Version: 8.1
Vision - The Window Object Scripting Functions
This page details the various component and extension functions available for Vision's Window Object components.
Component Functions​
.getRootContainer​
  • Description
    • Returns a reference to the Root Container in the window.
  • Parameters
    • None
  • Return
    • Object - a reference to the Root Container, which is functionally just a Vision - Container.
.getComponentForPath​
  • Description
    • Returns a reference to a component. The path parameter allows you to specify the full path to the component as a string.
  • Parameters
    • String path - The path to the component, using a period as a delimiter, such as "Root Container.Group.Label".
  • Return
    • Object - to the component specified, or None if there is a typo in the path.
Extension Functions​
