system.historian.deleteAnnotations
Descriptionβ
Deletes desired annotations from the specified historian.
Syntaxβ
system.historian.deleteAnnotations(paths, storageIds)
Parametersβ
| List | paths | A list of historical paths associated with the annotations. See Path Syntax for more information on recommended syntax. |
| List | storageIds | A list of annotation storage IDs to be used for deleting. |
Returnsβ
List - A list of QualityCode objects. The quality code will indicate success or failure, and if successful, the storage ID of the annotation will have been deleted.
Scopeβ
Code Examplesβ
Code Snippet
# Delete a previously stored annotation and log an info level formatted message.
paths = ["histprov:MySQL:/sys:gw1:/prov:default:/tag:history_200"]
storageIds = ["1f001108-5689-4b2a-b995d360250a"]
result = system.historian.deleteAnnotations(paths, storageIds)
system.util.getLogger('HistorianTest: deleteAnnotations').info(str(result))
