--- title: "Scripting in Vision" --- # Scripting in Vision > A majority of the scripting that happens in Vision is either located on components and windows, or it manipulates component and window values. Many times, you can easily add the path to another component or property from your script. It is important to understand how the component hierarchy of a window works as well as how to properly access components and properties in a script anywhere in a project. ## Component Hierarchy Each window in a project uses a hierarchical structure of containers and components. The hierarchy forms a tree, with one root container at the top and child components arranged below it. Smaller windows have simple trees, while complex projects include multiple layers of nested containers. Since the hierarchy is directional, you can only move up or down within it. To access a sibling component, go up to the shared parent, then down to the target. The example below shows a basic window hierarchy: * Root Container * Edit Table Container * Enter Data Button * Text Field * Alarm Label * Data Table * Header Label ![](scripting-in-vision.png) Flipping the tree around can help explain why we can only move up and down through the hierarchy and how getting to a component can differ depending on where you start. The table below describes three different paths we could take if we wanted to reach the **Text Field** to grab its value. | Start From | Path to Text Field | |------- | -------| |Edit Table Container | Down to **Text Field**| |Enter Data Button | Up to **Edit Table Container**Down to **Text Field**| |Data Table | Up to **Root Container**Down to **Edit Table Container**Down to **Text Field**| To move up or down within the hierarchy, components provide two key ways to navigate: the `.parent` property, which returns the container above, and the `.getComponent()` method, which accesses a child component by name. ```py title="Pseudocode - Component Hierarchy" # This pseudo code shows how to grab the parent of a component component.parent # This pseudo code shows how to grab a child of a component component.getComponent("Text Field") ``` Both `.parent` and `.getComponent()` can be chained as many times as necessary to reach the desired component, drilling up or down through layers of containers or grouped components. Once you have a component reference, you can access its properties directly. :::info Exception: Root Container and Window Access The parent of a Root Container is not the window, and a window reference does not provide `.getComponent(name)`. To get a reference to the window, call [system.vision.getParentWindow](appendix/scripting-functions/system-vision/system-vision-getParentWindow.md) with a component event object. From the window, use its `.rootContainer` property to reach the root of the component hierarchy, and then follow the same rules above. ::: ### Accessing Component Properties To access a property on a component, use the property's scripting name. You can find scripting names in the property description by enabling the Description field or hovering over the property to view the tooltip. Scripting names are also listed in the property tables for each component in the [Appendix](appendix/appendix.md). For example, the scripting name of a Text Field component's Text property is `text`. ```py title="Pseudocode - Component Properties" # This pseudo code will access the text property of a component and assign it to value. value = component.text ``` ## Accessing a Component Now that you understand the hierarchy, you can apply it from anywhere in the project. The movement up and down remains the same, but your starting point varies based on where the script runs. ### From an Event Handler [Event Handlers](component-events/component-events.md) receive an `event` object with properties specific to the event type. All events provide `event.source`, which is the component that fired the event. From there, you can use `.parent` and `.getComponent()` to reach the target component. ```py title="Python - Accessing a Component from an Event Handler" # This would access the text property of a Text Field component. print event.source.parent.getComponent('Text Field').text ``` If you already have a window object, you can use `.getComponentForPath()` to navigate to a component by entering its path as a string, similar to an expression binding. ```py title="Python - Accessing a Component from an Event on a Window" system.vision.getParentWindow(event).getComponentForPath('Root Container.Text Field').text ``` You can also get the Root Container directly using `.getRootContainer()`, which works similarly to the function above. ```py title="Python - Accessing a Component from an Event on a Window" system.vision.getParentWindow(event).getRootContainer().getComponent('Text Field').text ``` ### From an Extension Function [Extension Functions](extension-functions/extension-functions.md) receive a `self` object that references the component the function is defined on. Use `self` as the starting point. ```py title="Python - Accessing a Property of a Component from an Extension Function" # This would access the text property of the component running the extension function script. print self.text # This would access the text property of the component named 'Text Field' if it is in the same container. print self.parent.getComponent('Text Field').text ``` ### From a Client Event Script [Client Event Scripts](client-event-scripts/client-event-scripts.md) do not start with a reference to a particular window or component. Use [system.vision.getWindow()](appendix/scripting-functions/system-vision/system-vision-getWindow.md) to get a window reference, then navigate to the Root Container and target component. This only works if the window is open. ```py title="Python - Accessing a Component from a Client Event Script" # Start the try block in case the window is not open. try: # Grab the window reference and assign it to the variable window. window = system.vision.getWindow("Other Window") # Use the window reference to get the text property off of a text field. print window.getRootContainer().getComponent("Text Field").text # Handle the exception by opening an informative error. except ValueError: system.vision.showError("The window is not open!", "Error") ``` ### From a Project Script [Project Library](platform/scripting/scripting-in-ignition/project-library/project-library.md) scripts can access components in different ways depending on where they are called from and what is passed in. In most cases, when the script module is called from an event handler or extension function, you can pass the `event` or `self` object to the project function. ```py title="Python - Accessing a Component from a Project Script" # This code would go in a project script. We are defining our function that takes an event object # and uses it to find the value of the text property on the text field in the same container. def func(event): print event.source.parent.getComponent('Text Field').text ``` ```py title="Python - Calling a Function from the actionPerformed Button" # On the action performed of a button on our window, we could then use this to call our function. myTestScript.func(event) ``` ![](from-a-project-script.png) However, in cases where you cannot pass the `event` or `self` object, such as when the function is called from a context outside an event handler or extension function, you can use the same approach as Client Event Scripts and obtain the window object instead. ## Accessing Components on Other Windows You can also read properties from components on other open windows using the same method as Client Event Scripts. For example, you are able to read a value from a main window in response to a popup window event. :::note Access Exceptions You can only read a property from another window if that window is open. ::: ## Complex Property Types Some component properties have more complex types. For example, Font properties typically use the `java.awt.Font` type. ![](complex-property-types.png) In most cases these property types are Java AWT types and can be manipulated from scripts by importing the appropriate classes. ```py from java.awt import Font event.source.parent.getComponent('Text Field').font = Font('Dialog', Font.BOLD, 50) ``` See the [AWT javadocs](https://docs.oracle.com/en/java/javase/11/docs/api/java.desktop/java/awt/package-summary.html) for more information.
