--- title: "New in this Version 📣" --- # New in this Version 📣 > Over the course of development, naturally there are changes and additions to the Ignition software. This page highlights any new functionality or modified behavior, but is not meant as a complete resource for new features. You can find more about these items by following the links on this page. ### Determining Your Current Version The current version of Ignition can be viewed by visiting the Welcome page of the Gateway. 1. Navigate to your Gateway and select the Home tab to view the Welcome page. 1. Locate the Gateway Version under the Gateway Overview section on the Welcome page. :::note You must be logged in with [Read or Write Permissions](platform/security/gateway-general-security-settings/gateway-general-security-settings.md#roles-and-permissions) to see this section. If you aren't prompted to log in, you can select the **Log In** option in the upper right-hand corner of the screen. ::: ![](img1.png) ### Upgrading Ignition Upgrading Ignition is easy, but there are a few things we recommend to ensure everything goes smoothly. See the [Installing and Upgrading](getting-started\installing-and-upgrading\installing-and-upgrading.md) page for a complete guide. ## New Ignition Perspective Mobile App Features This section is devoted to new features introduced to the [Ignition Perspective Mobile App](ignition-modules\perspective\perspective-sessions\ignition-perspective-app\ignition-perspective-app.md). New versions of the app are released separately from new Ignition versions, so notable changes to the app will be listed in this section. ## New Ignition Features This section is devoted to new features introduced to Ignition. Any pages in this user manual that contain features that were added will be accompanied by a display like this: ## New in 8.3.9 ### BACnet * Added a new [system property](appendix\reference-pages\gateway-configuration-file-reference\gateway-and-gateway-network-parameters\gateway-and-gateway-network-parameters.md#bacnet) that controls whether or not BACnet devices will perform concurrent manifest reads. ### Docker * Added a new [runtime argument](platform/advanced-deployments/docker-image/docker-image.md#options) to restore local-only configuration files from a Gateway backup. ### Embedded Java * Updated the Java Service Wrapper from version 3.5.60 to version 3.6.5. ### Enterprise Administration Module (EAM) * Users can now [upgrade](ignition-modules\enterprise-administration\agent-management\remote-upgrade\remote-upgrade.md) multiple remote agents simultaneously. ### Gateway * The [Redundancy page](platform/ignition-redundancy/ignition-redundancy.md#redundancy-page-overview) is now accessible to users with read permissions. * Added a new [system property](appendix\reference-pages\gateway-configuration-file-reference\gateway-and-gateway-network-parameters\gateway-and-gateway-network-parameters.md#automatic-remote-procedure-call-gzip) that allows users to opt out of automatically gzipped remote procedure calls between the Designer, Vision Client, and Gateway. * Added a new [system property](appendix\reference-pages\gateway-configuration-file-reference\gateway-and-gateway-network-parameters\gateway-and-gateway-network-parameters.md#iec-61850-openssl-library) that allows users to choose whether the IEC 61850 driver will use the module-bundled OpenSSL libraries, or the host system's OpenSSL libraries. * Updated the [max-file-size](appendix/reference-pages/web-xml-file-reference/web-xml-file-reference.md#servlet-and-servlet-mapping) property's default value from 20 MB to 128 MB to allow larger JDBC drivers to be uploaded. ### OPC UA * Updated the Eclipse Milo OPC UA library to version 1.1.6, which now requires a [`ConfigureAdmin` or `SecurityAdmin` role to enable server diagnostics](ignition-modules/opc-ua/opc-ua-connections/opc-ua-connections.md#granting-configureadmin-or-securityadmin-roles). * Added [Sampling tags](ignition-modules\opc-ua\opc-ua-drivers\opc-ua-drivers.md#sampling-tags) to track metrics for the Siemens Enhanced driver. * Updated [IEC 61850](ignition-modules/opc-ua/opc-ua-drivers/iec-61850-driver/iec-61850-driver.md#iec-61850-hierarchical-data-model) addressing so that attributes shared by multiple Functional Constraints (FCs) are exposed as separate OPC nodes with an `[FC]` suffix. Tags on affected addresses must be re-addressed after upgrading. ### Scripting * Updated the parameter syntax for the [system.historian.queryAggregatedPoints](appendix\scripting-functions\system-historian\system-historian-queryAggregatedPoints.md), [system.historian.queryRawPoints](appendix\scripting-functions\system-historian\system-historian-queryRawPoints.md), and [system.historian.browse](appendix\scripting-functions\system-historian\system-historian-browse.md) functions. ### Tag Browser * Added an [Alarm Metrics folder](platform/tags/tag-properties/tag-alarm-properties/tag-alarm-properties.md#runtime-alarm-metrics-properties) at the tag provider level to the Tag Browser. * Added the [List of Names](platform\tags\user-defined-types-udts\udt-multi-instance-wizard\udt-multi-instance-wizard.md#create-instances) Pattern Type that was removed in 8.3.0 back into the Multi-Instance Wizard. ## New in 8.3.8 ### Event Streams * Icons have been added in the Project Browser for [event streams](ignition-modules/event-streams/event-streams.md#project-browser-status-icons) to indicate running, modified, disabled, and