--- title: "JDBC Driver and Database Translator Settings" description: "This page details various JDBC driver and translator settings." --- # JDBC Driver and Database Translator Settings > This page details various JDBC driver and translator settings. This page details various JDBC driver and translator settings. See the [JDBC Drivers and Translators page](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-drivers-and-translators.md#add-a-new-jdbc-driver) for information on adding and configuring JDBC drivers and translators. The settings listed below can be found by expanding the three dots menu for the driver, and selecting **Edit**, which displays the driver properties on an Edit panel. Note that the driver names are included in the property tables below, even though the names are only displayed in the title of the Edit panel and not as an editable property. You must select the **Rename** option to update the name of any driver. A new menu option, **Manage JAR Files**, was added in version 8.3.2. This means that although the JAR File(s) property is also included in the tables below, it can only be viewed and edited by selecting the **Manage JAR Files** option. Note that prior to 8.3.2, the JAR File(s) property is available to view and change in the Edit panel. Select **Delete** to remove a JDBC driver from your Gateway. ![](three-dot-menu-options.png) ## IBM ### IBM Default JDBC Driver Settings #### General Properties |Property|Value| |---|---| |Name|IBM DB2| |Description|The official IBM DB2 JDBC Driver.| |Classname|com.ibm.db2.jcc.DB2Driver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|DB2| |URL Format|jdbc:db2://localhost:50000/SAMPLEORjdbc:db2://localhost:25000/SAMPLE| |URL Instructions|The format of the DB2 connect URL is:db2://**host**:**port**/**database**With the three parameters (in bold)**host**: The host name or IP address of the database server.**port**: The port that the database server is running on. DB2 default port is **50000**.**database**: The name of the logical database that you are connecting to on the DB2 server.| |Default Connection Properties|Blank| |Connection Properties Instructions|Blank| |Default Validation Query|select 1 from sysibm.sysdummy1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use. Default: IBM DB2| ### IBM Default Translator Settings #### General Properties |Property|Value| |---|---| |Name|(Name of the Translator. The JDBC driver will reference the settings below by the name specified here)| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} GENERATED ALWAYS AS IDENTITY PRIMARY KEY`| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|Blank| |Limit Syntax|`FETCH FIRST {limit} ROWS ONLY`| |Limit Position|Back| |Current Timestamp Query|The value's current timestamp.| |Column Quote Character|"| |Supports Returning Auto-generated Keys?|False| |Fetch Key Query|`SELECT max({columnname}) FROM {tablename}`| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|timestamp| |Float (R4)|float| |Double (R8)|double| |String|varchar(255)| |Binary|blob| |Long Text|clob(65536)| ## MariaDB ### MariaDB Default JDBC Driver Settings #### General Properties |Property|Value| |---|---| |Name|MariaDB| |Description|The MariaDB (a community-owned fork of MySQL) JDBC Driver - compatible with all MariaDB servers, MySQL 5.x (>= 5.5.3) and MySQL 8.0.| |Classname|org.mariadb.jdbc.Driver| |JAR File(s)|Click on the **Choose File** button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|MySQL| |URL Format|jdbc:mariadb://localhost:3306/test| |URL Instructions|The format of the MariaDB connect URL is:jdbc:mariadb://**host**:**port**/**database**With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. MariaDB default port is **3306**.**database**: The name of the logical database that you are connecting to on the MariaDB server.| |Default Connection Properties|connectTimeout=120000;socketTimeout=120000;rewriteBatchedStatements=true;| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|MySQL| ### MariaDB Default Translator Settings Refer to the [MySQL Default Translator Settings](#mysql-default-translator-settings) as the MariaDB JDBC Driver uses MySQL Translator. ## MySQL ### MySQL Default JDBC Driver Settings #### General Properties |Property|Value| |---|---| |Name|MySQL| |Description|The official MySQL JDBC Driver, Connector/J.| |Classname|com.mysql.cj.jdbc.Driver| |JAR File(s)|Click on the **Choose File** button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|MySQL| |URL Format|jdbc:mysql://localhost:3306/test| |URL Instructions|The format of the MySQL connect URL is:jdbc:mysql://**host**:**port**/**database**With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. MySQL default port is **3306**.**database**: The name of the logical database that you are connecting to on the MySQL server.