JDBC Driver and Database Translator Settings
This page details various JDBC driver and translator settings. See the JDBC Drivers and Translators page for information on adding and configuring JDBC drivers and translators.
IBMβ
IBM Default JDBC Driver Settingsβ
Main Propertiesβ
| Property | Value |
| Name | IBM DB2 |
| Description | The official IBM DB2 JDBC Driver. |
| Classname | com.ibm.db2.jcc.DB2Driver |
| JAR File(s) | Click on the Choose File button to select and upload the JAR(s). This is the part where you upload the JDBC driver. |
Driver Defaults & Instructionsβ
| Property | Value |
| Driver Type | DB2 |
| URL Format | jdbc:db2://localhost:50000/SAMPLE OR jdbc:db2://localhost:25000/SAMPLE |
| URL Instructions | The format of the DB2 connect URL is: db2://host:port/database With the three parameters (in bold)
| Default Connection Properties | Blank |
| Connection Property Instructions | Blank |
| Default Validation Query | select 1 from sysibm.sysdummy1 |
SQL Language Compatibilityβ
| Property | Value |
| Default Translator | The Translator this driver should use. Default: IBM DB2 |
IBM Default Translator Settingsβ
Main Propertiesβ
| Property | Value |
| Name | (Name of the Translator. The JDBC driver will reference the settings below by the name specified here) |
| Create Table Syntax | CREATE TABLE {tablename} ({creationdef}{primarykeydef}) |
| Create Sequence Syntax | Blank |
| Create Trigger Syntax | Blank |
| Create Index Syntax | CREATE INDEX {indexname} ON {tablename}({columnname}) |
| Auto Increment Field Definition | {type} GENERATED ALWAYS AS IDENTITY PRIMARY KEY |
| Alter Table Syntax | ALTER TABLE {tablename} {alterdef} |
| Add Column Syntax | ADD COLUMN {columnname} {type} |
| Primary Key Syntax | Blank |
| Limit Syntax | FETCH FIRST {limit} ROWS ONLY |
| Limit Position | Back |
| Current Timestamp Query | The value's current timestamp. |
| Column Quote Character | " |
| Supports Returning Auto-generated Keys? | False |
| Fetch Key Query | SELECT max({columnname}) FROM {tablename} |
| Table List Filter | Blank |
Data Type Mappingβ
| Name | Type |
| Byte (I1) | int |
| Short (I2) | int |
| Integer (I4) | int |
| Long (I8) | bigint |
| Boolean | int |
| Datetime | timestamp |
| Float (R4) | float |
| Double (R8) | double |
| String | varchar(255) |
| Binary | blob |
| Long Text | clob(65536) |
MySQLβ
MySQL Default JDBC Driver Settingsβ
Main Propertiesβ
| Property | Value |
| Name | MySQL |
| Description | The official MySQL JDBC Driver, Connector/J. |
| Classname | com.mysql.cj.jdbc.Driver |
| Property | Value |
| Driver Type | MySQL |
| URL Format | jdbc:mysql://localhost:3306/test |
| URL Instructions | The format of the MySQL connect URL is: jdbc:mysql://host:port/database With the three parameters (in bold)
| Default Connection Properties | zeroDateTimeBehavior=CONVERT_TO_NULL;connectTimeout=120000;socketTimeout=120000;useSSL=false;allowPublicKeyRetrieval=true; |
| Connection Properties Instructions | There is an extensive list of extra connection properties available for MySQL Connector/J. See the documentation for a table describing all connection properties. A default serverTimezone value (taken from the Gateway) will be appended to the connection string if one is not specified. |
| Default Validation Query | SELECT 1 |
| Property | Value |
| Default Translator | MySQL |
MySQL Default Translator Settingsβ
Main Propertiesβ
| Property | Value |
| Name | MySQL |
| Auto Increment Field Definition | {type} NOT NULL AUTO_INCREMENT |
| Primary Key Syntax | PRIMARY KEY ({columnname}) |
| Limit Syntax | LIMIT {limit} |
| Current Timestamp Query | SELECT CURRENT_TIMESTAMP |
| Column Quote Character | ` |
| Supports Returning Auto-generated Keys? | True |
| Fetch Key Query | Blank |
Data Type Mappingβ
| Name | Type |
| Byte (I1) | int |
| Short (I2) | int |
| Boolean | int |
| Datetime | datetime |
| Float (R4) | float(10) |
| Binary | varbinary |
| Long Text | text |
MSSQLβ
MSSQL Default JDBC Driver Settingsβ
Main Propertiesβ
| Property | Value |
| Name | Name of the driver, as you would like it to appear on the Gateway. |
| Description | Enter a useful description you would like to see next to the driver. |
| Classname | com.microsoft.sqlserver.jdbc.SQLServerDriver |
| Property | Value |
| Driver Type | Microsoft SQL Server |
| URL Format | jdbc:sqlserver://localhost\SQLEXPRESS |
| URL Instructions | The format of the SQL Server connect URL is: jdbc:sqlserver:// host \ instanceName [:port] With the three parameters (in bold)
For SQL Server, you specify the database name to connect to using the databaseName property in the Extra Connection Properties. |
| Default Connection Properties | databaseName=test |
| Connection Properties Instructions | Use databaseName=YOUR_DATABASE to specify the database to connect to. |
| Property | Value |
| Default Translator | The Translator this driver should use. |
MSSQL Default Translator Settingsβ
Main Propertiesβ
| Property | Value |
