title: "Vision Client Launcher"
# Vision Client Launcher
The Vision Client Launcher opens Vision Clients from an Ignition Gateway. Once your Vision projects are added to the Vision Client Launcher, they will be displayed under **My Applications** and organized by Gateway. This page describes the unique Vision Client Launcher settings, deploying the launcher, and Command Line Arguments.
The Vision Client Launcher is available under the **Home** section of the Gateway Webpage on the **Vision** > **Download** page. More information on installing any of the Launchers can be found on the [Launchers and Workstation](../launchers-and-workstation.md) page. For information on accessing Vision projects remotely, refer to the [Accessing Projects Remotely](tutorials\tutorials-and-helpful-tricks\accessing-projects-remotely.md) section.
## Vision Client Application Settings
This section details settings for applications in the Vision Client Launcher. To access the settings, click on the three dots menu on the **My Applications** window and select the **Manage** option. The General tab will open. The table below describes the settings that can be applied.
### Vision Client Launcher Application Settings
|Setting Name|Description|
|Application Name|The descriptive name of the application. This is independent of the project name that corresponds to a project on the Gateway. Instead, this is the name of the application as it is defined in the Launcher.|
|Gateway Address|The address to the Gateway in the format http[s]://host:port|
|Description| An optional description for the application that will be listed on the Application in the launcher. Defaults to the Project's description. |
|Vision Client Project |The name of the project containing Vision resources that the Application will attempt to launch. The Vision Client Project field is required.|
|Fallback Application |The name of the application (configured in the same launcher) to use if the number of retries has been exceeded. The fallback is only utilized if the **Retries** setting is greater than 0.|
|Image Path |This will allow the icon of the application to be set within the Designer and it will be downloaded and displayed as the icon for the application as well as the shortcuts. If no path is set, the default icon is used. If this is set to a different icon path, that icon will be used. The image path notation is a filepath on the local system.Supported image formats includes PNG, SVG, GIF, and JPEG files.|
|Window Mode |Controls the client mode. Available options are:`window`: Launches the client in Windowed Mode`fullscreen`: Launches the client in Fullscreen Mode|
|Screen Index|The screen index indicates which monitor to use.|
|Timeout|The maximum number of seconds to allow for any Gateway communication. Any communication that exceeds this amount will cause the Vision Client Launcher to abort the communication and try again if configured.|
|Retries|How many times to attempt to contact a Gateway again if an error occurred during communication. Available values are:-1 : Retry indefinitely, or until the launcher is manually closed.0 : Zero retries, or abort after the first failure.1 (or more): Determines the number of retries: i.e., a value of 5 means five retries. If the number of retries is exceeded, then the launcher will attempt to launch the Fallback Application.If the number of retries is exceeded, then the Launcher will attempt to launch the Fallback Application.|
|Init Heap| The initial heap memory size for the Client. |
|Max Heap| The maximum heap memory size for the Client. |
|JVM Arguments |Arguments to append to client startup. These should start with a `-D` and be separated by semi-colons.|
### Vision Client Tag Override Settings
Click on the **Client Tag Overrides** tab to create or update any tags. The table below shows the Client Tag Override setting that can be applied to each designer.
|Client Tag Overrides |Allows Client tags to be overridden on the Vision Client. These are set using the table on the application configuration screen by adding rows with the names of the tags and the corresponding values.When applying the overrides from command line, the tags must first be defined as launch parameters, then a value can be set on the parameters.Vision Client tag overrides within folders and passing Client tag overrides are supported by using a '+' icon as an escape character. This happens automatically if you are configuring overrides in the Client Launcher. To learn more about how to configure Client Tag Overrides, refer to [Overriding Vision Client Tags](../../ignition-modules/vision/vision-client-tags/vision-client-tags.md).|
For additional application settings, refer to the [Launchers and Workstation](../launchers-and-workstation.md) page.
## Redundancy
The Vision Client Launcher can take advantage of a redundant Gateway setup. Whenever a connection is established with a master Gateway, the backup Gateway IP address is automatically stored in the client launcher configuration file. If the master Gateway cannot be contacted the next time the client launcher is run, an attempt is made to contact the backup Gateway. If the backup cannot be contacted, the Client Launcher switches between contacting the primary Gateway and the backup Gateway until one responds or the user closes the launcher.
## Command Line/Terminal
Clients can be launched from the Client Launcher via command/terminal. When called in this way, many of the application properties may be overridden for the one call. The overrides use the same property names as noted in the [Application Property Reference Table](../deploying-pre-configured-launchers/deploying-pre-configured-launchers.md), under the "JSON name" column.
Windows:
"C:\ClientLauncher\visionclientlauncher.exe" application=myproject window.mode=window
Linux:
./visionclientlauncher.sh application=myterminal window.mode=fullscreen screen=0
The Vision Client Launcher must be installed and have an application added for the command line/terminal commands to work.There are a few important notes when using the command line/terminal to launch a project from the Vision Client Launcher.
* The **application** argument requires the application name in the Launcher, not the project name. You can open the launcher to determine what the application name is. Adding new applications in the launcher uses the Project title by default.
* Applications may contain spaces in their name. However, when launching from the command line/terminal, spaces should be escaped with **%20**. For example, if our application was named **my project**, then we could all it with the following:
"C:\ClientLauncher\visionclientlauncher.exe" application=my%20project
### Command Line Arguments
|Argument|Description|
|`application`|The name of the application to launch.|
|`window.mode`|Controls the Client mode. Available options are:`window`: Launches the Client in Windowed Mode`fullscreen`: Launches the Client in Fullscreen Mode|
|`screen`|The screen index indicates which monitor to use.|
|`fallback.application`|The name of the application to use if the number of retries has been exceeded. The fallback is only utilized if the **Retries** setting is greater than 0.|
|`timeout`|The maximum number of seconds to allow for any Gateway communication. Any communication that exceeds this amount will cause the Vision Client Launcher to abort the communication and try again if configured.|
|`retries`|How many times to attempt to contact a Gateway again if an error occurred during communication. Available values are:-1 : Retry indefinitely, or until the launcher is manually closed.0 : Zero retries, or abort after the first failure.1 (or more): Determines the number of retries: i.e., a value of 5 means five retries. If the number of retries is exceeded, then the launcher will attempt to launch the Fallback Application.If the number of retries is exceeded, then the launcher will attempt to launch the Fallback Application|
|`init.heap`|The initial heap size (memory) for the Client.|
|`max.heap`|The maximum heap size (memory) for the Client|
|`-Djavaws.launchparams`|Defines Client tags that can be overwritten upon launch. The use of this argument alone only defines the Client tags that will be overwritten. Setting a value on the tags can be done by an additional argument that utilizes the tag names delimited by a semicolon:// Establishes the tag names-Djavaws.launchparams="Tag1;Tag2"// Sets values on the tags-Djavaws.launchparams.Tag1=10-Djavaws.launchparams.Tag2=20//An actual call would look like:"C:\ClientLauncher\visionclientlauncher.exe" application=myproject -Djavaws.launchparams="Tag1;Tag2" -Djavaws.launchparam.Tag1=10 -Djavaws.launchparam.Tag2=20
|`config.json`|Allows you to point the launcher to a launcher configuration file from command line. Doing so will start running an instance of the launcher using the configurations in the file as temporary overrides. The argument expects a path to a JSON export file, specifically the same file that's created by the **Export Launcher Config** button under the launcher's **Settings** menu.`"C:\ClientLauncher\visionclientlauncher.exe" config.json="C:\Users\MyUser\Desktop\vision-client-launcher.json"`|
