system.historian.queryAggregatedPoints
Descriptionβ
Queries aggregated data points for a historian over a specified time range. This function takes a list of strings, where each string is a path to a historical node.
This is useful when you wish to aggregate historian data collected over a period of time into a single value per aggregate. If you want multiple values aggregated to a single time slice, such as hourly aggregates for the same tag over an 8-hour period, consider using system.historian.queryRawPoints.
Make sure the deadband style is set to Discrete Mode if you do not want seed values included in the raw data returned.
Syntaxβ
system.historian.queryAggregatedPoints(paths, startTime, endTime, [aggregates], [columnNames], [returnFormat], [returnSize], [extendedProperties])
Parametersβ
| List | paths | A list of historical paths to query aggregated data points for. See Path Syntax for more information on recommended syntax. |
| Date | startTime | A start time to query aggregated data points for. |
| Date | endTime | An end time to query aggregated data points for. |
| List | aggregates | A list of aggregate functions to apply to the query. [Optional] Available aggregates include:
| List | fillModes | Changed in 8.3.9 This parameter was removed in 8.3.9, but still exists in Ignition to maintain backwards compatibility. A list of fill modes to apply to the query. The fill mode will override the tag's stored interpolation mode at query time. For example, if a tag stores with analog mode (linear), but you want to query as discrete (prev), specify fillModes=['PREV']. This parameter is only functional with the Core Historian and the Internal Historian. [Optional] Available options include:
| List | columnNames | A list of alias column names for the returned dataset. [Optional] |
| String | returnFormat | The desired return format for the query. [Optional] Available options include:
| Integer | returnSize | The maximum number of results to return. [Optional] |
| Boolean | includeBounds | Changed in 8.3.9 This parameter was removed in 8.3.9, but still exists in Ignition to maintain backwards compatibility. Whether to include the bounds in the query results. [Optional] |
| Boolean | excludeObservations | Changed in 8.3.9 This parameter was removed in 8.3.9, but still exists in Ignition to maintain backwards compatibility. Whether to exclude observed aggregated data points in the query results. When applied, observed values, such as periodic samples from Tag Group evaluations will be filtered out, while source values, such as tag changes from devices will remain in the returned dataset. [Optional] |
| Dictionary | extendedProperties | New in 8.3.10 A dictionary of extended query properties for the SQL Historian only. This parameter supports the scan class validation execution (validateSExec) as a boolean, allowing you to to either enable or disable validateSExec. Disabling validateSExec with extendedProperties={'validateSExec': 'false'} can help prevent stale boundary points from being generated, and therefore reduce unexpected aggregates. Default is true. [Optional] |
Returnsβ
Dataset - A dataset representing the aggregated values for the specified historical paths. A demonstration of the table is shown below. There is a row per tag ID, and a column per requested calculation. The tag is returned in the first column.
| tag | calculation1 | calculation2 | calculationN |
| path1 | value | value | value |
| path2 | value | value | value |
| pathN | value | value | value |
Scopeβ
Code Examplesβ
# Query a specified historical simulator tag path and display aggregated data from within the past minute.
end = system.date.now()
start = system.date.addMinutes(end, -1)
myDataset = system.historian.queryAggregatedPoints(["histprov:MySQL:/sys:gw1:/prov:default:/tag:Simulator_/Random/RandomInteger1"], start, end)
for row in myDataset:
print row[0], row[1]
# Query a specified historical simulator tag path and display the sum of the aggregated data
# from within the past minute in Wide format.
path = ["histprov:MySQL:/sys:gw1:/prov:default:/tag:Simulator_/Random/RandomInteger1"]
aggregates = ["Sum"]
returnFormat = 'Wide'
returnSize = 1
historyHistorian = system.historian.queryAggregatedPoints(
path,
start,
end,
aggregates,
returnFormat=returnFormat,
returnSize=returnSize)
for row in historyHistorian:
print row [0], row[1]
