Version: 8.3
Perspective - Pump
Component Palette Icon:
An animated component that looks like a pump. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. The Pump has two pre-configured variants:
  • Centrifugal: Component appearance is that of a centrifugal pump.
  • Vacuum: Component appearance is that of a vacuum pump.
Properties​
NameDescriptionProperty Type
appearanceOptions for the appearance of the component. Options are auto, p&id, mimic, and simple. If set to auto, the value is taken from the Perspective Session Property symbols.autoAppearance.
value: string
variantVariant of pump to display. Options are centrifugal or vacuum. Default is centrifugal.value: string
animationSpeedThe speed of the animation as a percent. Set to "0" to turn off animation. If set to auto, then the animationSpeed setting is taken from the Perspective Session Property.value: numeric
stateState of the animation. Built-in options are default, running, stopped, or faulted. Default is default.
Built-in states and new states can be configured and applied on the Project Properties > Symbols page.
value: string
orientationOrientation of the pump. Options are top, bottom, left, or right. Default is right.color
feetFeet location for the pump. Options are top, bottom, left, or right. Default is bottom.
labelLabel settings for the component.
  • text: Text for the label. Value is string.
  • location: Label position relative to the pump: top, bottom, left, right, or hidden. Default is bottom. Value is string.
  • justify: Label text justification: left, center, right, or auto. Default is center. Value is string.
  • style: Modify label text style using the style properties. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class
object
valueValue settings for the component.
  • text: Value to display as text. Value is string.
  • location: Value position relative to the pump: top, bottom, left, right, or hidden. Default is bottom. Value is string.
  • justify: Value text justification: left, center, right, or auto. Default is center. Value is string.
  • style: Sets a style for the value Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class
object
styleSets a style for this cylindrical tank. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. The Pump has two pre-configured variants.object
Component Events​
Example​
PropertyValue
props.appearancesimple
props.variantvacuum
props.label.textVacuum Pump Simple
props.style.backgroundColor#CCCCFF
props.style.borderStylesolid
