--- title: "Exporting and Importing a CSV" --- # Exporting and Importing a CSV > A CSV (comma separated values) file, is one of the most simple structured formats used for exporting and importing datasets. It is a convenient and flexible way to edit and share data across applications. Ignition has a built-in function to convert a dataset to CSV data called [system.dataset.toCSV](appendix\scripting-functions\system-dataset\system-dataset-toCSV.md). You can even convert the contents of a CSV in a script and move it to an Ignition component, such as a Table. This section contains examples for exporting and importing data to a CSV, as well as converting the contents of a CSV file. ## Exporting Data to a CSV You can export a dataset from a query or table to a CSV file. In the following examples, we will generate data on a Power Table and Table component in Vision and Perspective, respectively, and then export that data. ### Vision Example 1. Drag a **Power Table** component on to your window and toggle its **TestData** property to generate some data. ![](testdata.png) 2. Drag a **Button** component on the window, and select **Scripting** from the Button's right-click menu to open the Component Scripting popup. 3. Select the **action** > **actionPerformed** event, and click on the **Script Editor** tab. 4. Copy the example script below, and paste the contents to the Script Editor. ```python title="Hard Coded Filepath" # Create a variable that references our Power Table. You could modify this part # of the example to point to a different component in the window. component = event.source.parent.getComponent('Power Table') # Use system.dataset.toCSV to turn the dataset into a CSV string csv = system.dataset.toCSV(component.data) # Write to local file system. Note the "r" character right before the directory path. # This denotes a raw string literal, meaning we ignore escape sequences (like the "/") system.file.writeFile(r"C:\myExports\myExport.csv", csv) ``` ![](actionperformed.png) To test your script, put the Designer in Preview Mode, and click the Button component. Then, open your myExport.csv file and check your data. ![](myexport.png) :::info Selecting a Path Directory Instead of hardcoding the path as we did in the above example, we could ask the user to select a directory on the local system with [system.vision.saveFile](appendix\scripting-functions\system-vision\system-vision-saveFile.md): ```python title="User Selected Directory" # Create a variable that references our Power Table. You could modify this part # of the example to point to a different component in the window. component = event.source.parent.getComponent('Power Table') # Use system.dataset.toCSV to turn the dataset into a CSV string. csv = system.dataset.toCSV(component.data) # Use system.vision.saveFile to have the user find a directory to write to. filePath = system.vision.saveFile("myExport.csv", "csv", "Comma Separated Values") # We can check the value of filePath to make sure the user picked a path before # attempting to write. if filePath: system.file.writeFile(filePath, csv) ``` ::: ### Perspective Example This example will demonstrate how to generate a CSV file from a Table component that contains a dataset. Note that you can run the script in this example using the default data for a Table component, but since it is a JSON array structure and not a dataset, the CSV file format will result in a single row of data. 1. Drag a **Table** component to your view. 2. Right-click on the `data` property and select **Change to** > **Value**. ``` { "$": [ "ds", 192, 1787772403105 ], "$columns": [ { "name": "Col 1", "type": "Integer", "data": [ 44, 86, 0, 78, 20, 21 ] }, { "name": "Col 2", "type": "String", "data": [ "Test Row 2", "Test Row 3", "Test Row 8", "Test Row 9", "Test Row 10", "Test Row 13" ] }, { "name": "Col 3", "type": "Double", "data": [ 1.8713151369491254, 97.4913421614675, 20.39722542161364, 34.57127071614745, 76.41114659745085, 13.880548366871926 ] } ] } ``` |Col 1|Col 2|Col 3| |--|--|--| |44 |Test Row 2 |1.87| |86 |Test Row 3 |97.49| |0 |Test Row 8 |20.4| |78 |Test Row 9 |34.57| |20 |Test Row 10 |76.41| |21 |Test Row 13 |13.88| 3. Drag a **Button** component to the view, and select **Configure Events** from the Button's right-click menu to open the Event Configuration popup. 4. Select **Component Events** > **onActionPerformed**. 5. Click the Add icon and select **Script**. 6. Copy and paste the script example below into the Script field. ```python title="Exporting Data" # Create a variable that references our Table. component = self.getSibling("Table").props.data # Use system.dataset.toCSV to turn the dataset into a CSV string csv = system.dataset.toCSV(component) # Write to local file system. Note the "r" character right before the directory path. # This denotes a raw string literal, meaning we ignore escape sequences (like the "/") system.file.writeFile(r"C:\myExports\myExport.csv", csv) ``` ![](onactionperformed.png) To test your script, put the Designer in Preview Mode, and click the Button component. Then, open your myExport.csv file and check your data. :::info Selecting a Path Directory Instead of hardcoding the path as we did in the above example, we could ask the user to select a directory on the local system with [system.perspective.download](appendix\scripting-functions\system-perspective\system-perspective-download.md): ```python title="User Selected Directory" # Create a variable that references our Table. component = self.getSibling("Table").props.data # Use system.dataset.toCSV to turn the dataset into a CSV string csv = system.dataset.toCSV(component) # Have the user find a directory to write to. system.perspective.download("myExport.csv",csv) ``` ::: ## Importing Data from a CSV There are several ways to import data from a CSV file. First, we could use [system.file.readFileAsString](appendix\scripting-functions\system-file\system-file-readFileAsString.md) to read the entire file as a string. Note, that this will read the file as is, meaning `\n` can be used to denote new lines. ```python title="Python - Using system.file.readFileAsString()" # Specify the CSV path in the local