--- title: "Connecting to Microsoft SQL Server Express" description: "This guide helps you with any difficulties you may have in getting the correct settings and parameters when connecting Ignition to Microsoft SQL Serverv" --- # Connecting to Microsoft SQL Server Express > This guide helps you with any difficulties you may have in getting the correct settings and parameters when connecting Ignition to Microsoft SQL Serverv ## SQL Server Connection Requirements In order to get connected to SQL Server, you must have a Translator, a Driver, and a Connection. The Translator and Driver only needs to be installed once, and after that you can make as many connections as you want to any compatible SQL Server databases. :::note When you Upgrade Ignition, any existing drivers are carried over. This means only a fresh install of Ignition will not have a SQL Server Connector. ::: ## Connect to Microsoft SQL Server 1. On the Gateway Webpage, go to the **Connections** section. 2. Select **Databases > Connections**. ![" "](mssql-databases-connections.png) 3. The Database Connections page is displayed. Click **Create Database Connection +**. 4. Select the **Microsoft SQLServer** JDBC Driver, and click **Next**. ![" "](mssql-driver.png) 5. On the **Database Connections** page, enter the following information: - Name: **SQLServer** - Connect URL: **jdbc:sqlserver://localhost\SQLEXPRESS** :::note We are connecting to the express edition of SQL Server using the default instance name. If you have the full SQL Server with default settings, replace SQLEXPRESS with the instance name of your SQL Server installation. Non-express versions of SQL Server tend to use MSSQLSERVER as a default instance name. ::: - username: **sa** - password: **sqlserver** (password is what you entered during the SQL Server installation. For this example, password is **sqlserver**) ![" "](mssql-main-settings.png) 6. At the bottom of the form, click on **Create New Database Connection**. Your connection is now created. The Database Connections page is displayed and will show the status of Reconnecting, then Valid. ## Microsoft SQL Server Connection Guide This guide helps you with any difficulties you may have in getting the correct settings and parameters when connecting Ignition to Microsoft SQL Server, a popular and robust relational database. ### Multiple Instances of Database Microsoft SQL Server supports multiple instances of the database running concurrently on the same computer. Each instance has its own name and set of system and user databases that are not shared between instances. Applications, such as Ignition, can connect to each instance on a computer in much the same way they connect to databases running on different computers. By default, each instance gets assigned a dynamic TCP/IP port on startup that listens for any incoming requests. Since the port is dynamic and the application does not know what the new port is, it must connect using the instance name. So if the communication is over TCP/IP and the application knows the instance name, how does the application find which port to communicate to? The answer is the **Microsoft SQL Server Browser** service. The Microsoft SQL Server Browser program runs as a Windows service and listens for all incoming requests for resources and provides information, such as the TCP/IP port, about each instance installed on the computer. Microsoft SQL Server Browser also contributes to these two actions: browsing a list of available servers and connecting to the correct server instance. If the Microsoft SQL Server Browser service is not running, you can still connect to SQL Server if you provide the correct port number. For example, you can connect to the default instance of SQL Server with TCP/IP if it is running on port 1433. ### Check 1: Make Sure the Database has TCP/IP Enabled Ignition connects using TCP/IP, therefore make sure your database has TCP/IP enabled. 1. Open the SQL Server Configuration Manager from **Start > All Programs > Microsoft SQL Server Version # > Configuration Tools > SQL Server Configuration Manager.** The Sql Server Configuration Manager window is displayed. 2. To see all the instances set up on that machine, expand **SQL Server Network Configuration**. 