failed statuses. ### Gateway * Added an optional [Restore from Backup](getting-started/installing-and-upgrading/installing-and-upgrading.md#install-ignition) step to the Ignition installer, allowing a user to restore a Gateway backup on new installations. * The active [deployment mode](platform/gateway/web-interface/platform/gateway-deployment-modes/gateway-deployment-modes.md) will now be logged during Gateway startup. * Disabled redundant [automatic backup](appendix/reference-pages/gateway-xml-file-reference/gateway-xml-file-reference.md) and [VACUUM](appendix/reference-pages/gateway-configuration-file-reference/gateway-and-gateway-network-parameters/gateway-and-gateway-network-parameters.md#internal-database-vacuum-operation) operations on the internal database to improve Gateway startup performance. * Larger text boxes on the Gateway Webpage, such as description fields, can now be vertically resized. ### Historian * Added a [Number of past partitions queried for seed values](ignition-modules/tag-historian/tag-history-providers/tag-history-providers.md#data-partitioning) setting to control how many partitions are searched when finding a seed value. ### Perspective * The Form component's [Dropdown widget](appendix/components/perspective-components/perspective-input-palette/perspective-form/perspective-form.md#dropdown) now includes the same `search`, `showClearIcon`, and `allowCustomOptions` properties that the Dropdown component has. * Added a [File Upload](appendix/components/perspective-components/perspective-input-palette/perspective-form/perspective-form.md#file-upload) widget to the Form component for selecting and uploading files. ### Scripting * Updated Ignition's Jython version from 2.7.3 to 2.7.4. * Added a new [system.config](appendix\scripting-functions\system-config\system-config.md) namespace that allows users to copy, create, delete, move, rename, replace, and retrieve Gateway resource configurations. * Added three new system.secrets functions that allow users to create configurations for secrets to use with relevant Gateway resources. * [system.secrets.createEmbeddedSecretConfig()](appendix\scripting-functions\system-secrets\system-secrets-createEmbeddedSecretConfig.md) * [system.secrets.createReferencedSecretConfig()](appendix\scripting-functions\system-secrets\system-secrets-createReferencedSecretConfig.md) * [system.secrets.readConfiguredSecretValue()](appendix\scripting-functions\system-secrets\system-secrets-readConfiguredSecretValue.md) ### Sequential Function Charts (SFC) * Added Insert Tag, Operators, and Functions buttons and support for Ignition's expression language to an SFC's [Parallel Element](ignition-modules\sequential-function-charts\SFC-elements\SFC-elements.md#parallel-element) Cancel Condition. ## New in 8.3.7 ### Alarming * Added a [Consolidation](ignition-modules/alarm-notification/notification-profile-types/simple-one-way-email-notification-profile/simple-one-way-email-notification-profile.md#consolidation) section to Simple One-Way Email Notification Profiles to allow configuration for consolidating multiple alarms into single notifications. * Reconnection attempts to [Twlio accounts](ignition-modules\alarm-notification\notification-profile-types\twilio-notification-profiles\twilio-notification-profiles.md#define-a-twilio-account) are now automatic if the connection fails immediately after being configured. ### Designer * Updated the [-Dignition.designer.websocketMaxBinaryMessageSize](appendix\reference-pages\gateway-configuration-file-reference\gateway-configuration-file-reference.md#designer-parameters) system property's default value to 4096 KB from 2048 KB. ### OPC UA * Added the ability to [export PLC symbols](ignition-modules\opc-ua\opc-ua-drivers\siemens\siemens-enhanced-driver\siemens-enhanced-driver.md#device-settings) from Siemens Enhanced Driver connections that are using symbolic addressing. ### Perspective * Added the ability to use expressions as dynamic [Query Binding](ignition-modules\perspective\working-with-perspective-components\bindings-in-perspective\query-bindings-in-perspective.md#binding-properties) paths for Perspective components. ### Sequential Function Charts (SFC) * Updated the SFC Element Properties panel when an [element is selected](ignition-modules/sequential-function-charts/SFC-elements/SFC-elements.md) to include a dedicated Notes tab for Transitions, Parallels, Actions, Assertions, and Enclosings. ### Security * Deprecated the [Create Project Permission](versioned_docs/version-deprecated/platform/security/create-project-permission/create-project-permission.md) setting from the Gateway **Platform** > **Security** > **General Settings** page. ### User Sources * Added a Legacy Naming Enabled property to the [Active Directory](platform/security/classic-authentication-strategy/active-directory-authentication/active-directory-authentication.md#ldap-search-properties), [AD/Database Hybrid](platform/security/classic-authentication-strategy/ad-database-hybrid/ad-database-hybrid.md#advanced-ad-properties), and [AD/Internal Hybrid](platform/security/classic-authentication-strategy/ad-internal-hybrid/ad-internal-hybrid.md#advanced-properties) User Sources to improve migration during upgrades from 8.1. ## New in 8.3.6 Ignition version 8.3.6 only contains a patch for an issue found in 8.3.5. ## New in 8.3.5 ### Cloud Edition * Ignition Cloud Edition is now available as a [container