--- title: "Accessing Projects Remotely" --- # Accessing Projects Remotely > This page provides an overview of different methods to access your Ignition Vision and Perspective projects from a remote location. Once created, Perspective and Vision projects can be opened without additional configuration by using the Gateway's IP address. If you want more secure options, you can connect to your Gateway’s local network using a VPN, expose specific ports to the internet via port forwarding, or use a reverse proxy for an additional layer of security. ## Using URLs For Perspective projects, you can open your web browser and navigate to your Ignition Gateway using the Gateway's IP address: `http://:8088`. The examples below demonstrate this format for both HTTP and HTTPS addresses. ```url title="HTTP" http://:8088/data/perspective/client/YourPerspectiveProject ``` ```url title="HTTPS" https://:8043/data/perspective/client/YourPerspectiveProject ``` ### Deep Links Both Vision and Perspective projects can use the deep links feature to launch a project with a URL. Refer to the [Deep Links](../../launchers-and-workstation/launchers-and-workstation.md#deep-link-and-file-association-support) section for more information. * Vision Format: `vision://Gateway/projectName` * Perspective Format: `perspective://Gateway/projectName` ## Using VPN A Virtual Private Network (VPN) allows you to securely connect to your Gateway's local network from a remote location. ### Set Up a VPN Server 1. Install and configure a VPN server on your network. Common options include OpenVPN, WireGuard, or a built-in VPN server on your router. 2. Ensure the VPN server is properly configured to allow remote connections and has the necessary firewall rules to permit traffic. ### Connect to the VPN 1. Install the VPN client software on your remote device. 2. Configure the VPN client with the server's address and the necessary authentication details. 3. Connect to the VPN. Once connected, your remote device will be part of your Gateway's local network. ## Using Port Forwarding Port forwarding allows you to expose the specific ports of your Gateway's local network to the internet. ### Configure Port Forwarding on Your Router 1. Log in to your router's admin interface. 2. Locate the port forwarding section and create rules to forward the Ignition Gateway ports to the internal IP address of your Ignition Gateway server. - Port 8088 for HTTP - Port 8043 for HTTPS ``` External Port: 8088 -> Internal IP: -> Internal Port: 8088 External Port: 8043 -> Internal IP: -> Internal Port: 8043 ``` ## Using Reverse Proxy A reverse proxy can provide an additional layer of security and simplify access to your Ignition projects. ### Set Up a Reverse Proxy 1. Install a reverse proxy server on your network. Common options include Nginx, Apache, or HAProxy. 2. Configure the reverse proxy to forward requests to your Gateway. ```nginx title="Example Nginx configuration" server { listen 80; server_name ; location / { proxy_pass http://:8088; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto $scheme; } } server { listen 443 ssl; server_name ; ssl_certificate /path/to/your/certificate.crt; ssl_certificate_key /path/to/your/certificate.key; location / { proxy_pass https://:8043; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto $scheme; } } ```
