--- title: "Inserting Data into a Database" --- # Inserting Data into a Database > A common way to insert information into a database is to run a script after a user presses a Button component that will collect data and execute a [Named Query](platform\sql-in-ignition\named-queries\named-queries.md) to push that data into a database table. Using a script allows values to be collected from tag values and property values as needed to insert into a table. The following syntax shows how this script can be structured. ```python title="Pseudocode - Collect Data and Insert into the Database" value1 = {component property reference} value2 = {tag value} value3 = {static value} query = "INSERT INTO table (col1, col2, col3) VALUES (?,?,?)" args = [value1, value2, value3] system.db.runPrepUpdate(query, args) ``` It is important to note that if you choose to use the [runPrepUpdate](appendix\scripting-functions\system-db\system-db-runPrepUpdate.md) function in Vision, you'll be required to enable certain [Client Permissions](../../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties). ## Inserting Values on a Button Press Example This example demonstrates how to insert data into a database for both Vision and Perspective using the database table and Named Query created in the steps below: 1. Open the [Database Query Browser](platform\designer\designer-tools\database-query-browser\database-query-browser.md) from the top navigation bar under Tools. 2. Create a **machines** table in a database with a **machine_name** and an **area_number** column. This example uses the following statement for the Default database. ```sql title="Create Table" CREATE TABLE machines ( machine_name varchar(255), area_number int ); ``` 2. Open the **Named Queries** workspace from the Project Browser. 3. Enter **Insert Values** into the New Query name field. 4. Select **Update Query**. 5. Select the **Authoring** tab. 6. Update the two default Value type Parameters. 1. Rename the first value to **machineName** and leave the data type as **String**. 2. Rename the second value to **areaNumber** and change the data type to **Int2**. 7. Enter the following Named Query statement: ```sql title="SQL - Insert Values" INSERT INTO machines (machine_name, area_number) VALUES (:machineName, :areaNumber) ``` ![](img1.png) Refer to the Vision and Perspective sections for the respective steps to build out a window or view for the rest of this example. ### Vision 1. On a Main window, add a Button component, a Text Field component, and a Dropdown component. 2. On the Dropdown's `data` property, create a dataset that contains the following values and labels: |Value|Label| |:---|:---| |1|Area 1| |2|Area 2| |3|Area 3| 3. Change the Button's `text` property to **Submit**. ![](img2.png) 4. Right-click on the **Button** and select **Scripting**. 5. Navigate to the **Script Editor** tab under Event Handlers > action > actionPerformed. 6. Enter the following script, which will pull in the values from the Dropdown and the Text Field, and then insert them into the table using the Insert Values Named Query created above. ```sql title="Python - Button actionPerformed Script" # Grab the area number and machine name from the components we added to the window. areaNum = event.source.parent.getComponent('Dropdown').selectedValue machineName = event.source.parent.getComponent('Text Field').text # A call to our Named Query, inserting the two parameters using dictionary syntax. system.db.execUpdate("Insert Values", {"machineName":machineName, "areaNumber":areaNum}) ``` Verify functionality by placing the Designer in Preview mode, selecting an area, entering in a machine name, and clicking Submit. Open the Database Query Browser and execute a SELECT query to see the new row. ### Perspective 1. Drag a Button component, a Text Field component, and a Dropdown component onto a view. 2. On the Dropdown's `options` property, add three array elements to enter the following value/label pairs: * options.0 * value: 1 * label: Area 1 * options.1 * value: 2 * label: Area 2 * options.2 * value: 3 * label: Area 3 3. Change the Button's `text` property to **Submit**. ![](img2.png) 4. Right-click on the **Button** and select **Configure Events...**. 5. Select **Component Events** > **onActionPerformed**. 6. Click the **Add** ![](add.png) icon and select **Script**. 7. Enter the following script, which will pull in the values from the Dropdown and the Text Field, and then insert them into the table using the Insert Values Named Query created above. ```sql title="Python - Button actionPerformed Script" # Grab the area number and machine name from the components we added to the window. areaNum = self.getSibling("Dropdown").props.value machineName = self.getSibling("TextField").props.text # A call to our Named Query, inserting the two parameters using dictionary syntax. system.db.execUpdate("Insert Values", {"machineName":machineName, "areaNumber":areaNum}) ``` Verify functionality by placing the Designer in Preview mode, selecting an area, entering in a machine name, and clicking Submit. Open the Database Query Browser and execute a SELECT query to see the new row.
