txId)
msg += ", SystemBytes=" + str(systemBytes)
msg += ", Message=" + message
logger = system.util.getLogger("SECSGEM.Gateway.S6F12Handler")
logger.info("S6F12Handler: Sending back response to S6F11 message:" + msg)
body = '{"format":"B", "value": 0, "doc":"ACKC6, Acknowledge Code", "codeDesc": "Accepted"}'
system.secsgem.sendResponse(txId, systemBytes, "S6F12", body, equipment)
logger.info("S6F12Handler: S612 response sent")
