title: "Gateway Backup and Restore"
# Gateway Backup and Restore
## Gateway Backups vs Project Exports
There are two main types of backups available in Ignition: Gateway backups and Project exports. Gateway backups are all inclusive while Project exports are simply a backup of an individual project. This page discusses making Gateway backups and restoring from a Gateway backup. To learn more about project backups and restoring projects, refer to the [Project Export and Import](platform\projects\project-export-and-import\project-export-and-import.md) page.
Creating Gateway backups and restoring from a Gateway backup are super easy in Ignition. Gateway backups are all inclusive, and typically takes less than a minute to run. It includes everything you find in the Ignition Gateway Webpage. Everything gets backed up - all your projects, Gateway settings, authentication profiles, tags, database connections, OPC and device connections, alarm pipelines, scripts, sequential function charts, reports, and Image Management Library (i.e., png, jpg, and jpeg files). The only data that is not included in a Gateway backup is data stored in other programs such as SQL databases, PLC programs, other files you manually added to the install directory, and any additional files you may be using. This information needs to be backed up separately.
Perspective custom assets such as fonts, icons, and themes are included in a Gateway backup. In addition, any custom assets in a backup file will be restored when performing a Gateway restore.
You have the option of creating a Gateway backup and restoring a backup from the Gateway Webpage or [Gateway Command-line Utility - gwcmd](platform\gateway\gateway-command-line-utility-gwcmd\gateway-command-line-utility-gwcmd.md). We recommend using Gateway Webpage since it's much easier.
### Scheduled Gateway Backups
In addition to manually taking a Gateway backup, an Ignition Gateway can be configured to automatically collect Gateway backups on a schedule. See the [Gateway Settings](platform/gateway/web-interface/platform/gateway-settings/gateway-settings.md) page for more details.
### Contents of a Gateway Backup
A Gateway backup represents a number of resources and configurations to apply during restoration. Restoring from a Gateway backup replaces the following resources on the target Gateway:
* Database connections
* JDBC drivers
* Gateway settings
* Web server settings
* Gateway Network settings
* Email settings
* Auditing settings
* User Sources
* IdP configurations
* Security Levels
* Security Zones
* Alarming settings
* Alarm Journal Profiles
* Alarm Notification Profile settings
* On-call rosters
* Alarm Schedules
* SECS/GEM equipment configurations and module settings
* Tag History Providers
* All Tag Providers, and the tags, UDT definitions, and Tag Groups within
* Device connections
* OPC UA client connections
* OPC UA settings
* BACnet local device configurations
* EAM settings
* SFC settings
* All projects, and their resources within
Notably, when restoring a Gateway backup on an existing Gateway, the following items are **not** changed or replaced by the backup:
* Modules
* License information/grants
* Redundancy settings
* [Tag Reference Store](platform\tags\tag-diagnostics\tag-diagnostics.md#collecting-data-backups)
## Downloading Redundant Gateway Backups
Within a redundant Gateway pair, users also have a **Download with Peer Data** button. This button will use the redundant Gateway backup's local configuration files, such as SSL certificate details, along with the rest of the contents listed [above](#contents-of-a-gateway-backup).
If you do not want the backup Gateway's local files, you can use the dropdown menu to select the **Download without Peer Data** option. This will download a Gateway backup containing the normal contents.
## Manually Collecting a Gateway Backup Example
The easiest way to create a backup of the Gateway is using the Gateway Webpage.
1. Go to the **Platform** tab of the Gateway Webpage, and click on **System** > **Backup & Restore**.
2. The System Backup & Restore page will be displayed. Make sure the **Backup** tab is selected, then click **Download Backup**.
3. By default, this downloads a `.gwbk` file extension to your local file system in your **Downloads** folder.
:::note
The Gateway Backup default filename will look like `GatewayName_Ignition-backup-YYYYMMDD-HHMM.gwbk` where `YYYYMMDD-HHMM` is the timestamp of when it was created.
#### Command-line Utility
In Windows and Linux, you can use the command-line utility to create a Gateway backup. To run the Command-line Utility, open a shell and enter the command below.
