Report - Rectangle Shape
The Rectangle shape component creates a square or rectangle and can be used anywhere on a report. Select the Rectangle shape on the Report Component Palette to make it active, and click and drag anywhere in your Report Designer to create a rectangle shape. Once the rectangle component is created, you can use the handles to change its height and width. Hold Shift while dragging to create a square instead of a rectangle. You can also change its stroke style, color, and dash pattern.
Report Design Component Palette Icon:
Properties​
| Property | Description |
| Fill | If true, the shape will fill its space with color. |
| Fill Color | If Fill is selected, the color that will fill the shape. |
| Opacity | How opaque the fill color is, between 0 and 1. |
| Stroke Style | What style of stroke or border to use: Hidden; Shape Outline; Border; Double. To learn more about stroke styles, refer to Stroke and Fill Properties. |
| Stroke | Details for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.
| Radius | Amount to radius the corners of this shape. |
| Roll | Number of degrees this shape is rotated clockwise. |
| Scale X | Amount to scale the width of this shape. 1 is scale to 100%. |
| Scale Y | Amount to scale the height of this shape. 1 is scale to 100%. |
| URL | A link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.
| Visible | If true, the shape will be visible. |
| Width | Width of this shape in pixels. |
| Height | Height of this shape in pixels. |
| X | Horizontal distance in pixels between the left edge of this shape and the left edge of the page. |
| Y | Vertical distance in pixels between the upper edge of this shape and the top edge of the page. |
Example​
| Property | Value |
| Fill Color | FFFF8A |
| Stroke Style | Double |
| Stroke Color | 0000AC |
| Stroke Inner Width | 3 pixels |
| Stroke Outer Width | 10 pixels |
| Stroke Position | Inner on path |
| Stroke Separation | 5 pixels |