file system. file = "C:\\my_dataset.csv" # Use readFileAsString to read the contents of the file as a string. # This string will be the parameter we pass to fromCSV below. stringData = system.file.readFileAsString(path) # Split stringData into a List of strings, delimited by the new line character stringData = stringData.split("\n") # Iterate through the list, and do something with each line for i in range(len(stringData)): # We're printing the row here, but you could do something more useful with the data. print stringData[i] ``` Alternatively, Python's CSV Library could be use to read in the contents of a CSV. In some cases, this is the easier approach, as the reader object is ready to be iterated over. Note, that this approach does read in each row as a List of strings: ```python title="Python - Using csv.reader()" # Import Python's built-in csv library import csv # Specify the CSV path in the local file system. file = "C:\\my_dataset.csv" # Create a reader object that will iterate over the lines of a CSV. # We're using Python's built-in open() function to open the file. file = open(path) csvData = csv.reader(file) # Iterate through the reader object, and do something with each line for row in csvData: # We're printing the row here, but you could do something more useful with the data. print row # Close the file once we're done with it file.close() ``` ## Converting the Data into a Dataset If you want to move CSV data into a component, it will need to be converted into a dataset so that it fits into the component's **data** property. There are a couple of functions that can be used to accomplish this depending on the format of your CSV file. ### Calling the system.dataset.fromCSV Function The [system.dataset.fromCSV](appendix\scripting-functions\system-dataset\system-dataset-fromCSV.md) function can take a string and convert it to a dataset. Note, that the function expects a very specific format: ```python title="CSV File Content" #NAMES Col 1,Col 2,Col 3 #TYPES I,str,D #ROWS,6 44,Test Row 2,1.8713151369491254 86,Test Row 3,97.4913421614675 0,Test Row 8,20.39722542161364 25,Test Row 4,20.39722542444222 33,Test Row 5,20.39722542232323 62,Test Row 6,20.39722542111999 ``` #### Vision Example 1. Create a text file on your local system named **example.csv** containing the CSV file Content data. ![](example-notepad.png) 2. Add a **Power Table** and a **Button** component to your window. 3. Select **Scripting** from the right-click menu for the Button component, and paste the following code into the **Script Editor** of the actionPerformed event: ```python title="Python - Using system.dataset.fromCSV()" # Ask the user to find the CSV in the local file system. path = system.vision.openFile("csv") # Use readFileAsString to read the contents of the file as a string. stringData = system.file.readFileAsString(path) # Convert the string into a dataset data = system.dataset.fromCSV(stringData) # Pass the dataset to the data property on the Power Table. event.source.parent.getComponent('Power Table').data = data ``` ![](fromcsv.png) 4. Put the Designer into Preview Mode, and click the **Button**. 5. A window will open for you for you to navigate and choose your CSV file, then click Open. ![](export-import.png) Your data will be displayed in the Power Table as shown below. ![](power-table.png) #### Perspective Example 1. Create a text file on your local system named **example.csv** containing the CSV file Content data. ![](example-notepad.png) 2. Add **Table** component and a **Button** component to your view. 3. Select **Configure Events** from the Button's right-click menu to open the Event Configuration popup. 4. Select **Component Events** > **onActionPerformed**. 5. Click the Add icon and select **Script**. 6. Paste the following code into the **Script Editor** of the actionPerformed event: ```python title="Python - Using system.dataset.fromCSV()" # Specify file path. file_path = "C:\\my_dataset.csv" # Read in the file as a string. data_string = system.file.readFileAsString(file_path) # Convert the string to a dataset and store in a variable. data = system.dataset.fromCSV(data_string) # Assign the dataset to a table. self.getSibling("Table").props.data = data ``` ![](perspective-fromcsv.png) 7. Put the Designer into Preview Mode, and click the **Button**. Your data will be displayed in the Table as shown below. Notice that the default array structure has been changed to value. ![](table.png) ### Calling the csv.reader Function As mentioned, `system.dataset.fromCSV()` requires a specific format, which may not match the format of your file. In this case, we can use Python's CSV Library to parse the file and convert it to a dataset. ```python title="CSV File Content" Col 1,Col 2,Col 3 44,Test Row 2,1.8713151369491254 86,Test Row 3,97.4913421614675 0,Test Row 8,20.39722542161364 25,Test Row 4,20.39722542444222 33,Test Row 5,20.39722542232323 62,Test Row 6,20.39722542111999 ``` Below is Vision code example to import the Python CSV data. Specifying the file path directly and replacing `event.source.parent.getComponent('Power Table').data = dataset` with `self.getSibling("Table").props.data = dataset` will enable this script to work for a Perspective Table component. ```python title="Python - Using Python's CSV Library" # Import Python's built-in CSV library. import csv # Ask the user to find the CSV in the local file system. path = system.vision.openFile("csv") # Create a reader object that will iterate over the lines of a CSV. # We're using Python's built-in open() function to open the file. file = open(path) csvData = csv.reader(file) # Create a List of strings to use as a header for the dataset. Note that the number # of headers must match the number of columns in the CSV, otherwise an error will occur. # The simplest approach would be to use next() to read the first line in the file, and # store that at the header. header = csvData.next() # Create a dataset with the header and the rest of our CSV. dataset = system.dataset.toDataset(header, list(csvData)) # Store it into the table. event.source.parent.getComponent('Power Table').data = dataset # Close the file file.close() ```