:::note
If you want to add a timestamp, you need to enter the date and time in the filename. Refer to the [Command-line Utility](platform\gateway\gateway-command-line-utility-gwcmd\gateway-command-line-utility-gwcmd.md) page for a complete list of 'gwcmd' options.
gwcmd -b C:\Backups\Ignition\IgnitionBackup.gwbk
## Restoring a Gateway Backup Example
Restoring a Gateway backup is just as easy as backing it up, and it can also be done from the Gateway Webpage.
:::caution
When you perform a Gateway Restore, **ALL** of the server's current configuration will be permanently lost. Restoring a Gateway backup overwrites all of the existing settings including your projects. There is no merge option for a Gateway backup. We recommend you always make a backup of the existing server immediately before performing a Gateway Restore.
:::note
A Gateway backup can also be restored during installation, using the optional Restore from Backup step in the Ignition installer. The selected backup is restored on the first Gateway startup. See [Install Ignition](getting-started/installing-and-upgrading/installing-and-upgrading.md#install-ignition) for details.
1. Go to the **Platform** tab and click on **System** > **Backup & Restore**.
2. The System Backup & Restore screen will be displayed. Click on the **Restore** tab. Read carefully through the restoration settings, and check the ones you wish to enable.
:::note
If you check the **Restore Disabled** box, the imported resources will be disabled upon restoration.
3. Click **Choose File**, then navigate to your Gateway backup file (`*.gwbk`). By default, all your Gateway backup files are saved in your Downloads folder unless you select another folder location to choose an existing Gateway Backup file (`*.gwbk`) to restore.
4. Choose your Ignition backup file (`.gwbk`), and click **Open**.
5. Click **Restore** in the top-right of the System Backup & Restore screen. The Gateway stops while restoring the backup file. When restoring is complete, the Gateway restarts itself to apply the restored settings. The Gateway Webpage is refreshed and your projects are loaded and your whole Gateway is restored in less than a minute.
The following table describes different Gateway restoration settings.
#### Gateway Restore Settings
| Property | Description |
| Restore Disabled | Checkbox for toggling if the Gateway Backup file's contents such as projects, database connections, OPC connections, Tag Providers, etc will be disabled upon restore. |
| Disable Temp Project Backup | Checkbox for toggling if the projects directory will have a temporary backup created during the restore process. |
| Override Gateway Name | Checkbox for toggling if the name of the Gateway should be overridden before the Gateway is restored. **CAUTION**: It is not recommended to change the Gateway's System Name after initial Gateway setup. Renaming your Gateway may break critical dependencies, affect data collection, and halt production. To see a list of features dependent on the Gateway name, click [here](appendix\reference-pages\system-name-usage-reference\system-name-usage-reference.md). |
| New Gateway Name | The name of the new Gateway. Requires "Override Gateway Name" to be enabled. |
### List of Restore Disabled Resources
The following is a list of affected resources and features when restoring a Gateway backup with the **Restore Disabled** option enabled:
* EAM Backup and Restore Tasks
* Projects
* Store and Forward Engines
* Audit Profiles
* Security Zones (Except the default Security Zone)
* API keys
* Device settings (AB CompactLogix Legacy, BACnet/IP as local device, and Programmable Device Simulator only)
* Device connections (AB CompactLogix Legacy, BACnet/IP, and Programmable Device Simulator only)
* Database Translator settings
* OPC connections (Ignition OPC UA and Kepware OPC UA only)
* Email settings (Classic SMPT)
* Outgoing Gateway Network connections
* Realtime Tag Providers (default and Sample_Tags)
* Remote Tag Providers
* Historians
* Alarm Journals
* Alarm Notification Profiles
* Alarm Rosters
* Alarm Pipelines (Pipelines will work if all associated components, including Email settings, Rosters, Notification Profiles, Security Profiles, Projecs, and Tag Provider, are reenabled)
* Alarm Scheduling (Holidays schedule only)
In Windows and Linux, you can use the command-line utility to restore a Gateway backup. To run the Command-line Utility, open a shell and enter the command below. Refer to the [Command-line Utility](platform\gateway\gateway-command-line-utility-gwcmd\gateway-command-line-utility-gwcmd.md) page for a complete list of '**gwcmd**' options.
gwcmd -s C:\Backups\Ignition\IgnitionBackup.gwbk