product](other-editions/ignition-cloud-edition/ignition-cloud-edition.md#purchasing-and-licensing) on the AWS Marketplace, deployable through Amazon Elastic Kubernetes Service (EKS). ### Docker * Added `jq` utility to the [Docker image](platform/advanced-deployments/docker-image/docker-image.md) to parse and manipulate JSON configuration files. ### Event Streams * Updated the test controls functionality and added a [Ready](ignition-modules\event-streams\event-streams.md#testing-your-event-stream) state for event stream stages. * Added a [previousValue](ignition-modules/event-streams/types-of-sources/source-data-and-metadata/source-data-and-metadata.md#tag-event) object to the Tag Event source metadata to display previous tag values. * Added an [`HTTP Version`](ignition-modules/event-streams/types-of-handlers/types-of-handlers.md#http) property to specify whether HTTP/1.1 or HTTP/2 should be used for HTTP handler requests. ### Gateway Network * Added the [Remote Gateways](platform\gateway-network\connections-gateway-network\connections-gateway-network.md#remote-gateways-tab) tab on the Gateway Network Connections webpage. ### Leased Licensing * Leased license [activation tokens](platform/licensing-and-activation/leased-licensing/leased-licensing.md) will now still be accepted even when the token is pasted into the Activation Token field wrapped in quotes. ### OPC UA * Added a [GDS Push Enabled](ignition-modules\opc-ua\ignitions-opc-ua-server\ignitions-opc-ua-server.md#advanced) property to Ignition's OPC UA Server to allow an external Global Discovery Server (GDS) to manage the server's certificate and trust list. ### Perspective * Added an [`enabled`](appendix/components/perspective-components/perspective-input-palette/perspective-file-upload/perspective-file-upload.md#properties) parent property to the File Upload component. Corresponding `enabled` and `disabled` child properties have also been added to support functionality. * Added an [onElementClicked](appendix\components\perspective-components\perspective-display-palette\perspective-drawing\perspective-drawing-scripting\perspective-drawing-scripting.md#onelementclicked) component event for the Perspective Drawing component. * Added `enabled` and `style` properties under the `radios` property for the [Radio Group](appendix/components/perspective-components/perspective-input-palette/perspective-radio-group/perspective-radio-group.md#properties) component. * Updated the XY Chart [`series.line.appearance.bullets`](appendix/components/perspective-components/perspective-chart-palette/perspective-xy-chart/perspective-xy-chart.md#seriesx-properties) child properties to replace `height` and `width` with `radius` and added `label.truncate`, `label.hideOversized`, and `tooltip.getFillFromObject` properties. ### Scripting * Added a new parameter to [`system.tag.getConfiguration`](appendix/scripting-functions/system-tag/system-tag-getConfiguration.md#parameters) to return overridden properties from UDT members. * Added [system.historian.types.annotationPoint](appendix/scripting-functions/system-historian/types/system-historian-types-annotationPoint.md), [system.historian.types.dataPoint](appendix/scripting-functions/system-historian/types/system-historian-types-dataPoint.md), and [system.historian.types.metadataPoint](appendix/scripting-functions/system-historian/types/system-historian-types-metadataPoint.md) functions to support structured data creation for historian writes and accept type-based objects. ### Security * Added a [File Secret Provider](platform/security/secrets-management/secrets-management.md#file) that can access secrets from files on disk. ## New in 8.3.4 ### Gateway * Added a `route-actor` [Mapped Diagnostic Context (MDC) Key](platform/gateway/web-interface/diagnostics/diagnostics-logs/diagnostics-logs.md#mapped-diagnostics-context-keys) to Gateway log messages that originates from route API code paths. Depending on the access strategy used, the Key will include the username of the user, the API token name, and Client IP address pair, or the Security Zone names and Client IP address. * Improved filesystem resource collection management and added an [`ignition.resources.digest.pruning`](appendix/reference-pages/gateway-configuration-file-reference/gateway-and-gateway-network-parameters/gateway-and-gateway-network-parameters.md#resource-cache-file-management) system property to enable further maintenance of the resource directories. ### Gateway Network * Replaced the Gateway Network 60 second enumeration call with an [event-based system](platform\gateway-network\gateway-network.md#gateway-network-proxy-rules). ### Historian * Updated the Core Historian directory to include [server.conf and log.conf files](ignition-modules/tag-historian/tag-history-providers/internal-historian-questdb/internal-historian-questdb.md#customizing-server-settings), which increase flexibility and customization for the server configuration. ### JxBrowser * Upgraded JxBrowser to version 8.16.0 and added a new [ignition.jxBrowser.sandboxMode](appendix/reference-pages/gateway-configuration-file-reference/gateway-configuration-file-reference.md#jxbrowser-sandbox-on-linux) system property to control the Chromium sandbox on Linux. ### OPC UA * Replaced the Force Secure Connection property used by Siemens Enhanced drivers with [Secure Connection Mode](ignition-modules\opc-ua\opc-ua-drivers\siemens\siemens-enhanced-driver\siemens-enhanced-driver.md#advanced-settings) to allow for greater control