Version: 8.1
Tag Historian Module
The Tag Historian module for Ignition allows you to turn a SQL database into a high-performance time-series Tag historian. It requires minimal work to implement and is simple to use, even if you aren’t very experienced with SQL databases. The power, ease of use, and incomparable price-to-performance ratio of the Tag Historian module make it the clear choice for storing your organization’s valuable historical information.
Store History with a Click
With the Tag Historian module, you can store history on an Ignition Tag to your database with the click of a mouse - no complex configuration, tuning, or data modeling required.
Create Tables Effortlessly
The module creates and manages tables for you, so you don’t need to be knowledgeable about database management to use it.
Easy Query Binding
Use the data intuitively throughout Ignition with simple, visual query binding screens – no need to write SQL or complex queries.
Powerful Historian Engine
The module’s high-powered historian engine automatically supports compression, partitioning, interpolation, and aggregation for any SQL database.
Make Data More Accessible
By recording your data to a SQL database, the module makes your process data available to any application with database access.
Combine with the Vision Module to simply pull the information you need into individual charts and graphs.
Great Performance and Value
By leveraging the power of SQL databases, the Tag Historian Module delivers tremendous performance at a fraction of the price of traditional historian products.
Powered by Ignition
Since the Tag Historian module is a SCADA module for Ignition, it integrates seamlessly with the Ignition platform and all other modules in the Ignition SCADA suite. Because the module is built on the power of Ignition, it shares the same advantages, such as cross-platform compatibility, unlimited free clients, robust out-of-the-box SQL database support, and fast installation. Its ability to leverage the full power of Ignition places it in a class above any other Tag historian on the SCADA software market.
Learn More
Read more about Tag Historian in the Tag Historian section of the manual.
