Version: 8.1
Report - Rectangle Shape
The Rectangle shape component creates a square or rectangle and can be used anywhere on a report. Select the Rectangle shape on the Report Component Palette to make it active, and click and drag anywhere in your Report Designer to create a rectangle shape. Once the rectangle component is created, you can use the handles to change its height and width. Hold Shift while dragging to create a square instead of a rectangle. You can also change its stroke style, color, and dash pattern.
Report Design Component Palette Icon:
Properties​
PropertyDescription
FillIf true, the shape will fill its space with color.
Fill ColorIf Fill is selected, the color that will fill the shape.
OpacityHow opaque the fill color is, between 0 and 1.
Stroke StyleWhat style of stroke or border to use: Hidden; Shape Outline; Border; Double. To learn more about stroke styles, refer to Stroke and Fill Properties.
StrokeDetails for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.
  • Color - Color to use for the stroke or border.
  • Dash Pattern - A "Dashed Pattern" string to specify the nunber of pixels on and off. For example, "5,10"
  • Width - Width of the stroke in pixels.
RadiusAmount to radius the corners of this shape.
RollNumber of degrees this shape is rotated clockwise.
Scale XAmount to scale the width of this shape. 1 is scale to 100%.
Scale YAmount to scale the height of this shape. 1 is scale to 100%.
URL
New in 8.1.19
A link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.
  • Page:Next - Navigates to the next page.
  • Page:Back - Navigates to the previous page.
  • Page:Number - Replace "Number" with a numeral. Navigates to the specified page.
VisibleIf true, the shape will be visible.
WidthWidth of this shape in pixels.
HeightHeight of this shape in pixels.
XHorizontal distance in pixels between the left edge of this shape and the left edge of the page.
YVertical distance in pixels between the upper edge of this shape and the top edge of the page.
Example​
PropertyValue
Fill ColorFFFF8A
Stroke StyleDouble
Stroke Color0000AC
Stroke Inner Width3 pixels
Stroke Outer Width10 pixels
Stroke PositionInner on path
Stroke Separation5 pixels