3. Find the database (or instance) you plan on using. To the right, all of the protocols the database supports are shown. Find the **TCP/IP** protocol and select it. ![" "](mssql-network-config.png) 4. Make sure the **Status** next to TCP/IP is **Enabled**. If not, double-click **TCP/IP** and choose **Yes** from the drop-down next to Enabled and click **OK**. ![" "](mssql-tcp-ip-props.png) ### Check 2: Make Sure Microsoft SQL Server Browser is Running If you ARE connecting to your database using a NAMED INSTANCE, you must make sure that the Microsoft SQL Server Browser is running. As mentioned earlier, the Microsoft SQL Server Browser translates the instance name to a TCP/IP port in order for Ignition to connect to it. 1. Open the **SQL Server Configuration Manager** from **Start > All Programs > Microsoft SQL Server Version # > Configuration Tools > SQL Server Configuration Manager.** 2. Select the **SQL Server Services** section. 3. On the right, see all of the services installed. One of the services is **SQL Server Browser**. Make sure this service is in fact running. If the service is not running, right-click and select **Start**. :::note The service could be disabled, so you may need to double-click it to enable the service before starting it up. ::: ![" "](mssql-run-service.png) ### Check 3: Make Sure There is a Database Created If you are connecting to an existing SQL Server installation, you only need to know the name of the database and you can skip this step. In newer versions of SQL Server, a fresh installation does not include a database so you must first create a new database. 1. Open the **SQL Server Management Studio** program. This program was an option when you installed SQL Server. 2. Log into the Management Studio using either SQL Server Authentication or Windows Authentication. 3. In the **Object Explorer** (on the left), expand the instance folder to find the **Databases** folder. The instances folder is usually expanded by default. 4. Right Click on the **Databases** folder and select the **New Database...** option. 5. Type in a Database Name. 6. Click the OK button in the lower right. You can then expand the **Databases** folder in the Object Explorer to see the new database. If it doesn't show up right away you can right-click to refresh. **Security** - Make your user a db_owner of the new database. 7. In the Object Explorer, expand to the **Security > Logins** folder, right click on your username, and select **Properties**. 8. In the **User Mapping** page click the checkbox next to your new database, then click the **db_owner** checkbox below. 9. Click OK. Now your user has access to a database. ## Different Ways of Connecting to SQL Server Now that you have ensured that TCP/IP is enables and the Microsoft SQL Server Browser is running, you can connect to Microsoft SQL Server in four different ways (all using TCP/IP communication) as follows: 1. Connect using an Instance Name and SQL Authentication. 2. Connect using an Instance Name and Windows Authentication (this is the most common method). 3. Connect using a Port and SQL Authentication. 4. Connect using a Port and Windows Authentication. ### Scenario 1: Connect By Using an Instance Name and SQL Authentication By default, Microsoft SQL Server only allows Windows authentication since it is more secure. But because we are using SQL authentication, we must enable Microsoft SQL to allow this type of authentication. #### Enable SQL Authentication 1. Open the **Microsoft SQL Server Management Studio** window from **Start > All Programs > Microsoft SQL Server Version # > SQL Server Management Studio.** The window is displayed showing connections to your database. 2. Right-click the top-level database in the **Object Explorer** and select **Properties**. ![" "](mssql-manager.png) 3. From the Server Properties window, on the left side, select **Security**. ![" "](mssql-security.png) 4. Verify that **SQL Server and Windows Authentication** mode is selected. If not, select it and click **OK** Now you need to restart the **SQL Server Windows** service so that this setting takes effect. 5. Open the **SQL Server Configuration Manager** at **Start > All Programs > Microsoft SQL Server Version # > Configuration Tools > SQL Server Configuration Manager.** 6. Select the **SQL Server Services** section and restart the **SQL Server (Instance Name)** item. ![" "](mssql-restart-service.png) Now that Microsoft SQL Server accepts SQL authentication, we can configure Ignition. #### Configure the Database Connection in Ignition 1. Log into the Ignition Gateway and access the Connections page from your web browser. 2. Select **Databases > Connections**. 3. Click on **Create Database Connection +**. 