Accessing Projects Remotely
This page provides an overview of different methods to access your Ignition Vision and Perspective projects from a remote location. Once created, Perspective and Vision projects can be opened without additional configuration by using the Gateway's IP address. If you want more secure options, you can connect to your Gateway’s local network using a VPN, expose specific ports to the internet via port forwarding, or use a reverse proxy for an additional layer of security.
Using URLs - Perspective Only
Open your web browser and navigate to your Ignition Gateway using the Gateway's IP address: http://<local-gateway-ip>:8088.
Project Examples
http://<local-gateway-ip>:8088/data/perspective/client/YourPerspectiveProject
https://<local-gateway-ip>:8043/data/perspective/client/YourPerspectiveProject
For more details on launching Perspective Sessions, refer to Perspective Sessions and Ignition Perspective App - Launch a Perspective Session.
Using VPN
A Virtual Private Network (VPN) allows you to securely connect to your Gateway's local network from a remote location.
Set Up a VPN Server
Install and configure a VPN server on your network. Common options include OpenVPN, WireGuard, or a built-in VPN server on your router.
Ensure the VPN server is properly configured to allow remote connections and has the necessary firewall rules to permit traffic.
Connect to the VPN
Install the VPN client software on your remote device.
Configure the VPN client with the server's address and the necessary authentication details.
Connect to the VPN. Once connected, your remote device will be part of your Gateway's local network.
