--- title: "Database Authentication" --- # Database Authentication > ## Database User Source The Database Authentication type uses an external database instead of storing data inside Ignition. Managing users is done via direct interaction with the database. This section addresses how to set up a database user source. The Database Authentication type requires you have a connection to an existing database, like SQL Server, Oracle, or MySQL. It stores all users, roles, schedules, and and more in the database, and uses queries to check login credentials. When you create a database user source, you have the option of setting it up in Automatic or Manual mode. #### Automatic Mode In Automatic mode, Ignition will create and manage the database tables for you. You can specify a prefix for the tables that are created automatically for you, but their names after the prefix are chosen by the user source. In this mode, the user source will be fully [manageable](platform/security/security.md) in Ignition. #### Manual Mode In Manual mode, you must provide SQL queries for various functions of the user source. In this mode, the user source will not be manageable from the Gateway or the Clients. You'll have to manage the users directly through the database. Examples for each of the queries are given on the user source setup page. Read each query description carefully to make sure you design your queries to return all the columns that are defined in the query's description as shown below. ## Property Reference Database User Sources have the following properties, organized by category. ### General Properties Details on the General Properties can be found on the [Classic Authentication Strategy](platform\security\classic-authentication-strategy\classic-authentication-strategy.md) page. The Database User Source also has the following properties: |Name|Description| |:---|:---| |Database|The database connection this User Source will retrieve user information from.| |Mode|How the Gateway should manage the database tables. Has two settings: **Automatic**: The Gateway will automatically create the database tables necessary, and all interactions with the table will use the built-in queries. When this option is set, the **Tablename Prefix** property is utilized. **Manual**: The Gateway will not automatically create any database tables, nor will it automatically modify users or roles. When set to manual, it is assumed that you want to manually write the queries that update the tables, or are utilizing another system. When Mode is set to this option, the **Manual Mode** properties are used to determine how the Gateway should query user data.| ### Automatic Mode Properties |Name|Description| |:---|:---| |Tablename Prefix|When set to **Automatic** mode, this property determines the prefix that will be used on all automatically created tables. Useful when multiple database User Sources are connected to the same database scheme.| ### Manual Mode |Name|Description| |:---|:---| |Authentication Query| A query that **must** return a row if the given username and password combination provided is valid. The query will run as a prepared statement, so use the question mark character (?) to represent username first and then password. The returned row may contain the user's basic properties under the column names: [firstname, lastname, schedule, language, notes] Note that the Gateway will pass both the username and password the user typed in, so this query **MUST** utilize exactly two question marks, otherwise an exception will occur.| |Badge Authentication Query |A query that must return a row if the given badge provided is valid. The query will be run as a prepared statement, so use question mark (?) to represent the badge. The returned row must contain the username.Example: `SELECT username FROM USERS WHERE badge = ?`| |List Roles Query|A query that returns all possible roles that any user could be a member of. The role names must be returned in the first column of the query's results.| |User's Roles Query|A query that returns all of the roles that the provided user belongs to. The roles must be strings and must be in the first column of the query's results. The query will be run as a prepared statement with one parameter: the username.| |Find User Query | A query that returns a row if a user with the given username exists. The query will be run as a prepared statement, so use question mark (?) to represent username. There must be at least one column: the username. Other columns are optional, supported columns are: [username, firstname, lastname, schedule, language, notes, badge].Example: `SELECT username, firstname, lastname, schedule, FROM USERS WHERE username = ?`When the User Source is paired with an [Ignition Identity Provider](platform\security\identity-provider-authentication-strategy\configuring-identity-providers\configuring-identity-providers.md#internal-ignition-identity-provider), enabling this option can provide a modest performance improvement during session login. | |List Users Query| A query that returns a row containing each username. There must be at least one column: the username. Other columns are optional, supported columns are: [username, firstname, lastname, schedule, language, notes].