--- title: "JDBC Drivers and Translators" description: "There are cases where drivers or translators may need modification." --- # JDBC Drivers and Translators > There are cases where drivers or translators may need modification. In most cases, the default JDBC drivers and Translator settings in Ignition will not need to be modified. However, there are cases where existing drivers or translators may need modification. Additionally, you may need to install new drivers to connect to your desired database. More information on the default JDBC Driver modules included with the Ignition installation can be found [here](ignition-modules/jdbc-drivers/jdbc-drivers.md). ## JDBC Drivers and Ignition Upgrades When upgrading Ignition, manually created JDBC drivers are **not** modified during the upgrade process. This is to prevent database connection issues on upgrade. You should only need to upgrade your JDBC drivers when the database is updated, not when Ignition is upgraded. In addition, restoring a Gateway backup from an older version will replace any new versions of the drivers with the versions from the backup. In this case, you will need to [update the JDBC drivers](#upgrade-a-jdbc-driver). If you need to see what JAR files are currently included in your Gateway configuration, you can view them by navigating to the **Connections** > **Databases** > **Settings** page on the Gateway and selecting Edit under the three dots menu for each JDBC driver, or locating them in the file system within the `/data/config/resources/core/ignition/database-driver` folder. Refer to the [JDBC Drivers](ignition-modules/jdbc-drivers/jdbc-drivers.md#configurations-and-upgrades) page for the upgrade process for the drivers shipped with Ignition. ### Common Third Party Drivers If you need to install a new driver, you will most likely have to download the official JAR file from the creator's website. The table below describes this process for common third-party drivers. Note that MySQL and MSSQL will be both be available already upon install, so you'll only need to follow the steps for these types if you need to override the existing driver files. |Database|Link|Notes| |---|---|---| |IBM DB2|https://www.ibm.com/support/pages/db2-jdbc-driver-versions-and-downloads|Select the GA version of your desired driver.Select your desired package.Log in to your IBM account and complete your package download.| |MySQL|https://dev.mysql.com/downloads/connector/j/|Select Your Operating system (or **Platform Independent** if you are on Windows).After the file has been downloaded, unzip the the archive. On Windows you can right-click and select the **Extract All** option.The location of the JAR we need should be in the extracted folder under **mysql-connector-java-X.X.XX** where the Xs are the version number. You are looking for a file that is named like **mysql-connector-java-X.X.XX.jar.** Compatibility with different JRE versions can be found in the [MySQL connector docs](https://dev.mysql.com/doc/connector-j/en/connector-j-versions.html).| |MSSQL|https://github.com/microsoft/mssql-jdbc/releases|You only need the .jar file, so you can select just the **mssql-jdbc-X.X.XX.jreX.jar** file. The Xs will be replaced with the version numbers of both the jdbc driver and jre used.Check the [SQL Server docs](https://learn.microsoft.com/en-us/sql/connect/jdbc/system-requirements-for-the-jdbc-driver?view=sql-server-ver15) for more details which jdbc drivers contain jre versions compatible with your Ignition server's embedded Java version.| |Oracle|https://www.oracle.com/technetwork/database/application-development/jdbc/downloads/index.html|You will need to create an Oracle account to download the JAR files.You can select the Unzipped version of the newest JAR.You are looking for a file that is named like **odbcX.jar**. Where X is the version number.| ## Database Translator and JDBC Driver Settings When adding your own JDBC driver or configuring a Translator, be sure to check the JDBC driver's documentation for information on how to configure them. The [JDBC Driver and Database Translator Settings](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-driver-and-database-translator-settings.md) page contains some recommended settings, but the vendor's documentation should always supersede any suggestions here. ## Add a New JDBC Driver Ignition comes pre-configured with select JDBC drivers already. In some cases you may only need to provide a JAR file by editing an existing driver configuration, instead of creating a new driver configuration. To add a new JDBC driver to Ignition, complete the following steps: 1. On the Gateway Webpage **Connections** section, click on **Databases > Settings**. ![" "](jdbc-drivers.png) The Database Settings page is displayed. 2. On the Drivers tab, click on **Create JDBC Driver +** at the top right of the JDBC Drivers list. ![" "](jdbc-drivers-create-new-driver.png) 3. In the **Name** field, type the full name of the JDBC driver, see the manufacturer's documentation to get the name. 4. In the **Classname** field, enter the JDBC driver classname for the JAR file you will be uploading. :::note JAR Files Note The process for uploading JAR files was updated in version 8.3.2. If you are adding a new JDBC driver in an earlier 8.3 version, you'll also need to upload your JAR file to the JAR File field within the General properties listing here. Additionally, steps 7-10 will not be applicable. ::: 5. Use the default settings for the following properties: **Driver and Defaults Instructions** Driver Type Is the brand of database. This is used for optimizations in the Gateway, if in doubt, select GENERIC. URL Format Is a default value for the connect URL. This provides a hint to the format of the connect URL that this driver requires while adding a datasource connection. For example, the hint for the format can be, `jdbc:dbtype://host:port/database`. URL Instructions Free form instructions that are shown to help the user to create a connection. Default Connection Properties Any additional properties to add by default to the connection string. Connection Properties Instructions Tips about which connection properties might be useful. Default Validation Query The default query that is used to verify that the connection is available. **SQL Language Compatibility** Default Translator The database translator that is used by default for connections from this driver. 