Version: 8.1
Variables, Datatypes, and Objects
Without incorporating any Ignition-specific objects, it is important to understand the basics of Python. This section seeks to introduce three main Python principles: Variables, Data Types, and Operators. Additionally, this page and the sub-pages herein will provide plenty of examples to get you started.
This section of the manual attempts to introduce these principles so that they may later be used in conjunction with Ignition. The information in this section is far from comprehensive, as Python's official documentation is a better reference for all things Python. However, this page serves as a great way to jump right into the action.
Variables​
Variables are created by simply assigning a value to them. Variables do not need to be declared, because Python has a dynamic type system. That means, Python figures out the type of the variable on the fly when the script is executed.
The following script would print out: 15
Python - Declaring and Assigning Variables
x=5
y=3
print x*y
A space may be included on either side of the assignment operator ('='), but is not required. Thus, the following example would be functionality identical as the example above.
Python - Declaring and Assigning Variables with Spaces
x = 5
y = 3
print x * y
Built-in Datatypes​
Python features several built-in data types. Below is an overview and links to appropriate pages where applicable.
None​
There is a special value in Python called None (with a capital N). This is simply a special value that means no value. This value is equivalent to Java's null value. None can be used to initialize a variable, but is best when checking to see if something exists before doing extra work:
Python - None
# If some value is not equal to None...
if something != None:
# ...then do some work
doWork()
Booleans​
Python has two built-in values to represent true and false values: True and False, respectively (note the capital letters). These can be used when testing for truth, and are implicitly returned when the comparison operator is used:
Python - Booleans
# Prints True
print 1 == 1
# Prints False
print 1 == 0
When using Booleans, such as predicates in an if-statement, you typically don't have to use True or False directly. Instead, many other values are considered True or False. The following values are also considered False:
  • None
  • Numeric values of 0, such as 0
  • Empty Sequences and Dictionaries, like [] or {}
Values aside from the ones mentioned above are considered true, so you can easily utilize the existence of a non-zero value as a True. Note that for integers both positive and negative numbers are True, only a value of 0 is False.
Strings​
Literal strings can be typed in using either double quotes or single quotes. This can be handy when your string contains one quote or the other. You can also use the backslash character to escape special characters including these quotes. See the Strings page for more information.
Numeric Types​
Numbers can just be typed in normally, like 42 or 3.14159 . Adding a decimal point differentiates an Integer from a Float. More information on Numeric types can be found on the Numeric Types page.
Colors​
Working with colors in Python is remarkably easy. You can simply use any tuple of 3 or 4 integers to represent a color in RGB or RGBA. For example, to set a label's text color to red, you can simple do something like this:
Python - Tuple as Color
label = event.source
label.foreground = (255,0,0) #(red,green,blue)
Additionally, the system.gui.color function allows you to pick a color in a similar fashion:
Python - System Function as Color
newColor = system.gui.color(255,0,0)
Lists and Tuples​
Python offers a variety of sequence types: most notably Lists and Tuples. These are ordered collections, meaning they are indexed and the sorted order is maintained. More information on these types can be found on the Lists and Tuples page.
newList = [1,2]
newTuple = (2,5,7)
Dictionaries​
A Dictionary is a very useful type that holds a set of key-value pairs. Unlike sequences, they are not ordered, so there is no need to sort them. Instead you give each Value in the dictionary a Key, which handles as a reference to Value. You may have used these in other languages and know them as hashmaps, maps, associative memories, or associative arrays. More information on Dictionaries can be found on the Dictionaries page.
newDictionary = {"itemName":5}
JSON​
JSON stands for JavaScript Object Notation. While it is not a data type, it is a way of defining data in a human readable format, and is commonly used in many applications. It comes from the Javascript programming language, but it is language independent. Each JSON object contains lists and objects. A list is a series of ordered values separated by commas that is commonly used within Python. The object works like a dictionary, using any number of name/value pairs, where each value could be any basic data type, a list, or even another object with its own name/value pairs. Because JSON is just a way of defining data, it can be used in many different programming languages, including Python. This makes it a useful tool for defining data in a way that humans can easily read.
Ignition also has two scripting functions that allow you to convert between a JSON string and a native Python object: system.util.jsonEncode and system.util.jsonDecode.
Official Documentation​
For more information on JSON, see http://www.json.org.
Datasets​
A Dataset is a multidimensional collection of values, stored in a manner similar to how values on a spreadsheet appear. Python does not natively have a Dataset type. Instead these datasets were created for use inside of Ignition. There are two types of datasets:
  • Dataset: Sometimes called a "Standard Dataset", this type is commonly used on many Vision Components, such as the Power Table or Chart, to display multiple values simultaneously.