when using TLS. ### Perspective * Added [typeAttr](appendix\components\perspective-components\perspective-display-palette\perspective-drawing\perspective-drawing.md#elements-properties) as an element property for the Drawing component. * Added a read-only currentBreakpoint property for the [Breakpoint](appendix\components\perspective-components\perspective-container-palette\perspective-breakpoint-container\perspective-breakpoint-container.md#properties) and [Column](appendix\components\perspective-components\perspective-container-palette\perspective-column-container\perspective-column-container.md#properties) containers. * The [Form component](appendix/components/perspective-components/perspective-input-palette/perspective-form/perspective-form.md) number type widget now supports using a value of `any` for step validation. ### Tags * Added Internal Indicator (IIN) [diagnostic tags](ignition-modules\opc-ua\opc-ua-drivers\opc-ua-drivers.md#root-diagnostic-tags) for the DNP3 and DNP3 (Legacy) drivers. * Wildcards can now be used to specify tag paths at both the folder level tag level when using the [Tag Event source](ignition-modules\event-streams\types-of-sources\types-of-sources.md#tag-event) and [Gateway Event Tag Change Scripts](platform/scripting/scripting-in-ignition/gateway-event-scripts/gateway-event-scripts.md#tag-change-scripts). ### User Sources * The upgrade process now detects [User Sources with duplicate users](getting-started/installing-and-upgrading/ignition-8-upgrade-guide/81to83-upgrade-guide.md#user-sources), logs the issues, and skips migration. ## New in 8.3.3 ### OPC UA * Updated the [Authentication property](/ignition-modules/opc-ua/opc-ua-connections/opc-ua-connections.md#opc-ua-client-connection-settings) for OPC UA connections to include Anonymous and Certificate types. * The OPC Quick Client is now available, allowing users to browse and test OPC UA items directly from the Gateway. * S7-1200 G2 PLCs are now supported for [Siemens Enhanced driver](ignition-modules/opc-ua/opc-ua-drivers/siemens/siemens-enhanced-driver/siemens-enhanced-driver.md) connections. ### Perspective * Updated Perspective to use the [Intl.NumberFormat](https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Intl/NumberFormat) object instead of the [Numeral.js](http://numeraljs.com/) library for better locale support. * Added [two new parameters](appendix/components/perspective-components/perspective-display-palette/perspective-table/perspective-table-scripting.md) to the Perspective Table component scripting events: `canceledValue` for the onEditCellCancel event and `originalValue` for the onEditCellCommit event. * Added a `color.disabled` property to the [Toggle Switch](appendix/components/perspective-components/perspective-input-palette/perspective-toggle-switch/perspective-toggle-switch.md#properties) component. ### Redundancy * General Gateway Network settings can now be modified on a backup Gateway to allow [disabled connections to reconnect](platform/ignition-redundancy/ignition-redundancy.md#node-communication). ### Reporting * Holding the Shift key while right-clicking on a report in the Project Browser will now display [two additional options](ignition-modules\reporting\report-designer-interface\report-designer-interface.md): Copy XML To Clipboard and Set XML From Clipboard. ### Scripting * Added `sizeCutoff` and `timeoutMs` parameters to the [system.kafka.pollPartition](appendix/scripting-functions/system-kafka/system-kafka-pollPartition.md) and [system.kafka.pollTopic](appendix/scripting-functions/system-kafka/system-kafka-pollTopic.md) system functions to control the amount of records returned when polling. ### SECS/GEM * The [SECS/GEM](/ignition-modules/secs-gem/secs-gem.md) pages are now available on the Gateway when the SECS/GEM module is installed. ### Security * Added the ability to [import 8.1 Gateway Identity Provider exports](platform/security/identity-provider-authentication-strategy/configuring-identity-providers/configuring-identity-providers.md#importexport-an-identity-provider) to 8.3 Gateways. * Added a [Remote Secret Provider](/platform/security/secrets-management/secrets-management.md#remote) that can access Secret Providers from another Gateway over the Gateway Network. ### Tags * Added a [deploymentMode](platform/tags/types-of-tags/system-tags/system-tags.md#root-system-tags) System Tag to display the Gateway's active deployment mode. ## New in 8.3.2 ### Drivers * Updated the Mitsubishi driver [Max Gap Size](ignition-modules/opc-ua/opc-ua-drivers/mitsubishi-tcp-driver/mitsubishi-tcp-driver.md#request-optimization) default to -1 for improved request optimization. ### Enterprise Administration * Updated the [Send Stats Interval](../ignition-modules/enterprise-administration/adding-an-agent/adding-an-agent.md#main) setting on agent Gateways from 30 seconds to 45 seconds. ### Event Streams * Added support for numeric quality codes for event stream [tag handlers](ignition-modules\event-streams\types-of-handlers\types-of-handlers.md#tag). * Users can now subscribe to Alarm Metrics in a [Tag Event source](ignition-modules/event-streams/types-of-sources/types-of-sources.md#tag-event). * Added a Tag Browser ![](icons/tag-browser.png) icon to the event stream [tag handler](ignition-modules/event-streams/types-of-handlers/types-of-handlers.md#tag) form to make adding tag paths easier. ### Gateway * Improved Gateway [System