--- title: "Scripts" --- # Scripts > The Running Scripts page provides a real-time view of all actively running Gateway scripts and includes tools to manage them, such as terminating a script. Similar functionality is available in the Vision Client and Designer consoles through their respective Running Scripts tabs. ## Running Scripts | Attribute | Description | |---------------------|---------------------------------------------------------------------------------| | Thread Id | The unique identifier (ID) of the thread running the script. | | Description | The name and description of the script. | | Execution Start | The timestamp indicating when the script began execution. | | Elapsed Time | The total time the script has been running. | To manage a script, expand the three dots menu ![](three-dot-menu.png) next to the script entry. Actions such as terminating the script can be performed from this menu. ![Diagnostics - Running Scripts](diagnostics-running-scripts.png) ## Gateway Scripts The Gateway Scripts page provides an overview of all configured Gateway Event Scripts. These scripts are managed in the [Gateway Event Scripts](platform/scripting/scripting-in-ignition/gateway-event-scripts/gateway-event-scripts.md) section of a project. The scripts are organized into tabs, each categorized by function. | Tab | Description | |------------------|-------------------------------------------------------------------------------------------------| | Startup | Scripts that execute when the Gateway starts. | | Update | Scripts that execute during project updates. | | Shutdown | Scripts that execute when the Gateway shuts down. | | Timer | Scripts that execute at predefined time intervals. | | Tag Change | Scripts that execute when a tag value changes. | | Messages | Scripts that execute in response to system or user-defined messages. | | Scheduled | Scripts that execute at specific times or dates. | ![Diagnostics - Gateway Scripts](gateway-scripts.png) ### Scripts Section Properties The **Scripts** section for the selected tab displays key details about each script. | Attribute | Description | |-----------------------|---------------------------------------------------------------------------------| | Project | The project where the script is configured. | | Last Execution | The most recent time the script ran. | | Duration | The time taken for the script to execute. | | Status | Indicates whether the script completed successfully or encountered an error. | ### Log Activity Properties The **Log Activity** section displays logger entries related to the configured Gateway Event Scripts with relevant attributes. | Attribute | Description | |-------------|-------------------------------------------------------------------------------------| | Min Level | Dropdown menu with filter options for INFO, DEBUG, and TRACE. | | Live Values | Toggle switch to turn live values on or off. | | Merge to Logs | Merge the settings of the current view with the main Diagnostics Log Viewer. | | Logger | The name of the logger associated with the script entry. | | Time | The timestamp indicating when the log entry was created. | | Message | The log message providing details about the script's behavior or any issues encountered. | To display additional properties, select the ![](log-props-icon.png) icon next to the logged event. ![](log-event-props.png)
