--- title: "Ignition Cloud Edition" description: "A cloud architecture-based version of Ignition." --- # Ignition Cloud Edition > A cloud architecture-based version of Ignition. **Ignition Cloud Edition** is a cloud architecture-based version of Ignition. Unlike standard Ignition and Ignition Edge, which are available as installable software on [Inductive Automation's downloads](https://inductiveautomation.com/downloads/) page, Cloud Edition is available through major cloud computing marketplaces such as **Amazon Web Services (AWS)**. Besides distribution, there are other key differences that distinguish Cloud Edition from standard Ignition or Edge, such as [device connectivity](#device-connectivity) and [module granularity](#module-granularity). ## Purchasing and Licensing Unlike previous versions of Ignition, Cloud Edition is purchased through cloud marketplaces and not through Inductive Automation. Cloud Edition will instead detect that it is running in a paid image or container, and therefore already be licensed, negating needing to apply a license key to the Gateway. In addition to the existing Cloud Edition image, Cloud Edition is available as a container product on the AWS Marketplace, deployable through Amazon Elastic Kubernetes Service (EKS). The container product follows the same usage-based billing model as the image, with pricing determined by three factors, all of which are billed by the hour: * A base rate * The number of CPU cores detected * The amount of heap memory used in gigabytes The CPU and memory factors reflect the resource limits applied to the container when running on Amazon Elastic Kubernetes Service (EKS). The costs for these limits are listed on the Cloud Edition Container pricing page, and the limits themselves can be found on the container's Diagnostics Overview page. When the container is started with a Gateway backup restore, the Gateway runs as Cloud Edition regardless of the edition associated with the backup. ## AWS Partner Solutions AWS offers automated reference deployments called Partner Solutions. There are two Partner Solutions available: * Standalone * Cluster Both of these Partner Solutions have already been configured with regards to security, Gateway connections, and database connectivity. See the [Ignition by Inductive Automation on AWS](https://aws.amazon.com/solutions/partners/inductive-automation-ignition/) reference page for more information. ## Core Functionality ### Cloud Connectors With Cloud Edition comes a new type of module called **Cloud Connectors**. These new modules are more focused on cloud infrastructure rather than locally installed software. The section below details the various Cloud Connectors available for Cloud Edition. | Cloud Connector | Description | |:---:|---| | ![MongoDB Module Logo](mongodb-module-logo.png) **MongoDB** | The [MongoDB Connector module](ignition-modules\cloud-connector-modules\mongodb\mongodb.md) allows Cloud Edition to connect to a MongoDB NoSQL database deployment. Several MongoDB Cloud Connector features include: Taking aggregates from document dataInserting, replacing, and deleting collection dataA MongoDB Perspective binding type | | ![Kafka Module Logo](kafka-module-logo.png) **Kafka** | The [Kafka Connector module](ignition-modules/cloud-connector-modules/kafka/kafka.md) allows you to process data in real time. With Kafka, you can produce or consume events using [event streams](ignition-modules\event-streams\event-streams.md). | ### Redundancy Two Cloud Edition Gateways can be set up with redundancy. Cloud Edition Gateways will only be able to failover to another Cloud Edition Gateway. It is recommended to set up redundancy between two Cloud Edition Gateways in different Availability Zones in case one Availability Zone fails. ### Module Offerings Cloud Edition comes standard with many of Inductive Automation's most popular modules, with the main exception being the Vision module. The nature of Cloud Edition makes Perspective's web-based visualization system more suitable for cloud-based infrastructure and helps mitigate potential security risks. The modules that are generally included in Cloud Edition are listed in the table below. For the EKS container product, the listed modules are enabled and running by default. :::note IA modules that are not included with Cloud Edition cannot be licensed. Third party modules can still be added and licensed on Cloud Edition platforms. ::: | Module Name | Description | |---|---| | Alarm Notification | Provides alarm notifications via email. | | Cirrus Link MQTT Distributor | Add an MQTT server that allows MQTT clients to connect to, publish, and subscribe to data. | | Cirrus Link MQTT Engine | Adds bidirectional communication with edge-of-network devices through an MQTT server. | | Cirrus Link MQTT Transmission | Publish data from edge of network Tag change events as MQTT messages. | | EAM | Manage many Gateways from a central Gateway. | | Event Streams | Provides source and handler combinations to receive, filter, and transform event-driven data. | | Historian | Adds powerful time-series historian functionality. | | Kafka Connector | A module enabling communication with Kafka. | | MongoDB Connector | Allows you to connect to non-relational, NoSQL databases. | | OPC UA | Provides OPC UA server and OPC UA client functionality. Device drivers are not included in Cloud Edition's OPC-UA module. | | Perspective | A module that provides modern, responsive HTML based graphical interfaces for Ignition projects. | | Reporting | Adds reporting capability. | | SFC | Sequential Function Charts are customizable logic execution environments. | | SQL Bridge | An OPC-to-SQL data logger and transaction manager. | | SQL Historian | Enables time-series historian functionality to SQL databases. | | Symbol Factory | Includes almost 4000 Scalable Vector Graphics (SVGs), making designing projects easier and smoother. | | Twilio Notification | Send SMS or voice alarm notifications without a physical device. | | Web Dev | Allows you to create and serve basic web resources and respond to web requests through scripting.| ## Ignition Cloud Edition Compared with Ignition Since Ignition Cloud Edition is more focused on cloud architecture compared to the standard version of Ignition, there are some features that differ in Cloud Edition compared to standard Ignition. The following sections detail some of these differences. ### Device Connectivity Cloud Edition does not include any industrial device drivers to connect directly to PLCs. For security reasons, it is architecturally inadvisable to connect to a PLC or industrial device from a cloud infrastructure. However, MQTT tools are available to publish device telemetry to Cloud Edition. ### Module Granularity Unlike a standard version of Ignition where you choose which modules you want to include, Cloud Edition comes with a packaged set of modules. See the [Module Offerings section](#module-offerings) for more information. ### Availability and Commissioning Since Cloud Edition will be available through major cloud computing platforms, this means that Cloud Edition will not appear as an option in the normal commissioning process during which users select which version of Ignition they are working with. ## Cloud Edition Gateway In a Cloud Edition installation, there are visual changes to the Gateway, with some pages being different or removed. For example, one of the visual changes include blue Cloud Edition logos instead of traditional orange Ignition logos. See the [Cloud Edition Gateway](other-editions\ignition-cloud-edition\cloud-edition-gateway\cloud-edition-gateway.md) page for more information. ## Cloud Edition Behavior with Ubuntu Starting in Ubuntu 24.04, the `unattended-upgrades` package is enabled by default, with the `needrestart` utility configured to automatically restart services when a related package is patched. If you are running Cloud Edition on an Ubuntu 24.04+ virtual machine, Ignition will be included with these services, causing it to automatically restart if the `needrestart` utility's requirements are met. While this behavior comes default with Ubuntu, users can opt out by following the steps below to add an exception to the `needrestart` utility. 1. Navigate to `/etc/needrestart/needrestart.conf` in the file system. 2. Add `qr(^ignition\service$) => 0` to the `$nrconf{override_rc}` section. 3. Save the file.