  • PyDataset: Short for "Python Dataset", these datasets act in a manner very similar to a Python Sequence when it comes to accessing specific values, or iteration (see Lists and Tuples). Ignition's built-in system functions that interact with the database typically return a PyDataset.
While there are two types of datasets, you can easily convert one type of dataset to the other. Additionally, you can easily create a dataset from a script.
Python - Creating a Dataset
header = ["The Only Column"]
rows = [[1],[2],[3]]
myDataset = system.dataset.toDataSet(header, rows)
Dates​
Dates and times can be created in Python with the datetime and time libraries. However, the Ignition's built-in system.date functions can also be used instead without having to import either library.
Python - Show the Current Datetime
currentTime = system.date.now()
print "The current time is: %s" % currentTime
Using the In-Keyword​
Python's in keyword can be used to check the contents of something for a specific instance of another object. One use is to check the contents of a string for a certain substring:
Python - Using In Keyword to Look for a Substring
myString = "Hello World"
subString = "World"
# Here we are using an if-statement to look for the substring. If the substring exists inside of myString, the expression returns True.
if subString in myString:
# This will print out, because the substring "World" exists in the string "Hello World"
print "The word 'World' appears in myString"
The in keyword can be used to look for a certain object inside of a sequence:
Python - Check for the Presence of an Object
myList = [1,2,3,4]
# If the integer 3 exists in myList, then this will print True, otherwise it will print False.
print 3 in myList
# Check for the Administrator role.
if "Administrator" in system.security.getRoles():
print "Administrator found"
Additionally, the in keyword can be used in an expression on a while loop:
Python - Check for the Presence of a Keyword in an Expression
myList = [1,2,3,4]
# As long as the integer 4 is in myList, the while loop will continue to iterate.
while 4 in myList:
# pop(0) will remove the first element in the list
myList.pop(0)
else:
print "all done!"
Basic Operators​
Python has many common operators as you would expect, or are at least familiar with if you've worked with other scripting languages.
These are just the basics. There are other operators, like bit shift operators and more. Read about them at: http://docs.python.org/library/stdtypes.html
Operator Reference​
Arithmetic Operators​
In regards to Arithmetic Operators, the precision of the returned value depends on the data types of the arguments: including at least one float will return a float, otherwise, an integer is returned.
OperatorMeaningExampleOutput
+Addition. Note that the data type of the returned object depends on the datatype of the arguments being used:
print 5 + 9
print 5.0 + 9
14
14.0
-Subtraction
print 5 - 9
-4
*Multiplication
print 5 * 9
45
/Division
print 10 / 4.5
2.2222222222222223
//Floored Division: will divide and return just the nearest integer value, even if dividing floats.
print 10 // 4.5
2.0
%Modulo: returns just the remainder of the dividend (the left argument) after being divided by the right argument.
In the example on the right, the 4.5 divides evenly twice, leaving 1.0 as a remainder.
print 10 % 4.5
1.0
**Power: raise the the number on the left to the power of the number on the right.
print 5 ** 3
125
Boolean Operators​
orReturns True if either argument is True. If both are False, then returns False.
x = False
y = True
print x or y
True
andReturns True only if both arguments are True. Otherwise, returns False.
x = False
y = True
print x and y
False
notReturns a boolean value that represents that opposite value of the trailing expression: False becomes True, and True becomes False.
x = True
print not x
False
Comparison Operators​
<Less than
print 10 < 5
print 10 < 10
False
False
<=Less than or equal to
print 10 <= 5
print 10 <= 10
False
True
>Greater than
print 10 > 5
print 10 > 10
True
False
>=Greater than or equal to
print 10 >= 5
print 10 >= 10
True
True
==Equal
print 10 == 10
print 10 == 0
True
False
!=Not equal
print 10 != 10
print 10 != 0
False
True
isReturns True if both arguments are referring to the same object, otherwise, returns False.
x = 10
y = 5
print x is y
False
is notReturns True if both arguments are referring to different objects.
x = 10
y = 5
print x is not y
True
Order of Operations​
Note that there is an order of operations for Arithmetic and Boolean operators that can be modified with parenthesis. For arithmetic they are grouped in tiers and evaluated left-to-right within a given tier:
  • Parenthesis
  • Exponents
  • Multiplication, Division, Modulo
  • Addition, Subtraction
6+10*2   # produces 6+(10*2) = 26
6*10+2 # produces (6*10)+2 = 62
10*6%2 # produces (10*6)%2 = 0
10%6*2 # produces (10%6)*2 = 8
For Boolean operators:
  • Not
  • And
  • Or