4. Select **Microsoft SQL Server JDBC Driver** and click **Next**. ![" "](mssql-driver.png) 5. In the **New Database Connection** window, enter the following information: - Name: **YourDatabaseConnectionName** (no spaces) - Connect URL: **jdbc:sqlserver://Hostname\InstanceName** - **Hostname** is your databases IP address or hostname and **InstanceName** is your databases instance name, for example: - **jdbc:sqlserver://localhost\SQLEXPRESS** - **jdbc:sqlserver://10.10.1.5\MSSQLSERVER** 6. Set the username and password to a valid SQL authentication user. For example, sa is the default administrator account you can use. ![" "](mssql-main-settings.png) 7. To add your own user account, open the SQL Server Management Studio and expand the **Security > Logins** folder. You will see all the current logins including **sa** and you can add a new login. 1. To add a new login, right-click on the **Logins** folder and click **New Login....** The **Login** window is displayed. 2. Choose the **SQL Server authentication** mode and type in a Login name and password. :::note You will also have to add permissions to your database by mapping db_datareader and db_datawriter to the new user in the User Mapping section of the Login window. If you want Ignition to be able to create tables (ie: for Tag History), you also need to give table creation access such as db_owner. ::: 8. Go back to the **Create Database Connection** page in the Gateway, enter the name of your database, for example, in the **Extra Connection Properties** enter: **databaseName=test** (replace **test** with your database name, not the instance name). 9. Click **Create Database Connection**. The Database Connection page is displayed showing the Status as **Valid** after a couple of seconds. If the connection is **Faulted**, check the Database Connection Status to find out why. Typically, the username/password is incorrect or the user doesn't have the right permissions. ### Scenario 2: Connect By Using Instance Name and Windows Authentication In Windows authentication mode, the username and password used to connect comes from the Ignition Windows Service logon. By default, the Ignition Windows Service is set to local system account which usually doesn't have privileges to connect. #### Set Up the Service to Use Windows Authentication 1. Download a copy of the [SQL Server JDBC driver](https://learn.microsoft.com/en-us/sql/connect/jdbc/download-microsoft-jdbc-driver-for-sql-server?view=sql-server-ver15). Specifically, download a ZIP or tar.gz file (NOT an installer), as you will need to extract a specific file and relocate it to the Gateway's installation directory. The exact version required depends on the version of Java your Gateway is using. Ignition 8.3 uses Java 17. :::caution Although, it's recommended you use the most recent driver available for your system, make sure the version of the JDBC Driver Ignition is using matches the downloaded DLL file. Your current driver version can be seen in the following directory: %IgnitionInstallationDirecotry%\temp\jdbc ::: 2. Locate the DLL file from the correct architecture folder ("x64" for 64-bit JDBC) inside of the enu/auth folders in the zip file. 3. Copy the DLL file to the **lib** folder in your install directory. If you have the default install directory, it's in the following location: `C:\Program Files\Inductive Automation\Ignition\lib\core\gateway` :::note File Considerations * Older versions of the JDBC driver (such as version 7.2.1) need this file to be renamed to `sqljdbc_auth.dll` before Ignition can utilize the file. In more modern versions of the driver, this is no longer the case. * The path `C:\Program Files\Inductive Automation\Ignition\lib\core\gateway` doesn't survive upgrades. However, keeping the file in `C:\Program Files\Inductive Automation\Ignition\lib` will persist through upgrades. ::: 4. The account used to connect will be the account that Ignition is running under in the services menu. To set up Ignition to logon using the right Windows account, open the **Services Control Panel** from Start > Control Panel > Administrative Tools > Services 5. Right-click the **Ignition** service (or whatever service name your Ignition installation is using) and choose **Properties**. 6. Select the **Log On** tab. 7. Choose the **This account** radio button and enter in your Windows username and password. 8. Click **OK** to save. 9. Now restart the Ignition service to make this change take effect. Click the **Action > Restart** button in the menubar to restart the Ignition service (or your can stop and start from the right-click menu). #### Configure the Database Connection in Ignition 1. Go to and login to the Ignition Gateway Config page from your webbrowser at http://hostname:8088/main/web/config/ 2. Select **Databases > Connections** from the menu. 3. Click on **Create new Database Connection**. 