--- title: "UDT Multi-Instance Wizard" --- # UDT Multi-Instance Wizard >
The Multi-Instance Wizard provides a streamlined way to generate multiple instances of a UDT. ## Accessing the Multi-Instance Creation Wizard Users can access the Multi-Instance Creation Wizard through: - The **Add** ![](../../icons/add.png) menu in the Tag Browser toolbar. ![](add-menu.png) - The right-click menu in the Tag Browser tree. ![](right-click.png) Selecting the **Multi-Instance Wizard** option from either location will open the Multi-Instance Creation Wizard. ## Instance Naming and Pattern Configuration The Multi-Instance Creation Wizard has two tabs: **Create Instances** and **Configure Parameters**. ### Create Instances This section defines how the instance names will be generated and where they will be placed. - **Data Type**: A dropdown selector used to choose the UDT definition to instantiate. - **Folder Location**: A folder selector used to define where the new instances will be created in the Tag Browser. - **Base Instance Name**: An input field used to define the base name for each instance. You can use reference tokens enclosed in curly braces to define dynamic naming patterns (e.g., `motor{x}`). - **Reference Table**: When a reference is defined in the Base Instance Name using curly braces, a row is added to the reference table. | Column | Description | |--------|-------------| | Reference | The name of the reference token (e.g., `x` in `{x}`). | | Pattern Type | Defines the type of pattern to apply (Numeric, Alpha (Upper), Alpha (Lower), or List of Names). Prior to 8.3.9, List of Names was not an available Pattern Type. | | Number Format | Optional format mask for numeric patterns (e.g., `#`, `##`, `000`). | | Step Count | Defines the numeric step increment between values. | | Start From | The starting value for the pattern. | | End At | The last value in the sequence. Only applicable to numeric references. | ### Configure Parameters If the selected UDT includes [parameters](platform\tags\user-defined-types-udts\udt-parameters\udt-parameters.md), the **Configure Parameters** tab becomes available. By default, parameters inherit values from the UDT definition. To override them, you can enable and configure them using the **Parameter Table**. | Column | Description | |--------|-------------| | Parameter | The name of the UDT parameter. Includes a checkbox to enable overriding the default value. | | Type | The data type of the parameter. | | Parameter Value | The value to assign. This field becomes editable when the parameter is enabled. | | Pattern Type | Defines how the parameter value will be applied. Options include None, Numeric, and Manual Entry. | | Step Count | Applicable to numeric patterns. Defines the interval between values. | | Start From | The starting value for the numeric pattern. | | Placement | Specifies whether the value should appear before or after the base string value (e.g., `1Motor` vs. `Motor1`). Applies to string concatenation. | Use this table to specify parameter values per instance or apply patterns dynamically. ### Preview Table The preview table displays a live preview of the instances that will be created. This includes: - **Instance Name**: The full name of each instance as it will appear in the Tag Browser. - **``**: A column for each UDT parameter. Shows inherited or overridden values per instance. This preview updates in real time as you modify the base name, pattern configuration, or parameter values. ## How to Make New Instances of a UDT Once you have a UDT Definition created, you can make multiple instances of it with the Multi-instance Creation Wizard. 1. In the **Tag Browser**, click the Add ![](../../icons/add.png) icon to create a new folder. In this example, we created a folder named **Machine Motors**. 2. Right-click on the **Machine Motors** folder, and select **Multi-Instance Wizard** to open the Multi-Instance Creation Wizard. ![](motor-folder.png) 3. Select a UDT (i.e., **Motor**) from the **Data Type** dropdown menu. ![](data-type.png) 4. In the **Base Instance Name** field, enter: - `Motor {x}` (Include a space after "Motor" to separate numbers.) ![](base-instance-name.png) 5. In the Reference Configuration Table, configure the pattern: - **Pattern Type**: Numeric - **Start From**: `1` - **End At**: `5` ![](reference-table.png) This configuration generates **five** instances: - Motor 1 - Motor 2 - Motor 3 - Motor 4 - Motor 5 6. The Preview table dynamically updates, showing how instance names and parameter values will be applied. ![](preview.png) 7. If the selected UDT has parameters, the **Configure Parameters** tab will be visible. To configure: - Check the parameter to enable configuration. - Choose a Pattern Type (Numeric). - Enter a custom value or pattern. ![](configure-parameters.png) 8. Verify the created instances in the **Tag Browser**. ![](tag-browser.png) :::note The **Multi-Instance Creation Wizard** cannot edit existing instances. It is only for creating multiple instances of a UDT. To modify instances, see [How to Edit an Existing UDT](platform\tags\user-defined-types-udts\udt-parameters\udt-parameters.md). :::
