--- title: "Gateway Network Diagram" --- # Gateway Network Diagram > ![Gateway Network Diagram Overview](gateway-network-diagram-overview.png) ## Gateway Network Diagram Overview The **Gateway Network Diagram** is a visual representation of your Gateway Network. You can access the diagram by going to **Network** > **Overview**. ### Gateway Network Diagram User Interface To navigate the diagram, you can use your mouse's left-click to pan around and your mouse's scroll wheel to zoom in or out. Additionally, you can drag and rearrange different nodes as you like. There are also different buttons on the diagram interface that may be helpful: ![Gateway Network Diagram User Interface](gateway-network-diagram-user-interface.png) | Icon | Element | Description | |:---:|---|---| | ![Filter Box](filter-box.png) | Filter box | Filters by Gateway name. You can use comma-delimited Gateway names so that multiple Gateways show through the filter. | | ![Export Live Diagram as JSON](export-live-diagram-as-json.png) | Export Live Diagram as JSON | Downloads the Gateway Network Diagram as a JSON file. | | ![Take Screenshot](take-screenshot.png) | Take screenshot | Takes a screenshot of the currently displayed Gateway Network Diagram. | | ![Use Dagre Layout](use-dagre-layout.png) | Use dagre layout | Displays the Gateway Network Diagram in a dagre, or top-down layout, from the perspective of the local Gateway. | | ![Use Circular Layout](use-circular-layout.png) | Use circular layout | Displays the Gateway Network Diagram in a circular layout, with the center being the local Gateway. | | ![Zoom In](zoom-in.png) | Zoom in | Zooms into the Gateway Network Diagram. | | ![Zoom out](zoom-out.png) | Zoom out | Zooms out of the Gateway Network Diagram. | | ![Reset Zoom and Center](reset-zoom-and-center.png) | Reset zoom and center | Resets the camera panning and zoom and centers the Gateway Network Diagram. | | ![Open in New Tab](open-in-new-tab.png) | Open in new tab | Opens the Gateway Network Diagram in a new, separate tab. | | ![Refresh Chart](refresh-chart.png) | Refresh chart | Refreshes the Gateway Network Diagram so that the most recent Gateway Network configuration is shown. | ## Gateway Network Diagram Details ### Live Diagram Icons The following table shows each Gateway Network Diagram icon and its description. | Icon | Description | |:---:|---| | ![Local Node Standard Edition](local-node-standard-edition.png) | The local node from which you are viewing the Gateway Network Diagram. This icon's orange color also indicates that the node is running Standard Edition. | | ![Gateway Node Standard Edition](gateway-node-standard-edition.png) | The Gateway node that the local Gateway is connected to. This icon's orange color also indicates that the connected node is running Standard Edition. | | ![Local Node Edge](local-node-edge.png) | The local node from which you are viewing the Gateway Network Diagram. This icon's green color also indicates that the node is running Edge Edition. | | ![Gateway Node Edge](gateway-node-edge.png) | The Gateway node that the local Gateway is connected to. This icon's green color also indicates that the connected node is running Edge Edition. | | ![Local Node Maker Edition](local-node-maker-edition.png) | The local node from which you are viewing the Gateway Network Diagram. The icon's multicolor also indicates that the node is running Maker Edition. | | ![Gateway Node Maker Edition](gateway-node-maker-edition.png) | The Gateway node that the local Gateway is connected to. The icon's multicolor also indicates that the connected node is running Maker Edition. | | ![Local Node Cloud Edition](local-node-cloud-edition.png) | The local node from which you are viewing the Gateway Network Diagram. The icon's blue color also indicates that the node is running Cloud Edition. | | ![Gateway Node Cloud Edition](gateway-node-cloud-edition.png) | The Gateway node that the local Gateway is connected to. The icon's blue color also indicates that the connected node is running Cloud Edition. | ### Connection Details You can find out more information about each node and connection by clicking on them in the diagram. For example, clicking on the connection itself will display information such as: * The connection's origin * The connection's target destination * Connection status * Ping time in milliseconds * Whether the connection is using SSL * How many times the connection has faulted ![Connection Details Node Running](connection-details-node-running.png) If the connection is in another state besides **Running**, the Diagram will update accordingly: ![Connection Details Node Stopped](connection-details-node-stopped.png) ### Gateway Nodes On the other hand, clicking on the Gateway node itself will display information such as: * Gateway Name * Network Address * Version * Edition ![Gateway Nodes](gateway-nodes.png) ### Redundancy Representation If two Gateways are part of a redundant pair, the diagram will show each Gateway node with an orange circle around it. In addition to the Gateway Name, Network Address, Version, and Edition, the Gateway Node will also display the **Gateway's role** in the redundant pair: ![Redundancy Representation](redundancy-representation.png) ### Proxy Connections The Gateway Network Diagram will also display proxy connections differently. Instead of a green arrow indicating status and direction, the connection will be grey with no direction indicator. Clicking on a proxy connection will give the following information: * The status of the server * Whether or not the two Gateways are using a Proxy connection * Which Gateway the proxy is routed through * The proxy connection's target Gateway ![Proxy Connections](proxy-connections.png)
