system.secsgem.getResponse
Descriptionβ
Attempts to retrieve a response message from the Gateway. The transaction id from the sent message is used to retrieve the response.
Syntaxβ
system.secsgem.getResponse(transactionID, equipment, [timeout], [poll])
Parametersβ
| Integer | transactionID | The transactionID of the request and response. The transactionID is used to retrieve the response. Typically used in conjunction with system.secsgem.sendRequest to generate a transactionID. |
| String | equipment | Name of equipment connection. |
| Integer | timeout | Specifies in seconds how long to wait for a response before returning None. If omitted the timeout will be 5 seconds. |
| Integer | poll | Specifies in milliseconds how often to poll the system for a response. If omitted the poll will be 150 milliseconds. |
Returnsβ
Any - A Python object, typically a dictionary. The actual result is a JSON string that's decoded into a Python object, as shown on the mapping on the system.util.jsonDecode page.
Scopeβ
Code Examplesβ
Code Snippet 1
# Replace the string below with the equipment name you want to send the request to.
myEquipment = "EquipmentOne"
# Define the contents of the body. We're using an empty string, since S1F1 doesn't expect a body, and we need to define something (Python's None will result in an exception).
body = ""
# Store the returned transactionID in a variable.
transactionID = system.secsgem.sendRequest("S1F1", True, body, myEquipment)
# Use the transactionID to lookup the response.
response = system.secsgem.getResponse(transactionID, myEquipment, 2)
# We're printing out the response here, but you could do something more useful instead.
print response
Code Snippet 2
# This example demonstrates how to retrieve the value of a Status Variable via S1F3.
# If using the simulator that comes with the SECS/GEM module, this example will return the current time from the Clock Status Variable.
# Define the contents of the body. The Clock Status Variable has an SVID of 1.
body = [{"format":"U4", "value":1}]
transactionID = system.secsgem.sendRequest("S1F3", True, body, myEquipment)
# Retrieve the response.
## We need to do some digging to get the value of the Clock:
## -The response is a Dictionary.
## -Inside of the response is the key "body".
## -The value of "body" is a Python List containing another Dictionary (which has our Clock value)
## Thus we use [0] to access the Dictionary.
## -The Dictionary contains a key named "value", which is the value of our clock.
theDatetime = response["body"][0]["value"]
# We parse the date into something more human readable, and print it out.
print system.date.parse(theDatetime, "yyMMddHHmmss")