| |Default Connection Properties|zeroDateTimeBehavior=CONVERT_TO_NULL;connectTimeout=120000;socketTimeout=120000;useSSL=false;allowPublicKeyRetrieval=true;| |Connection Properties Instructions|There is an extensive list of extra connection properties available for MySQL Connector/J. See [the documentation](https://dev.mysql.com/doc/connectors/en/connector-j-reference-configuration-properties/) for a table describing all connection properties.A default `serverTimezone` value (taken from the Gateway) will be appended to the connection string if one is not specified.| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|MySQL| ### MySQL Default Translator Settings #### General Properties |Property|Value| |---|---| |Name|MySQL| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} NOT NULL AUTO_INCREMENT`| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`LIMIT {limit}`| |Limit Position|Back| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|`| |Supports Returning Auto-generated Keys?|True| |Fetch Key Query|Blank| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|datetime| |Float (R4)|float(10)| |Double (R8)|double| |String|varchar(255)| |Binary|varbinary| |Long Text|text| ## MSSQL ### MSSQL Default JDBC Driver Settings #### General Properties |Property|Value| |---|---| |Name|(Name of the driver, as you would like it to appear on the Gateway)| |Description|Enter a useful description you would like to see next to the driver.| |Classname|com.microsoft.sqlserver.jdbc.SQLServerDriver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|Microsoft SQL Server| |URL Format|jdbc:sqlserver://localhost\SQLEXPRESS| |URL Instructions|The format of the SQL Server connect URL is:jdbc:sqlserver:// **host** \ **instanceName** [:**port**] With the three parameters (in bold) **host**: The host name or IP address of the database server.**instanceName**: (optional) the instance to connect to on the host. If not specified, a connection to the default instance is made.**port**: (optional) the port to connect to. The default is **1433**. If you are using the default, you can omit the port and the preceding `:`. For SQL Server, you specify the **database name** to connect to using the `databaseName` property in the **Extra Connection Properties**.| |Default Connection Properties|databaseName=test| |Connection Properties Instructions|Use `databaseName=YOUR_DATABASE` to specify the database to connect to.| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use.| ### MSSQL Default Translator Settings #### General Properties |Property|Value| |---|---| |Name|Name of the Translator. The JDBC driver will reference the settings below by the name specified here.| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} IDENTITY(1,1)`| |Alter Table Syntax|`ALTER TABLE {tablename} ADD {alterdef}`| |Add Column Syntax|`{columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY CLUSTERED ({columnname})`| |Limit Syntax|`TOP {limit}`| |Limit Position|Front| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|"| |Supports Returning Auto-generated Keys?|True| |Fetch Key Query|Blank| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| \Long (I8)|bigint| |Boolean|int| |Datetime|datetime| |Float (R4)|float(10)| |Double (R8)|double precision| |String|varchar(255)| |Binary|varbinary| |Long Text|nvarchar(max)| ## Oracle Express ### Oracle Express Default JDBC Driver Settings #### General Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|oracle.jdbc.driver.OracleDriver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|Oracle| |URL Format|jdbc:oracle:thin:@localhost:1521:test| |URL Instructions|The format of the Oracle connect URL is:jdbc:oracle:thin:@ **host** : **port** : **SID** With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. Oracle's default port is **1521**.**SID**: the system ID that identifies the database to connect to.| |Default Connection Properties|Blank| |Connection Properties Instructions|Blank| |Default Validation Query|SELECT 1 FROM DUAL| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use.| ### Oracle Express Default Translator Settings #### General Properties |Property|Value| |---|---| |Name|Name of the Translator. The JDBC driver will reference the settings below by the name specified here| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|`CREATE SEQUENCE {tablename}seq START WITH 1 INCREMENT BY 1`| |Create Trigger Syntax|`CREATE TRIGGER {tablename}trig BEFORE INSERT ON {tablename} REFERENCING NEW AS NEW FOR EACH ROW BEGIN select {tablename}seq.nextval INTO :NEW.{columnname} FROM dual; END;`| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} NOT NULL`| |Alter Table Syntax|`ALTER TABLE {tablename} ADD ({alterdef})`| |Add Column Syntax|`{columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`rownum<={limit}`| |Limit Position|Wrap| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP FROM DUAL`| |Column Quote Character|"| |Supports Returning Auto-generated Keys?