Version: 8.1
Vision - PDF Viewer Scripting Functions
This page details the various component and extension functions available for Vision's PDF Viewer component.
Component Functions​
.loadPDFBytes(bytes, name)​
  • Description
    • This function will pass in the bytes of a PDF and load them into the PDF Viewer component. Please see Storing Files in a Database for more details
  • Parameters
    • string bytes - The bytes of the PDF to be displayed on the component
    • string name - The name of the PDF
  • Return
    • None
.print(showDialog)​
  • Description
    • This function will print the PDF.
  • Parameters
    • boolean showDialog - If true, shows the user a print dialog. Default is true [optional]
  • Return
    • None
.setZoomFactor(zoom)​
  • Description
    • This function will set the current zoom level of the PDF, adjusted to stay within the minimum / maximum zoom range. Will zoom in on center of page.
  • Parameters
    • float zoom - Zoom factor to use. 1.0 is no zoom.
  • Return
    • None
Extension Functions​
