--- title: "Tag Event Scripts" --- # Tag Event Scripts >
Scripts can be attached to tags. When you edit a tag, you can navigate to the Tag Events section and click on the **Edit** ![](../icons/edit.png) icon to see a list of all of the available events. Those events are * Value Changed * Quality Changed * Qualified Value * Alarm Active * Alarm Cleared * Alarm Acknowledged Because tags are stored in the Gateway, they aren't scoped to a specific project. In these cases, some system functions may require that you specify a project or other resource, such as a database for the [system.db.runPrepUpdate](appendix\scripting-functions\system-db\system-db-runPrepUpdate.md) function. :::note Because these scripts are Gateway scoped, certain things like print statements will not print to the Designer console, but will print instead to the wrapper log file in Ignition's installation directory. The preferred approach to adding logging statements to Tag Event Scripts is to use the [system.util.getLogger](appendix\scripting-functions\system-util\system-util-getLogger.md) function, which will send the messages to the [Gateway's Logs](platform/gateway/web-interface/diagnostics/diagnostics-logs/diagnostics-logs.md) page. ::: ## Event Options Once an event has been selected, note that the top of the text area is [defining a function](platform\scripting\python-scripting\user-defined-functions.md). As a result, all code that should execute when this event occurs should be indented at least once to be included in the definition. ![](img1.jpg) ### Value Changed The Value Changed event is fired whenever the value of the particular tag changes. This event has a variety of arguments available for use in the script: * String tagPath: The full path to the tag. Example: `[tagProvider]Folder/Folder/Tag` * Object previousValue: The previous value. This is a qualified value, so it has value, quality, and timestamp properties. * Object currentValue: The current value. This is a qualified value, so it has value, quality, and timestamp properties. * Boolean initialChange: A boolean flag indicating whether this event is due to the initial subscription or the first execution after a tag update. The valueChanged event will have an initialChange of true if either: * The tag’s previous value was null, as in the first evaluation of an expression tag after a Gateway restart * Its previous quality was [Uncertain_InitialValue](platform\tags\quality-codes-and-overlays\quality-codes-and-overlays.md#quality-code-reference-table). This is typically an OPC tag’s initial value before a true value is delivered from a subscription. * Boolean missedEvents: A flag indicating that some events have been skipped due to an event overflow. :::note The currentValue and previousValue arguments are qualified values: objects that contain a value, timestamp, and quality. This means that to get to the value of the currentValue, your script would need to access `currentValue.value`. Refer to [Scripting Object Reference](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualifiedvalue) for more information about qualified values. ::: ### Quality Changed The Quality Changed event is fired whenever the quality of the tag changes. This event has a variety of arguments available for use in the script: * String tagPath: The full path to the tag. Example: `[tagProvider]Folder/Folder/Tag` * Object previousValue: The previous value. This is a qualified value, so it has value, quality, and timestamp properties. * Object currentValue: The current value. This is a qualified value, so it has value, quality, and timestamp properties. * Boolean initialChange: A boolean flag indicating whether this event is due to the initial subscription or the first execution after a tag update. * Boolean missedEvents: A flag indicating that some events have been skipped due to an event overflow. ### Qualified Value The Qualified Value event is fired whenever the value, quality, or timestamp of the tag changes, depending on the change trigger enabled on the script: * Value * Quality * Timestamp This event has a variety of arguments available for use in the script: * String tagPath: The full path to the tag. Example: `[tagProvider]Folder/Folder/Tag` * Object previousValue: The previous value. This is a qualified value, so it has value, quality, and timestamp properties. * Object currentValue: The current value. This is a qualified value, so it has value, quality, and timestamp properties. * Boolean initialChange: A boolean flag indicating whether this event is due to the initial subscription or the first execution after a tag update. * Object changed: Information about which aspects of the qualified value (value, quality, timestamp) changed to trigger the event. * Boolean missedEvents: A flag indicating that some events have been skipped due to an event overflow. ### Alarm Active The Alarm Active event fires whenever a new active alarm event occurs. This event has a variety of arguments available