| Name | Name of the Translator. The JDBC driver will reference the settings below by the name specified here. |
| Auto Increment Field Definition | {type} IDENTITY(1,1) |
| Alter Table Syntax | ALTER TABLE {tablename} ADD {alterdef} |
| Add Column Syntax | {columnname} {type} |
| Primary Key Syntax | PRIMARY KEY CLUSTERED ({columnname}) |
| Limit Syntax | TOP {limit} |
| Limit Position | Front |
Data Type Mappingβ
| Name | Type |
| Byte (I1) | int |
| Short (I2) | int |
| \Long (I8) | bigint |
| Boolean | int |
| Double (R8) | double precision |
| Long Text | nvarchar(max) |
Oracle Expressβ
Oracle Express Default JDBC Driver Settingsβ
Main Propertiesβ
| Property | Value |
| Classname | oracle.jdbc.driver.OracleDriver |
| Property | Value |
| Driver Type | Oracle |
| URL Format | jdbc:oracle:thin:@localhost:1521:test |
| URL Instructions | The format of the Oracle connect URL is: jdbc:oracle:thin:@ host : port : SID With the three parameters (in bold)
| Connection Properties Instructions | Blank |
| Default Validation Query | SELECT 1 FROM DUAL |
| Property | Value |
Oracle Express Default Translator Settingsβ
Main Propertiesβ
| Property | Value |
| Name | Name of the Translator. The JDBC driver will reference the settings below by the name specified here |
| Create Sequence Syntax | CREATE SEQUENCE {tablename}seq START WITH 1 INCREMENT BY 1 |
| Create Trigger Syntax | CREATE TRIGGER {tablename}trig BEFORE INSERT ON {tablename} REFERENCING NEW AS NEW FOR EACH ROW BEGIN select {tablename}seq.nextval INTO :NEW.{columnname} FROM dual; END; |
| Auto Increment Field Definition | {type} NOT NULL |
| Alter Table Syntax | ALTER TABLE {tablename} ADD ({alterdef}) |
| Limit Syntax | rownum<={limit} |
| Limit Position | Wrap |
| Current Timestamp Query | SELECT CURRENT_TIMESTAMP FROM DUAL |
| Fetch Key Query | SELECT {tablename}SEQ.CURRVAL FROM DUAL |
Data Type Mappingβ
| Name | Type |
| Byte (I1) | int |
| Short (I2) | int |
| Long (I8) | int |
| Boolean | int |
| String | varchar2(255) |
| Long Text | nclob |
PostgreSQLβ
PostgreSQL Default JDBC Driver Settingsβ
Main Propertiesβ
| Property | Value |
| Classname | org.postgresql.Driver |
| Property | Value |
| Driver Type | PostgreSQL |
| URL Format | jdbc:postgresql://localhost:5432/test |
| URL Instructions | The format of the PostgreSQL connect URL is: jdbc:postgresql://host:port/database With the three parameters (in bold)
| Connection Properties Instructions | No extra connection parameters are recommended for PostgreSQL. For possible parameter values, see the documentation at the PostgreSQL JDBC driver website. |
| Property | Value |
PostgreSQL Default Translator Settingsβ
Main Propertiesβ
| Property | Value |
| Auto Increment Field Definition | SERIAL NOT NULL |
Data Type Mappingβ
| Name | Type |
| Byte (I1) | int |
| Short (I2) | int |
| Boolean | int |
| Binary | bytea |
| Long Text | text |
Snowflakeβ
Snowflake Default JDBC Driver Settingsβ
Many of the fields for the Snowflake JDBC driver can be left blank if your custom Snowflake translator is set up properly and referenced in the "Default Translator" field.
Due to security updates in Java 17, Snowflake JDBC drivers may not interact correctly with Ignition. This can be fixed by adding the following Java argument to the Gateway Configuration File:
wrapper.java.additional.1=--add-opens=java.base/java.nio=ALL-UNNAMED
See the official Snowflake Knowledge Base for more information about this issue.
Main Propertiesβ
| Property | Value |
| Classname | net.snowflake.client.jdbc.SnowflakeDriver |
| Property | Value |
| Driver Type | Generic |
| URL Format | Blank |
| URL Instructions | Blank |
| Property | Value |
| Default Translator | Your custom Snowflake Translator. |
Snowflake Default Translator Settingsβ
If you have a database table called "NO_OP_TABLE", you should use a different table name for the "Create Index Syntax" field.
Main Propertiesβ
| Property | Value |
| Name | Name of the translator, as you would like it to appear on the Gateway. |
| Create Table Syntax | CREATE TABLE IF NOT EXISTS {tablename} ({creationdef}{primarykeydef}) |
| Create Sequence Syntax | CREATE SEQUENCE IF NOT EXISTS {tablename}seq |
| Create Index Syntax | ALTER TABLE IF EXISTS NO_OP_TABLE SET COMMENT='no-op table due to forced value for TRANSLATORS < ALTER TABLE SYNTAX; |
| Auto Increment Field Definition | {type} NOT NULL AUTOINCREMENT |
| Column Quote Character | Blank |
| Fetch Key Query | SELECT NEXT_VALUE FROM INFORMATION_SCHEMA.SEQUENCES WHERE SEQUENCE_NAME='{tablename}' |
Data Type Mappingβ
| Name | Type |
| Byte (I1) | int |
| Short (I2) | int |
| Boolean | int |
| String | string |
| Binary | binary |
| Long Text | text |
In addition to a custom JDBC driver and custom translator, you may need to also configure the Connection Initialization Commands property in your Snowflake database connection to properly store Tag History. Add the following values to the Connection Initialization Commands property:
- USE DATABASE ignition_db
- USE SCHEMA ignition_db.time_series