Name](/platform/gateway/web-interface/platform/gateway-settings/gateway-settings.md#gateway-settings) validation so that invalid names, such as those containing a \| character, will be rejected and fail to save. Non-ASCII Unicode and emoji characters are supported, but may cause rendering issues in certain areas. * [Quarantined Modules](getting-started\installing-and-upgrading\installing-or-upgrading-a-module.md#quarantined-modules) now have actions allowing users to either resolve the quarantine reason or delete the module from the Gateway. * Updated the 8.3 Gateway UI graphic assets and Quick Start menu to ensure contrast ratio and shape distinction accessibility standards are met. * Added [two new properties](platform/gateway-network/gateway-network.md#main) to the Gateway Network General Settings page to support the Gateway Network now using its own thread pool to process incoming messages. Users who have previously adjusted the [`gateway.maxThreads`](appendix/reference-pages/gateway-xml-file-reference/gateway-xml-file-reference.md#gateway-xml-properties) property found in the `gateway.xml` file, especially those using large Hub and Spoke Architectures, should now configure these settings instead. * Added a [**Manage JAR Files**](platform/database-connections/connecting-to-databases/jdbc-drivers-and-translators/jdbc-driver-and-database-translator-settings.md) option on the JDBC Drivers page to improve visibility and access to JAR files. * Added an [Identity Provider](platform/projects/project-settings/project-settings.md#security-settings) setting to configure the Identity Provider selection when creating a project. This addition matches the process already available when setting up projects in the Designer. ### Reporting * Improved [vector settings and print quality](ignition-modules/reporting/report-schedules/scheduling-actions/scheduling-actions.md#print-actions) for Report components using vector graphics. ### Security * A new Connect Timeout property has been added to [Active Directory](platform\security\classic-authentication-strategy\active-directory-authentication\active-directory-authentication.md#ldap-search-properties), [AD/Database Hybrid](platform\security\classic-authentication-strategy\ad-database-hybrid\ad-database-hybrid.md#advanced-ad-properties), and [AD/Internal Hybrid](platform\security\classic-authentication-strategy\ad-internal-hybrid\ad-internal-hybrid.md#advanced-properties) User Sources, allowing users to set a custom connection timeout for LDAP operations. ### Tags * Added a [Qualified Value](platform/tags/tag-event-scripts/tag-event-scripts.md#qualified-value) option to Tag Event Scripts, allowing scripts to run when a tag receives a qualified value update. ### Vision * Updated the [Resource Encoding](/ignition-modules/vision/vision-project-properties/vision-project-properties.md#data) project property to also include Vision Client tags when applying binary or XML serialization format. ## New in 8.3.1 ### Gateway * Users can now edit endpoints for overridden [OPC UA Connections](../ignition-modules/opc-ua/opc-ua-connections/opc-ua-connections.md) that are within different Gateway Deployment Modes. ### Launchers * Added support for JVM arguments in File Associations for Designers and Vision Clients. ### OPC UA * Users can now utilize the .getDescription() method when using [system.opc.browseServer](appendix\scripting-functions\system-opc\system-opc-browseServer.md) to retrieve [Documentation](platform\tags\tag-properties\tag-properties.md#meta-data-properties) meta data from [exposed tags](ignition-modules\opc-ua\ignitions-opc-ua-server\ignitions-opc-ua-server.md#advanced). * Added a new property allowing users to specify read and write [max holding register](ignition-modules\opc-ua\opc-ua-drivers\modbus\connecting-to-modbus-device\connecting-to-modbus-device.md#request-optimization) values independently of each other. * Added a [Timestamp Source](ignition-modules\opc-ua\opc-ua-connections\opc-ua-connections.md#advanced) property for OPC UA Connections. ### Perspective * Upgraded the Markdown library to v5.0.3 to address CVE-2020-7753 and improve the [Markdown component](/appendix/components/perspective-components/perspective-display-palette/perspective-markdown/perspective-markdown.md) functionality. * Added [keyboard shortcuts](appendix/components/perspective-components/perspective-display-palette/perspective-drawing/perspective-drawing.md#keyboard-shortcuts) (**F1-F10**) to the Drawing component's Drawing Editor for quickly switching tools. * Updated shortcut behavior to include the ⌘ (Command) key for macOS, and modified the ⌘ + Drag functionality to now pan instead of opening a right-click menu. ### Scripting * The PyOPCTag return object for [system.opc.browseServer](appendix\scripting-functions\system-opc\system-opc-browseServer.md#syntax) has been updated to include functionality that was already included in the OPCBrowseElement return object. * Added a new `PyPlaintext` class and [system.secrets](../appendix/scripting-functions/system-secrets/system-secrets.md) functions to interact with `SecretProviders` and the `SystemEncryptionService`. ### Security * Added [User Attribute Mapping](platform\security\identity-provider-authentication-strategy\configuring-identity-providers\user-attribute-mapping\user-attribute-mapping.md), [User Grants](platform\security\identity-provider-authentication-strategy\user-grants\user-grants.md), and [Security