for use in the script: * String tagPath: The full path to the tag. Example: `[tagProvider]Folder/Folder/Tag` * String alarmName: The name of the alarm. This does not include the full alarm path. * Object alarmEvent: The full alarm event object. The properties available to this object are: * eventId * source * name * priority * displayPath * displayPathOrSource (the display path if it is set, otherwise the source) * state (the current state, active/cleared + acked/unacked) * eventState (the last transition, active, clear, acknowledged) * isClear (a boolean if the alarm is currently cleared) * isAcked (a boolean if the alarm is currently acknowledged) * isShelved (a boolean if the alarm is currently shelved) * notes * String alarmPath: The full alarm path. * Boolean missedEvents: A flag indicating that some events have been skipped due to an event overflow. ### Alarm Cleared The Alarm Cleared event fires whenever an alarm becomes cleared on the tag. This event has a variety of arguments available for use in the script: * String tagPath: The full path to the tag. Example: `[tagProvider]Folder/Folder/Tag` * String alarmName: The name of the alarm. This does not include the full alarm path. * Object alarmEvent: The full alarm event object. See the [Alarm Active alarmEvent object](#alarm-active) for the full list of available properties. * String alarmPath: The full alarm path. * Boolean missedEvents: A flag indicating that some events have been skipped due to an event overflow. ### Alarm Acknowledged The Alarm Acknowledged event fires whenever an alarm event becomes acknowledged on the Tag. This event has a variety of arguments available for use in the script: * String tagPath: The full path to the tag. Example: `[tagProvider]Folder/Folder/Tag` * String alarmName: The name of the alarm. This does not include the full alarm path. * Object alarmEvent: The full alarm event object. See the Alarm Active alarmEvent object for the full list of available properties. * String alarmPath: The full alarm path. * String ackedBy: The full path to the user that acknowledged the alarm. * Boolean missedEvents: A flag indicating that some events have been skipped due to an event overflow. ## Using the Project Library in a Tag Event Script Scripts defined in a project script can be called from a Tag Event Script. However, only scripts defined in the Gateway Script Project may be used. For more information on configuring the Gateway Scripting Project, see the [Project Library](platform\scripting\scripting-in-ignition\project-library\project-library.md) page. ## UDT Parameters in Tag Event Scripts Parameters on UDTs can be interacted with from Tag Event Scripts by accessing the parameter values as dictionary values. The script will access the most recent parameter values on a UDT, where the parameters can then change without needing to edit the UDT or restart the tag. For example, if you are trying to access the value of a parameter named "myParam" from a Tag Event Script within the UDT, the script would look like: ```python # Reminder: "tag" is a built-in argument on all Tag Event Scripts. # Accessing the "parameters" key on the tag argument will # provide access to all UDT parameters. paramValue = tag['parameters']['myParam'] ``` Using the approach described above, value changes to UDT parameters will be reflected in subsequent calls. ## Tag Script Examples ```python title="Printing All Parameters" # This script will fetch all of the possible parameters in the Tag Changed Script. # Note that this will not print out to the console, but it will print to the wrapper logs located on the Gateway. path = tagPath prev = previousValue cur = currentValue init = initialChange missed = missedEvents print path, prev.value, cur.quality, init, missed ``` ```python title="Automatic Reset" # This code can be used on a Value Changed script, and will automatically reset the value of the tag to 0 after it goes above 3000. # This can be useful for counter tags. if currentValue.value > 3000: system.tag.writeBlocking(["[default]IntegerCounterTag"], [0]) ``` ```python title="Copy to Another Tag" # This code can be used on a Value Changed script, and will record the highest value of the current tag onto another memory tag. # This can be useful for recording the highest temperature. highestRecordedTemp = system.tag.readBlocking(["[default]HighestTempTag"])[0].value if currentValue.value > highestRecordedTemp: system.tag.writeBlocking(["[default]HighestTempTag"], [currentValue.value]) ``` ## Troubleshooting It may be helpful when troubleshooting or testing Tag Event Scripts to increase the default thread pool count, as reaching the thread pool limit may cause scripts to not run as expected. Refer to the [Gateway Configuration File Reference - Thread Pool Counts](appendix\reference-pages\gateway-configuration-file-reference\gateway-and-gateway-network-parameters\gateway-and-gateway-network-parameters.md#thread-pool-counts) for more information.
