Version: 8.1
SMS Notification Profile
Inductive University
Watch the video
SMS Notification Module​
Short Message Service (SMS) is the protocol that is used by text messaging systems. The SMS Notification Module allows you to deliver SMS alarm notifications via a cellular modem configured with a SIM card belonging to an active cellular account. If enabled, recipients of these messages can reply with a special code in order to acknowledge the alarm.
note
The SMS Notification Module is dependent on the Alarm Notification module. You must have both modules installed to send alarms.
Device Configuration​
Inductive Automation officially supports three Airlink devices: the RV50/RV50X, RV55 and LX40. Most devices from most manufacturers that support the Airlink IP protocol can be used, but some configuration settings might be different. You can do the basic configuration for the Airlink modem by importing a template settings file provided by Inductive Automation. To learn more, refer to the Knowledge Base article below.
For more information about various AirLink® devices, see: https://www.sierrawireless.com/router-solutions/airlink/
Card Image
AirLink LS300 Setup Guide
Link to Knowledge Base Article
Card Image
AirLink RV50 Setup Guide
This article describes how to set up Sierra Wireless AirLink RV50 device to work with Ignition SMS Notification module.
Multiple Systems with One Modem​
You can use one SMS modem with multiple Ignition systems for one-way (outgoing) messaging. If you want to use two-way messaging (incoming and outgoing), then only one Ignition system can receive those incoming responses.
Create an SMS Notification Profile​
  1. Go to the Config section of the Gateway Webpage
  2. Scroll down to Alarming > Notification from the menu on the left.
  3. On the Alarm Notification Profiles page, click on Create new Alarm Notification Profile.
  4. Select the SMS Notification profile type and click Next.
  5. Set the following settings concerning your device, and then click on Create New Alarm Notification Profile.
    • Name: SMS
    • Description: Optional
    • Enabled box: Click to Enable SMS notifications.
    • Airlink Host Address: The IP address of the airlink modem.
    • Send Port: The default port is 17341, which is configured in the device.
    • Receive Port: The default port is 17342, which is the port used by Ignition when two-way messaging is enabled. The port must not already be used by the host system, and must not be blocked by a firewall.
    New in 8.1.39
    • Airlink Backup Host Address: Optional. If on a Backup Gateway, this is the host address.
    New in 8.1.39
    • Backup Send Port: Default matches the Send Port default, enter a different port as needed if on a Backup Gateway.
    New in 8.1.39
    • Backup Receive Port: Default matches the Receive Port default, enter a different port as needed if on a Backup Gateway.
    • Two-way Enabled: If enabled, the message recipients will receive a text message notifying them of an alarm, and a link to acknowledge the alarm. This is communicated to Ignition via UDP data sent from the modem. Therefore, the Airlink modem must be configured with the IP address of the system.
    • Numeric Only Ack Code: If this is true, the ack code sent with the SMS message will be a numeric code instead of an alphanumeric code.
    • Audit Profile: If an audit profile is selected, events such as SMS messages and acknowledgements will be stored to the audit system.
  6. Once all the settings are entered, click the Create New Alarm Notification Profile button.
Once you have the SMS Notification profile set up, you can add phone numbers to your contacts using the SMS Contact type. SMS notifications can also be sent with the Twilio Module.
SMS Notification Profile Settings​
The following tables describe the settings on the Alarm Notification Profiles page for a Twilio SMS Notification profile.
Main​
SettingDescription
NameName for this alarm notification profile.
DescriptionDescription of the profile.
EnabledWhether the profile is enabled or disabled.
SMS Settings​
SettingDescription
Airlink Host addressEnter the Airlink host address for this profile.
Send PortThe send port. (Default is 17,341.)
Receive PortThe receive port. (Default is 17,342.)
New in 8.1.39
IP address of the backup modem used by a redundant Gateway if redundancy is configured.
Backup Send Port
New in 8.1.39
Send Port to use if on a Backup Gateway. (Default is 17,341.)
Backup Receive Port
New in 8.1.39
Receive Port to use if on a Backup Gateway. (Default is 17,342.)
Two-Way EnabledWhether or not two-way SMS is enabled.(Default is false.)
Numeric Only Ack CodeWhether to accept only numeric ack codes. (Default is false.)
Auditing​
SettingDescription
Auditing ProfileSelect an audit profile from the dropdown list.
