system.historian.storeAnnotations
Descriptionβ
Stores a list of annotations to the specified historian.
When provided as individual parameter lists, ensure all parameters are 1:1, meaning all provided lists must be of the same length. If a particular annotation doesn't need a parameter, that element can be None in the list.
Syntax #1β
system.historian.storeAnnotations(paths, startTimes, [endTimes], [types], [data], [storageIds], [deleted])
Parametersβ
| List | paths | A list of historical paths. See Path Syntax for more information on recommended syntax. |
| List | startTimes | A list of start times associated with the annotation. |
| List | endTimes | A list of end times associated with the annotation. [optional] |
| List | types | A list of string types that indicate the annotation type. [optional] |
| List | data | A list of annotation data. [optional] |
| List | storageIds | A list of annotation storage IDs to indicate that the annotation should be updated. [optional] |
| List | deleted | A list of deleted flags to indicate whether the annotation should be marked deleted. [optional] |
Returnsβ
List - A list of QualityCode objects. The quality code will indicate success or failure.
Scopeβ
Syntax #2β
system.historian.storeAnnotations(annotations)
Parametersβ
| List | annotations | A list of annotations objects created with system.historian.types.annotationPoint. |
Returnsβ
Scopeβ
Code Examplesβ
# Store an annotation on a tag and log an info level formatted message.
paths = ["histprov:HistorianB:/sys:gw1:/prov:default:/tag:remote_200"]
endTimes = [system.date.now()]
startTimes = [system.date.addSeconds(endTimes[0], -5)]
types = ['note']
data = ['this is a test']
result = system.historian.storeAnnotations(paths, startTimes, endTimes, types, data)
system.util.getLogger('HistorianTest: storeAnnotations').info(str(result))
source = "histprov:SQL_Historian:/sys:GW1:/prov:default:/tag:test_tag"
startTime = system.date.now()
data = "Annotation text"
annotations = [system.historian.types.annotationPoint(source=source, startTime=startTime, data=data)]