Levels](platform\security\identity-provider-authentication-strategy\security-levels\security-levels.md) to be configurable on overridden Identity Providers within mutable [collections](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md#collections). * Updated Netty library to version 4.1.127. ### Tags * Added the [Preserve Source Timestamp](platform\tags\tag-properties\tag-properties.md#value-properties) property to Derived tags. * Added an option to hide [Alarm Metrics](/platform/tags/tag-browser/tag-browser.md#display-alarm-metrics) within the Tag Browser. ### Vision * Added an [Auto-Redirect](/ignition-modules/vision/vision-project-properties/vision-project-properties.md#login-screen) option for Vision Clients using the Identity Provider strategy to skip the login steps when launching. ## New in 8.3.0 ### Alarming * The [Runtime Alarm Metric](platform/tags/tag-properties/tag-alarm-properties/tag-alarm-properties.md#runtime-alarm-metrics-properties) properties are now available at the folder level and for all UDT instances, along with an additional 15 aggregated alarm metric properties. * Added two new [tag alarm modes](platform\tags\tag-properties\tag-alarm-properties\tag-alarm-properties.md#alarm-mode-settings-properties), When True and When False. * Added Twilio [Voice](ignition-modules/alarm-notification/notification-profile-types/twilio-notification-profiles/twilio-voice-notification/twilio-voice-notification.md) and [WhatsApp](ignition-modules/alarm-notification/notification-profile-types/twilio-notification-profiles/twilio-whatsapp-notification/twilio-whatsapp-notification.md) Notification Profiles for the Twilio Notification module to allow more options for alarm acknowledgement. ### Designer * Added a [-Dignition.designer.websocketMaxBinaryMessageSize](appendix\reference-pages\gateway-configuration-file-reference\gateway-configuration-file-reference.md#designer-parameters) system property to adjust the maximum size of binary data that the websocket between the Designer and Gateway can handle. ### Docker * Improved Docker image support for third party modules, especially during container upgrades with the following: * Updated [module identifiers](platform/advanced-deployments/docker-image/docker-image.md#module-identifiers-table) to be fully qualified IDs. * Added two new [environment variables](appendix\reference-pages\platform-environment-variables\platform-environment-variables.md#environment-variables) to automate third party module acceptance across container lifecycle events. * Updated the [Docker image](platform/advanced-deployments/docker-image/docker-image.md) to be compatible with OpenShift 4 `restricted` Security Context Constraints. ### Drivers * Added a new [Siemens Enhanced driver](/ignition-modules/opc-ua/opc-ua-drivers/siemens/siemens.md) through the Siemens Enhanced Driver module that supports browsing and symbolic access when connected to S7-1200 and S7-1500 devices. * The [MariaDB, MSSQL, and PostgreSQL JDBC drivers](/ignition-modules/jdbc-drivers/jdbc-drivers.md) are now bundled with Ignition. ### Enterprise Administration Module (EAM) * Added the option to use [Leased Licenses (Eight-Character Keys)](platform/licensing-and-activation/leased-licensing/leased-licensing.md) for EAM license activation. ### Event Streams * [Event Streams](ignition-modules\event-streams\event-streams.md) are now available to use as project resources. ### Gateway * Added a [-Dignition.gateway.externalModulesFolder](appendix/reference-pages/gateway-configuration-file-reference/gateway-and-gateway-network-parameters/gateway-and-gateway-network-parameters.md#docker-image-external-modules-folder) system property to allow to specify an install folder location for external or third party modules. * Added two [system properties](appendix/reference-pages/gateway-configuration-file-reference/gateway-and-gateway-network-parameters/gateway-and-gateway-network-parameters.md#core-historian) that enable the ability to query the Core Historian directly using Postgres. * Added a new [banner](platform\gateway\web-interface\web-interface.md#banners) state to indicate when Gateway Restarts are required. * Added [Gateway Deployment Modes](platform\gateway\web-interface\platform\gateway-deployment-modes\gateway-deployment-modes.md) to allow Gateways to have different running environments. * Added a [reference page](appendix\reference-pages\gateway-folder-structure\gateway-folder-structure.md) for the Gateway's folder structure. * Added a new [OpenAPI](platform/gateway/openapi/openapi.md) documentation page at the `/openapi` endpoint, providing a dynamically generated specification of available HTTP API routes for external integration. * Updated the [Gateway sidebar navigation](platform/gateway/web-interface/web-interface.md#navigating-the-gateway), along with other interface changes, for improved usability and layout. * Added a [`-Dignition.gateway.rpcErrorDetailSuppression`](appendix/reference-pages/gateway-configuration-file-reference/gateway-and-gateway-network-parameters/gateway-and-gateway-network-parameters.md#detailed-exception-message-suppression) system property to filter error details from Clients and Designers as desired. * Added a [Permissions tab](ignition-modules/opc-ua/ignitions-opc-ua-server/ignitions-opc-ua-server.md#opc-ua-server-permissions) to the OPC UA Server Settings page to allow users to apply access levels to OPC UA devices and exposed Tag Providers. * Added an [environment