4. Select **Microsoft SQL Server** JDBC Driver and click **Next**. ![" "](mssql-driver.png) 5. On the **New Database Connection** page, enter the following information: - Name: **YourDatabaseConnectionName** (no spaces) - Connect URL: **jdbc:sqlserver://Hostname\InstanceName** - **Hostname** is your databases IP address or hostname and **InstanceName** is your databases instance name, for example: - **jdbc:sqlserver://localhost\SQLEXPRESS** - **jdbc:sqlserver://10.10.1.5\MSSQLSERVER** - **username**: leave blank - **password**: None - Extra Connection Properties: **databaseName=test; integratedSecurity=true**; (replace test with your database name) ![" "](mssql-integrated-security-true.png) 6. Click on **Create Database Connection**. The Status should be Valid after a couple of seconds. Again, if the connection is Faulted, check the Database Connection Status to find out why. ### Scenario 3: Connect By Using Port and SQL Authentication 1. Connecting by using a port and SQL authentication is just like scenario 1 above except you specify a port instead of the instance name in the **Create Database Connection** page. 2. Enter the following: - Connect URL: **jdbc:sqlserver://Hostname:Port** - **Hostname** is your databases IP address or hostname and **Port** is your databases TCP/IP port (SQLSERVER default port is 1433), for example: - **jdbc:sqlserver://localhost:1433** - **jdbc:sqlserver://10.10.1.5:1433** ### Scenario 4: Connect By Using Port and Windows Authentication Connecting by using a port and Windows authentication is just like scenario 2 above except you specify a port instead of the instance name in the **New Database Connection** page. Don't forget to download the sqljdbc_auth.dll file if you need it. Enter the following: - Connect URL: **jdbc:sqlserver://Hostname:Port** - **Hostname** is your databases IP address or hostname and **Port** is your databases TCP/IP port (SQLSERVER default port is 1433), for example: - **jdbc:sqlserver://localhost:1433** - **jdbc:sqlserver://10.10.1.5:1433** ## Troubleshooting ### TCP/IP Communication Not Enabled SQL Server requires that you explicitly turn on TCP connectivity. To do this, use the SQL Server Configuration Manager, located in the **Start** menu under **Microsoft SQL Server > Configuration Tools**. Under **SQL Server Network Configuration**, select your instance, and then enable TCP/IP in the panel to the right. You need to restart the server for the change to take affect. ### Window Firewall When connecting remotely, make sure that Windows Firewall is disabled, or set up to allow the necessary ports. Normally ports 1434 and 1433 must be open for TCP traffic, but other ports may be required based on configuration. ### SQL Server Browser Process Not Running To connect to a named instance, the **SQL Server Browser** service must be running. It is occasionally disabled by default, so you need to verify that the service is not only running, but set to start automatically on bootup. The service can be found in the Windows Service Manager (**Control Panel > Administrative Tools > Services**). ### Mixed Mode Authentication Not Enabled Unless selected during setup, **mixed mode** or **SQL authentication** is not enabled by default. This mode of authentication is the **username/password** scheme that most users are used to. When not enabled, SQL Server only allows connections using Windows Authentication. Due to the ease of using SQL Authentication over Windows Authentication, we recommend enabling this option and defining a user account for Ignition. 1. To enable this, open the SQL Server Management Studio. 2. Connect to the server. 3. Right click on the instance and select **Properties**. 4. Under **Security**, select **SQL Sever and Windows Authentication mode**. ### TLS/Security An update starting in Java 8 disables TLS 1.0 and 1.1, which may affect your connection to an MSSQL database. The [Support](https://support.inductiveautomation.com/hc/en-us) department has written a [guide on how to resolve this issue](https://support.inductiveautomation.com/hc/en-us/articles/4417310204813-TLS-v1-0-and-v1-1-Microsoft-SQL-Server-Database-connection-issue). ## JDBC Drivers and Translators In some cases, you may need to add your own JDBC Driver, or configure a Translator. More information on configuring these can be found on the [JDBC Drivers and Translators](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-drivers-and-translators.md) page. However, you may need to check the JDBC driver's documentation for information on how to configure them. If you are using a more recent JDBC driver such as 10.2 or 11.2, you will need to add the following argument to the extra connection properties: **trustServerCertificate=true**. This will allow the transport layer to use SSL to encrypt the channel and bypass going through the certificate chain to validate trust.
