title: "HTML in Vision"
# HTML in Vision
> HTML stands for HyperText Markup Language. It is commonly used to style text within web pages. The features that HTML brings to style web pages can be applied to many components within Ignition to style the text within components.
## Using HTML in Components
Many Vision components display a text string. By default, a component's text is displayed in a single font and color and will not wrap when its content exceeds the space the component has made available to the text. However, you can use HTML if you want to mix fonts or colors within the text or if you want formatting such as multiple lines. HTML formatting can be used in Vision components such as buttons, labels, and tables. It can be used in common properties such as the mouse over text property.
To specify that a component's text has HTML formatting, just put the `` element at the beginning of the text, then use any valid HTML element in the remainder.
:::note
Closing the HTML element is optional. In other words, there is no need to place a `` at the end of your stylized text. Also, the HTML elements are not case sensitive.
## Common HTML Elements
HTML Tags are the special characters that instruct text to become stylized differently than other text within the same text. The following table describes the most common HTML elements that you can use within Ignition.
HTML Element | Name | Description
`...` | HTML | Initiates an html formatting. In most cases closing the html with `