variable](appendix\reference-pages\platform-environment-variables\platform-environment-variables.md#environment-variables) and [Gateway Network setting](../platform/gateway-network/gateway-network.md#main) to allow Java serialization as needed for upgrading 8.1 Gateways to 8.3. * Added a [Serialization Format](platform/gateway/web-interface/platform/gateway-settings/gateway-settings.md#script-message-encoding) setting to allow Java Serialization for messaging between Clients, Designer and the Gateway during upgrade. * Added a [Roles & Permissions](platform/security/gateway-general-security-settings/gateway-general-security-settings.md#roles-and-permissions) section to the Gateway **Platform** > **Security** > **General Settings** page. These settings enable access levels and permissions based on the current user role. ### Historian * Added the [Core Historian](ignition-modules\tag-historian\tag-history-providers\tag-history-providers.md#core-historian) as an additional historical provider option for time-series data. ### JxBrowser * Upgraded JxBrowser to 8.5.0. ### Launchers * Added [deep link and File Association](launchers-and-workstation/launchers-and-workstation.md#deep-link-and-file-association-support) support to the launchers to allow direct launching of targeted Gateways. * Updated [Launcher](launchers-and-workstation/launchers-and-workstation.md) supported architecture for Mac to Apple Silicon, x86 Mac is no longer supported. * Added a new [allow.uri.schemes](launchers-and-workstation/launcher-settings/launcher-settings.md#launcher-json-configuration-files) Launcher JSON setting to support direct access to applications from the operating system. ### OPC UA * Added support for GDS Push in Ignition's OPC UA server with a `gdsPushEnabled` property now available in the [OpenAPI](platform/gateway/openapi/openapi.md) under `IgnitionOpcUaServerConfig.Advanced`. When enabled, a user with the SecurityAdmin role is allowed to manage the server's certificates and trust lists via the ServerConfigurationObject and its associated methods. Note that the `SecurityAdmin` does not exist by default and will need to be created on the Gateway for this feature to function properly. ### Platform * The [gwcmd utility `-u` command](platform/gateway/gateway-command-line-utility-gwcmd/gateway-command-line-utility-gwcmd.md#command-line-utility-gwcmd-options) now supports unactivating supplemental license keys in addition to the primary license key. * Added the ability to [create Backup version configurations](platform/ignition-redundancy/setting-up-redundancy/setting-up-redundancy.md#create-a-backup-version-configuration) that will override master Gateway configurations in redundant pair setups. ### Perspective * Added a [Drawing](appendix/components/perspective-components/perspective-display-palette/perspective-drawing/perspective-drawing.md) component to create and configure SVG-based vector graphics directly within the Designer. * Added a [Form](appendix/components/perspective-components/perspective-input-palette/perspective-form/perspective-form.md) component to create and manage interactive forms with dynamic validation, submission handling, and custom scripting capabilities. * Added a [Form Submission](ignition-modules/perspective/scripting-in-perspective/perspective-session-events-scripts.md#form-submission) Session Event, allowing users to handle form submission, manage validation, and process form data within the Gateway. * Upgraded minimum browser versions required for [Perspective Sessions](/ignition-modules/perspective/perspective-sessions/perspective-sessions.md#browser-version-requirements). * Added a [Page Details](ignition-modules/perspective/perspective-sessions/perspective-sessions.md#session-status-popup) section to the Perspective Session Status Popup to display page counts, latency, and up time data. * Updated Perspective themes to now use APIs for overriding built-in themes or [creating new themes](/ignition-modules/perspective/styles/creating-and-using-custom-perspective-themes.md#creating-a-custom-theme) resources under the config-perspective-themes resource type. * Added [Offline Mode](ignition-modules/perspective/perspective-sessions/ignition-perspective-app/offline-mode/offline-mode.md) support in the Perspective App, allowing mobile users to continue interacting with cached project views and resources during periods of network disconnection. Offline Mode must be enabled in the Perspective Project Properties and is only available in the Perspective App. * Upgraded the react-pdf library to version 7.7.3. * The File Upload component will now only accept files smaller than 20 MB, regardless of the [fileSizeLimit](appendix\components\perspective-components\perspective-input-palette\perspective-file-upload\perspective-file-upload.md#properties) property. This can be increased using the max-file-size property within the [web.xml](appendix\reference-pages\web-xml-file-reference\web-xml-file-reference.md) file. ### Reporting * Added a [Radar Chart](appendix/components/report-design-components/report-design-chart-palette/report-component-radar-chart/report-component-radar-chart.md) component to the Reporting module. * Added a [hidden](appendix/components/report-design-components/report-design-object-palette/report-component-page-object/report-component-page-object.md#properties) property for the Page Object component to allow entire pages to be excluded from a report. * Images can now be added through [copy and