Version: 8.3
Perspective - Gauge
Component Palette Icon: " "
The Gauge component in Perspective provides a way to show realtime values in a range as they change. The gauge can have one or two axis. It is fully customizable in its appearance, from colors, line widths, needle length, radius, and more.
The Gauge component has three pre-configured variants:
  • Half Circle - Default layout with a half-circle gauge.
  • 3/4 Circle - Layout with a 3/4 circle gauge.
  • Full Axis - Layout with a full axis gauge. For an example of each variant, see the examples section below.
Properties​
NameDescriptionProperty Type
valueNumeric value for the gauge to display. Default is 0.value: numeric
secondaryValueOptional secondary value for the gauge to display on a second axis. Default is 0.value: numeric
startAngleRadial position for the start of the gauge's axis. Default is 180.value: numeric
endAngleRadial position for the end of the gauge's axis. Default is 360.value: numeric
outerAxisSets the values for an outer axis on the gauge. Click to see the outerAxis properties.object
innerAxisSets the values for an inner axis on the gauge. Click to see the innerAxis properties.object
backgroundColorColor applied as a background within the gauge. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.color
animateWhether needle should be animated in a sweeping motion when value changes. Default is false.value: boolean
reverseScaleIf true, the gauge will reverse the direction from minValue to maxValue on its dial.value: boolean
styleSets a style for this gauge. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
outerAxis Properties​
dataWhat value this axis and its needle should display. Can be set to the value or secondary value of the gauge.value: string dropdown
showWhether the outer axis is displayed. Default is true (show).value: boolean
minValueMinimum gauge value for this axis. Default is zero (0).value: numeric
maxValueMaximum gauge value for this axis. Default is 120.value: numeric
widthWidth of the line (in pixels) that represents the outer axis.value: numeric
colorColor of the arc line that represents the outer axis. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.color
percentRadiusRadius of the outer axis, as a percentage of the total chart radius.value: numeric
rangesZones defined on the gauge arc line with a unique color. Array values always start at 0 and increment.
  • start: Value at which this range starts. Value is numeric.
  • end: Value at which this range ends. Value is numeric.
  • width: Width of this axis, in pixels. Value is numeric.
  • color: Color to apply to this range of the dial. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value.
array
needleSettings for the needle on the gauge.
  • origin: Distance from the gauge's center or at which the needle originates, as a percentage of the radius. For example, a value of 0 indicates the needle starts at the center point of the gauge. A value of 50 indicates it starts 50% from the center point. Value is numeric.
  • reach: How far the needle reaches from the center of the gauge towards the outer dial, as a percentage of the radius. For example, a value of 100 indicates the needle will reach all the way to the outer axis. Value is numeric.
  • color: Color of the gauge's needle. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.
object
tickMarksSettings for the display of the tick marks on the outer access.
  • color: Color of the tick marks. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.
  • thickness: Thickness of the tick marks, in pixels. Default is 1. Value is numeric.
  • length: Length of the tick marks, in pixels. Default is 10. Value is numeric.
object
innerAxis Properties​
dataWhat value this axis and its needle should display. Can be set to the value or secondary value of the gauge.value: numeric
showWhether the inner axis is displayed on the gauge. Default is false (don't show).value: boolean
maxValueMaximum gauge value for this axis. Default is 80.value: numeric
widthWidth of the line (in pixels) that represents the inner axis.value: numeric
colorColor of the arc line that represents the inner axis. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.color
percentRadiusRadius of the inner axis, as a percentage of the total chart radius.value: numeric
rangesNumber of zones defined on the gauge arc line with a unique color.
  • color: Color to apply to this range of the dial. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.
array
needleSettings for the display of the needle on the inner access.
  • origin: Distance from the gauge's center at which the needle originates, as a percentage of the radius. For example, a value of 0 indicates the needle starts at the center point of the gauge. For example, a value of 50 indicates it starts 50% from the center point. Value is numeric.
  • reach: Length of the needle in percentage. For example, a value of 100 indicates the needle will reach all the way to the inner axis. Value is numeric.
object
tickMarksSettings for the display of the tick marks on the inner access.
object
Component Events​
Examples​
Example 1 - Fourth Axis​
In this example we added a fourth axis (outerAxis.ranges.3) and configured it.
PropertyValue
Value75
props.outerAxis.maxValue150
props.outerAxis.ranges.3.start120
props.outerAxis.ranges.3.end150
props.outerAxis.ranges.3.width20
props.outerAxis.ranges.3.color#C077D8
Example 2 - 3/4 Circle Variant​
Start with the Gauge 3/4 Circle variant. Set the properties as follows:
PropertyValue
props.startAngle90
props.endAngle360
props.outerAxis.ranges.0.color#FFFF00
props.outerAxis.ranges.1.color#FF8C00
props.outerAxis.ranges.2.color#D90000
Example 3 - Full Axis Variant​
Start with the Gauge Full Axis variant. Set the properties as follows:
PropertyValue
props.startAngle135
props.endAngle405
props.outerAxis.maxValue300
props.outerAxis.ranges.0.end100
props.outerAxis.ranges.1.start100
props.outerAxis.ranges.1.end200
props.outerAxis.ranges.2.start200
props.outerAxis.ranges.2.end300
props.outerAxis.tickMarks.color#000000
props.outerAxis.tickMarks.thickness2
props.style.color#000000
props.style.fontFamilyVerdana
props.style.fontSize12
props.style.fontWeightbold
