Perspective - Pump
Component Palette Icon:
An animated component that looks like a pump. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. The Pump has two pre-configured variants:
- Centrifugal: Component appearance is that of a centrifugal pump.
- Vacuum: Component appearance is that of a vacuum pump.
Properties
Name | Description | Property Type |
appearance | Options for the appearance of the component. Options are auto, p&id, mimic, and simple. If set to auto, the value is taken from the Perspective Session Property symbols.autoAppearance. ![]() | value: string |
variant | Variant of pump to display. Options are centrifugal or vacuum. Default is centrifugal. | value: string |
animationSpeed | The speed of the animation as a percent. Set to "0" to turn off animation. If set to auto, then the animationSpeed setting is taken from the Perspective Session Property. | value: numeric |
state | State of the animation. Built-in options are default, running, stopped, or faulted. Default is default. New in 8.1.26 Built-in states and new states can be configured and applied on the Project Properties > Symbols page. | value: string |
orientation | Orientation of the pump. Options are top, bottom, left, or right. Default is right. | color |
feet | Feet location for the pump. Options are top, bottom, left, or right. Default is bottom. | |
label | Label settings for the component.
| object |
value | Value settings for the component.
| object |
style | Sets a style for this cylindrical tank. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. The Pump has two pre-configured variants. | object |
Component Events
Example
Property | Value |
props.appearance | simple |
props.variant | vacuum |
props.label.text | Vacuum Pump Simple |
props.style.backgroundColor | #CCCCFF |
props.style.borderStyle | solid |