6. Click **Create JDBC Driver** located at the bottom of the form to create the new driver. 7. The new driver resource will now appear on the JDBC Drivers list. When you see it, expand the three dots menu and select **Manage JAR Files**. 8. Click the **Choose File** button to add the JAR file that will upload the JDBC driver. :::note Large JAR Files The default size limit has been changed from 20 MB to 128 MB to allow larger JDBC drivers to be uploaded. If your driver exceeds this size, increase the `max-file-size` in the `web.xml` file and restart the Gateway. See the [Web XML File Reference](appendix/reference-pages/web-xml-file-reference/web-xml-file-reference.md#servlet-and-servlet-mapping) page for more information. ::: 9. Once you have selected the file, and then click **Open**. 10. Select **Save Changes** on the bottom of the Manage JAR Files panel. ## Upgrade a JDBC Driver In some cases you may need to upgrade a driver. The steps below detail where this would take place: 1. You will need to obtain the new driver. These are typically provided by the same organization that made the database. The driver will be a JAR file. 2. Once you have the new driver, head to your Ignition Gateway's **Connections** section, click on **Databases > Settings**. 3. The Database Settings page will open and display the currently configured JDBC drivers. Click the three dots menu ![](three-dot.png) icon and select **Manage JAR Files** for the driver you need to upgrade. :::note Manage JAR Files Option Added in 8.3.2 If you are upgrading a JDBC driver in version 8.3.0 or 8.3.1, you'll need to select **Edit** from the three dots menu to choose a new JAR file. Additionally, step 6 is not applicable for these versions. ::: 4. Click the **Choose File** button under JAR File(s). 5. Navigate to the file location in your File Explorer, and then click **Open**. 6. Click **Remove** for the existing JAR file listed. 7. Select **Save Changes** on the Manage JAR Files panel. In some cases you may need to update other properties when a new driver is in place. This depends on the driver and what it changes. Refer to the driver's documentation to determine if any connection properties need to be changed. If further changes are required, open the **Edit** panel from the three dots menu. Be sure to save your changes when done. Note that if the driver name needs updating, you must select the **Rename** option. ## Database Translators Despite the presence of a SQL standard, many database systems vary in how they implement or accomplish various tasks. The JDBC driver system tries to hide these differences as much as possible, but unfortunately some differences persist. The database translator system in Ignition navigates these differences as applicable. It provides a way to define certain key operations that are commonly different between database vendors, such as creating auto-incrementing index columns, and the keywords used for different data types. #### Translator Management Database translators are managed in the Gateway from the **Connections > Databases > Settings** page on the **Translators** tab. Ignition comes pre-configured with translators for the major supported databases, but you can edit and remove them, as well as create new translators. It is necessary to create a new translator only when adding a new JDBC driver for a database that does not share syntax with any of the existing translators. #### Creating a New Translator To add a new database translator to Ignition, complete the following steps: 1. In the Gateway Connections section, click on **Databases > Settings**. The Database Settings page is displayed. 2. Go to the **Translators** tab and click **Create Translator +**. The Create Translator form pops up to show all of the translator properties. 3. Define the tokens used with the translator properties on the Create Translator form. For most of the properties, you need to define special token markers to indicate places where other values are placed. For example, the default **Create Table Syntax** entry looks as follows: ```CREATE TABLE {tablename} ({creationdef}{primarykeydef})``` Where: `tablename`, `creationdef`, and `primarykeydef` are all tokens that are expanded. `tablename` is replaced directly with the table, `creationdef` is a list of columns, and `primarykeydef` is the phrase created by the **Primary Key Syntax** entry in the translator. The possible tokens are as follows: |Token|Description| |---|---| |`tablename`|The name of the table being created.| |`indexname`|The name of the index to create, when adding a column index to the table.| |`primarykeydef`|A clause that defines a primary key for a new table.| |`creationdef`|The list of columns to create in the table.| |`alterdef`|A list of columns to add/remove/modify in the table.| |`columnname`|The name of a column.| |`type`|The data type of a column.| |`limit`|The value of the limit clause.| #### Other Properties |Token|Description| |---|---| |Limit Position|Defines where the limit clause should be placed. **Back**, the limit is placed at the end of the query. **Front**, places it directly after the SELECT keyword.| |Column Quote Character|All columns are created and accessed with the defined quote, which tells the database to use a specific casing, as well as avoiding collisions between the column name and database keywords.| |Supports Returning Auto-generated Keys?/Fetch Key Query|Indicates whether the JDBC driver supports the return of generated keys. If the driver does not support this feature, the **Fetch Key Query** is used to retrieve the last key.| #### Date Type Mapping |Token|Description| |---|---| |All data types|The keywords that are used when creating columns of the given types.| 4. Click **Create Translator** located at the bottom of the form to create the translator.