|False| |Fetch Key Query|`SELECT {tablename}SEQ.CURRVAL FROM DUAL`| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|int| |Boolean|int| |Datetime|timestamp| |Float (R4)|float| |Double (R8)|double precision| |String|varchar2(255)| |Binary|varbinary| |Long Text|nclob| ## PostgreSQL ### PostgreSQL Default JDBC Driver Settings #### General Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|org.postgresql.Driver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|PostgreSQL| |URL Format|jdbc:postgresql://localhost:5432/test| |URL Instructions|The format of the PostgreSQL connect URL is:jdbc:postgresql://**host**:**port**/**database**With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. PostgreSQL default port is **5432**.**database**: The name of the logical database that you are connecting to on the PostgreSQL server.| |Default Connection Properties|Blank| |Connection Properties Instructions|No extra connection parameters are recommended for PostgreSQL. For possible parameter values, see the documentation at the [PostgreSQL JDBC driver website](http://jdbc.postgresql.org).| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use. | ### PostgreSQL Default Translator Settings #### General Properties |Property|Value| |---|---| |Name|Name of the Translator. The JDBC driver will reference the settings below by the name specified here| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|SERIAL NOT NULL| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`LIMIT {limit}`| |Limit Position|Back| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|"| Supports Returning Auto-generated Keys?|True| |Fetch Key Query|Blank| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|timestamp| |Float (R4)|float| |Double (R8)|double precision| |String|varchar(255)| |Binary|bytea| |Long Text|text| ## Snowflake ### Snowflake Default JDBC Driver Settings :::note Many of the fields for the Snowflake JDBC driver can be left blank if your custom Snowflake translator is set up properly and referenced in the "Default Translator" field. ::: Due to security updates in Java 17, Snowflake JDBC drivers may not interact correctly with Ignition. This can be fixed by adding the following Java argument to the [Gateway Configuration File](appendix\reference-pages\gateway-configuration-file-reference\gateway-configuration-file-reference.md#changing-java-additional-parameters): ``` wrapper.java.additional.1=--add-opens=java.base/java.nio=ALL-UNNAMED ``` See the official [Snowflake Knowledge Base](https://community.snowflake.com/s/article/JDBC-Driver-Compatibility-Issue-With-JDK-16-and-Later) for more information about this issue. #### General Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|net.snowflake.client.jdbc.SnowflakeDriver| |JAR File(s)|Click on the **Choose File** button to select and upload the JAR(s).| #### Driver & Default Instructions |Property|Value| |---|---| |Driver Type|Generic| |URL Format|Blank| |URL Instructions|Blank| |Default Connection Properties|Blank| |Connection Properties Instructions|Blank| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|Your custom Snowflake Translator.| ### Snowflake Default Translator Settings :::note If you have a database table called "NO_OP_TABLE", you should use a different table name for the "Create Index Syntax" field. ::: #### General Properties |Property|Value| |---|---| |Name|Name of the translator, as you would like it to appear on the Gateway.| |Create Table Syntax|`CREATE TABLE IF NOT EXISTS {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|`CREATE SEQUENCE IF NOT EXISTS {tablename}seq`| |Create Trigger Syntax|Blank| |Create Index Syntax|`ALTER TABLE IF EXISTS NO_OP_TABLE SET COMMENT='no-op table due to forced value for TRANSLATORS > ALTER TABLE SYNTAX;`| |Auto Increment Field Definition|`{type} NOT NULL AUTOINCREMENT`| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`LIMIT {limit}`| |Limit Position|Back| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|Blank| |Supports Returning Auto-generated Keys?|False| |Fetch Key Query|`SELECT NEXT_VALUE FROM INFORMATION_SCHEMA.SEQUENCES WHERE SEQUENCE_NAME='{tablename}'`| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|datetime| |Float (R4)|float| |Double (R8)|double| |String|string| |Binary|binary| |Long Text|text| :::note In addition to a custom JDBC driver and custom translator, you may need to also configure the `Connection Initialization Commands` property in your Snowflake [database connection](platform\database-connections\database-connections.md) to properly store Tag History. Add the following values to the `Connection Initialization Commands` property: * USE DATABASE ignition_db * USE SCHEMA ignition_db.time_series :::