| |Contact Info Query|A query that returns all of the contact info for the user. The first column must be the contact type, the second column the contact value. Optional, may be blank.| Schedule Adjustment Query| A query that returns the upcoming schedule adjustments for the user. This property is optional, and may be left blank. The results set expects the following columns: **Start**(date)**End**(date)**Available**(boolean)**Note**(string)| |Extra Properties Query|A query that returns name, value pairs of extra properties for the user. Will be run with one parameter: the username. Optional, may be blank. ## To Create a Database User Source 1. On the Gateway Webpage under the **Platform** tab, go **Security > User Sources**. The User Sources page will be displayed. 1. Click **Create User Source +**. 1. Choose the **Database** authentication type, and click **Next**. ![](create-db-user-source.png) 1. The Configure Source form will open. Some properties are optional, but if you're using Automatic mode, enter the following properties as appropriate. + **Name**: DBAuth + **Failover Source**: default + **Failover Mode**: Hard + **Database**: MySQL + **Mode**: Automatic + **Tablename Prefix**: auth_ (You can leave this field blank, but if you use a prefix when the tables get created, they will contain the specified prefix in their name). When finished, click **Create User Source**. ![](databaseDBAauth.png) :::note Table Creation The tables in the database will not be created in the database until they are needed. For example, as soon as a user or role is added, the associated tables will automatically get created. ::: 1. Now that your Authentication profile is created, add a user. On the right, click on the **three dot** menu and select **Manage Users**. Click **Create User +** and fill in the required fields. 1. To view and verify the tables, go into **Designer** and from the menu bar, select **Tools** > [Database Query Browser](platform\designer\designer-tools\database-query-browser\database-query-browser.md).You will see all the tables that were created beginning with 'auth_' when the user and role get created. 1. Double click on any of tables beginning with '**auth_**', and click **Execute**. In this example, you will see the tables associated with 'roles' and 'users' displayed in the Schema area. ![](usertable.png) ### Password Encryption When a database user source Mode is set to Automatic, Ignition encrypts the user’s password in the database using SHA1. However, it is possible to allow users to change their passwords using an update query. The script below takes a password string, encrypts it, and updates the password in the database. ```python title="Simple Password Encryption Script" # Get the current logged in user’s username. username = system.tag.readBlocking(["[System]Client/User/Username"])[0].value # Take the user’s new password from a component. We are using the Password Field component. newPass = event.source.parent.getComponent('Current Password').text # Import SecurityUtils from com.inductiveautomation.ignition.common.util. from com.inductiveautomation.ignition.common.util import SecurityUtils # Encrypt the password from the second line using SecurityUtils. # This will encrypt your password as SHA1. encryptPass = SecurityUtils.sha1String(newPass) # Add our update query. query = "UPDATE scada_users SET passwd = ? WHERE username = ?" # Execute our query to update the password in the database. system.db.runPrepUpdate(query, (encryptPass, username), 'database_connection') ``` This is a simplified script, but you can add additional logic to your script. For example, the following script also validates the user’s current password before allowing them to update their password. ```python title="Password Encryption Script with User Validation" # Get the current logged in user’s username. username = system.tag.readBlocking(["[System]Client/User/Username"])[0].value # Create a variable for the user’s current password. In the client this is where the user enters their current password. password = event.source.parent.getComponent('Current Password').text # If the field isn't empty, continue; otherwise warn the user. if password != "": # Validate the username and password for the current logged-in user. confirmPassword = system.security.validateUser(username, password) if confirmPassword: # Get new password entries (must match). pass1 = event.source.parent.getComponent('Password 1').text pass2 = event.source.parent.getComponent('Password 2').text if pass1 == pass2: # Encrypt the new password as SHA1. from com.inductiveautomation.ignition.common.util import SecurityUtils newPass = SecurityUtils.sha1String(pass1) # Update the password in the database. query = "UPDATE support_users SET passwd = ? WHERE username = ?" system.db.runPrepUpdate(query, (newPass, username), 'database_connection') # Inform the user. system.vision.showMessage("Your password has been updated.") else: system.vision.showWarning("Password 1 and Password 2 do not match") else: system.vision.showWarning("Incorrect password") else: system.vision.showWarning("Enter current password") ```
