8.3.0 Known Issues
· 5 min read
Susan Shamgar
Technical Writing Supervisor
Updated 06/02/2026
The following issues were detected prior to the release of Ignition 8.3.0 as items that would not work as expected at the time of launch. This page will continue to be updated as these issues are addressed in future versions. Note that this is not an exhaustive list of all bugs.
The primary support channel for any questions or feedback is the 8.3 Early Access forum.
Fixed in 8.3.5
Gateway Network Connections
  • Added the Remote Gateways tab to the Gateway Network Connections webpage.
Fixed in 8.3.4
Historian & Store and Forward
  • Renaming a database connection no longer stops the data forwarding. The Store and Forward engine will now update its configuration as well so that data can continue to be forwarded as expected. Similar issues with renaming historian profiles, Audit Profiles, Alarm Journals, and equipment connections have also been corrected.
Fixed in 8.3.3
EAM & Redundancy
  • Disabling the Gateway Network on a redundant master disables the same setting on the backup. The Enabled setting must be re-checked on both Gateways to successfully restore the connection. To allow this, the General Gateway Network settings can now be modified on a backup Gateway. Any other General Gateway Network settings changed on the backup will be overwritten with the master settings once the nodes are synced.
OPC UA
  • The OPC Quick Client is now available again, allowing users to browse and test OPC UA items directly from the Gateway.
SECS/GEM
  • SECS/GEM pages are now available on the Gateway when the SECS/GEM module is installed.
Security & Identity
  • The unsupported Retention setting has been removed from the Gateway UI for Remote Audit Profiles.
Fixed in 8.3.2
  • When upgrading an existing 8.1 Gateway, Audit Profiles will maintain the uppercase format and work as intended. New 8.3 installs may still see errors due to the difference in capitalization when connecting to an 8.1 database where an Audit Profile exists.
Tags & UDTs
  • Tags with custom properties using the name valuePersistence or defaultValue will now log their property values to the migration log and will no longer be overwritten upon upgrade.
  • The Remote Tag Provider will no longer display warning or error messages when deleting shelved alarms or when attempting to unshelve the alarms for deleted tags.
Security & Identity
  • Users no longer need to clear session cookies to log into the Gateway after setting up HTTPS and deleting the web server TLS certificate.
Fixed in 8.3.1
EAM & Redundancy
  • Scheduled tasks will now execute after a failover.
  • When users have a controller set up within a redundant pair, the backup controller Gateway is now able to see EAM Agents before and after they have been approved on the master controller Gateway.
  • Users can no longer create or select invalid controllers within the EAM Setup Wizard when setting up an EAM environment.
Event Streams
  • Event Stream startup and shutdown actions are now handled by separate threads so that they can run independently of each other to ensure the lifecycle of one event stream doesn't affect the lifecycle of another.
  • When upgrading to 8.3, Historian modules and related JDBC drivers are no longer installed if they were not present in 8.1.
Alarming
  • Active alarms will now display correctly in the Alarm Status Table component.
  • Edge alarm events will now sync as expected on remote Alarm Journals on a standard Gateway.
Designer & Scripting
  • The Designer will no longer have errors finding updated projects when the Gateway redundancy role is set to Master.
  • Scripting requests using system.util.sendRequestAsync will now function as expected.
  • The Merge to Logs action on the Gateway Scripts webpage will now correctly apply filters.
Security & Identity
  • Internal Identity Providers with spaces in their names are now accepted.
  • The system.user.editUser function will now work as intended when editing users in a AD Internal Hybrid User Source.
Known Issues
EAM & Redundancy
No log messages appear when an EAM Edge Agent paired with a standard Gateway does not receive resources
If a user sends resources to a target project that doesn't exist on the Edge Gateway, it can't make a project to catch those resources like a standard Gateway can. While this is the intended behavior, there is no logging to indicate that anything happened.
Reporting
Master Pages
This feature was initially targeted for 8.3.0, but was trimmed from scope. This will be added in a future release.
Tags & UDTs
Remote Tag Provider becomes unresponsive after attempting to unshelve non-existent alarm
The Remote Tag Provider can become unresponsive if a user attempts to unshelve an alarm after the tag for that alarm is deleted.
Security & Identity
Remote Audit Profiles incorrectly display Retention option
The Retention setting is shown in the UI for Remote Audit Profiles even though it is not supported or functional.
Web UI
Update response toasts are not properly displaying 422 messages
If users see a JSON object inside of an error dialog, it's likely due to this known issue.
Mobile-Responsive Gateway UX
Changes to the Gateway UX to improve mobile responsiveness are planned for an upcoming release.
401 error on Gateway homepage when not logged in
The homepage may continuously log 401 errors in the console when accessed without authentication.
Maker edition incorrectly allows redundancy setup
The Maker edition Gateway allows users to configure redundancy in the UI even though it is not supported.