paste](ignition-modules/reporting/report-design/images-in-reports/images-in-reports.md#copy-and-paste-images) in addition to the drag and drop method. * The following components can now be used as either raster or vector images: * [Barcode](appendix\components\report-design-components\report-design-display-palette\report-component-barcode\report-component-barcode.md) * [Bar Chart](appendix\components\report-design-components\report-design-chart-palette\report-component-bar-chart\report-component-bar-chart.md) * [Pie Chart](appendix\components\report-design-components\report-design-chart-palette\report-component-pie-chart\report-component-pie-chart.md) * [Radar Chart](appendix/components/report-design-components/report-design-chart-palette/report-component-radar-chart/report-component-radar-chart.md) * [Timeseries Chart](appendix\components\report-design-components\report-design-chart-palette\report-component-timeseries-chart\report-component-timeseries-chart.md) * [XY Chart](appendix\components\report-design-components\report-design-chart-palette\report-component-xy-chart\report-component-xy-chart.md) ### Redundancy * Added a [-Dignition.redundancy.syncMaxAttempts](/appendix/reference-pages/gateway-configuration-file-reference/gateway-and-gateway-network-parameters/gateway-and-gateway-network-parameters.md#max-sync-attempts) system property to set a limit on sync attempts for redundancy providers. ### Scripting * Improved [scripting autocompletion and hint](platform/scripting/scripting-in-ignition/scripting-in-ignition.md#system-functions-hints-and-autocomplete) details for system functions, including listing system library constants and identifying deprecated functions. * Migrated the [`system.serial`](/appendix/scripting-functions/system-serial/system-serial.md) scripting functions into the Ignition platform, and removed the Serial modules as they are no longer needed. * Added a [`system.db.execScalar`](appendix/scripting-functions/system-db/system-db-execScalar.md) scripting function to provide a way to execute scalar queries, compared to `system.db.execQuery`, which only executes select queries. ### Security * Extra LDAP attributes can now be defined for the [Active Directory](platform\security\classic-authentication-strategy\active-directory-authentication\active-directory-authentication.md#ldap-search-properties), [AD/Database Hybrid](platform\security\classic-authentication-strategy\ad-database-hybrid\ad-database-hybrid.md#advanced-ad-properties), and [AD/Internal Hybrid](platform\security\classic-authentication-strategy\ad-internal-hybrid\ad-internal-hybrid.md#advanced-properties) user sources. * Two additional properties for nested group membership lookup and group role attributes are now available for the [Active Directory](platform\security\classic-authentication-strategy\active-directory-authentication\active-directory-authentication.md#ldap-search-properties) user source. * Three new properties are now available for [Ignition Internal Authentication](platform\security\classic-authentication-strategy\internal-authentication\internal-authentication.md#password-policies-properties): * Prohibit Password * Prohibit Username * Maximum Consecutive Repeated Characters * The Administrator role is now automatically listed under the Authenticated/Roles [security level](platform\security\identity-provider-authentication-strategy\security-levels\security-levels.md#authenticatedroles) when installing a fresh Gateway. * Implemented a [Secrets Management system](platform/security/secrets-management/secrets-management.md) that provides support for encrypting secrets like credentials, API tokens, and private keys. The Secrets Management system also includes opt-in functionality for establishing a more secure system setup. ### System Functions * Updated syntax for system functions that are only scoped for the Vision Client to [system.vision](appendix/scripting-functions/system-vision/system-vision.md). This affected functions under system.dataset, system.db, system.file, system.gui, system.nav, system.net, system.print, system.security, system.tag, and system.util. * Deprecated `system.gui.convertPointToScreen` and `system.gui.getQuality`. * Reconfigured dataset scripting to automatically expose all datasets as PyDatasets. The function `system.dataset.toPyDataSet` has been deprecated with this change. * Replaced `system.db.clearAllNamedQueryCaches` and `system.db.clearNamedQueryCache` system functions with [system.db.clearQueryCache](appendix/scripting-functions/system-db/system-db-clearQueryCache.md). ### Tags * A new System tags folder called [ModuleVersions](platform/tags/types-of-tags/system-tags/system-tags.md#module-versions-folder) has been added for EAM controllers to monitor module versions on agents. * Two Memory tag [Value properties](/platform/tags/tag-properties/tag-properties.md#value-properties) have been added: **Default Value** and **Value Persistence** that determine Memory tag values on startup and storage behaviors. ### Vision * Vision Client settings now propagate on [retargets](ignition-modules/vision/vision-windows/navigation-strategies-in-vision/navigation-retargeting/navigation-retargeting.md) to preserve launch modes, screens, and more. * The [Web Browser](appendix/components/vision-components/misc/web-browser/web-browser.md) component is now included within the Vision module, and can now be found under the Misc category in the Designer Vision Components panel.
