--- title: "SECS/GEM Messages" --- # SECS/GEM Messages > The SECS-II standard defines how information is exchanged between equipment and a host using messages. Messages are organized into categories called **streams**, which contain specific messages called **functions**. Each SECS message is identified by a stream and function number, written as **S#F#**. For example, **S1F13** refers to Stream 1, Function 13. ## SECS Message Basics ### Requests and Responses SECS messages are exchanged as requests and responses: * **Request** (primary message): Originates from the host, which in Ignition is the Gateway. Request messages use odd-numbered functions, such as **S1F1**. * **Response** (secondary message): Originates from the equipment in reply to a request. Response messages use even-numbered functions, such as **S1F2**. A request may expect a single response or no response, depending on the message definition. This request-and-response pattern forms the basis of SECS/GEM communication. ## SECS Message Format SECS messages are transmitted using binary SECS protocols. Within Ignition, messages are represented as structured JSON objects for scripting and configuration purposes. Each message includes a header that specifies the stream, function, and whether a response is expected. Messages may also include a body containing one or more data items, which can be nested lists. ### SECS Message Example The following example shows an **S1F11** request represented as JSON within Ignition: ```json title="S1F11 Request Message" { "header":{ "doc":"Status Variable Namelist Request", "stream":1, "function":11, "reply":true }, "body":[ { "doc":"SVID, Status Variable ID", "format":"U4", "value":4 } ] } ``` To send this request from a script, use the [sendRequest](appendix/scripting-functions/system-secsgem/system-secsgem-sendRequest.md) function. This function returns a transaction ID, which is used to retrieve the corresponding response. ```python title="Python - Send an S1F11 request to the Equipment" body = [{"format": "U4", "value": 4}] transactionID = system.secsgem.sendRequest("S1F11", True, body, "Equip4") ``` A response to the above request would look similar to the following: ```json title="S1F12 Response Message" { "header": { "doc": "Status Variable Namelist Reply", "stream": 1, "function": 12, "reply": false }, "body": [ [ { "doc": "SVID, Status Variable ID", "format": "U4", "value": 4 }, { "doc": "SVNAME, Status Variable Name", "format": "A", "value": "RandomBinaryData" }, { "doc": "UNITS, Units Identifier", "format": "A", "value": "B" } ] ] } ``` Responses are retrieved using the [getResponse](appendix/scripting-functions/system-secsgem/system-secsgem-getResponse.md) function. ```python title="Python - Get an S1F12 response from the Equipment" response = system.secsgem.getResponse(transactionID, "Equip4") print response ``` This request-and-response pattern forms the foundation of SECS/GEM communication. In addition to retrieving responses through scripting, messages can also be processed using tags or Message Handlers. :::note To send or receive a specific SECS message, the corresponding stream and function must be defined in the equipment connection’s SDL file. ::: ## SECS Messages through Tags SECS messages that contain data can be configured to generate tags. This is commonly used for recurring data, such as trace data returned in **S6F1** messages. When enabled, tags are created automatically under the SECS/GEM Realtime Tag Provider for the equipment connection. These tags are read-only and do not support Tag History, alarming, or manual editing. :::note Realtime tags are not persistent. If the Gateway restarts, the tags must be recreated. ::: To enable tag creation for a message, the message definition in the SDL file must be configured accordingly. The default SDL file is preconfigured to generate tags for **S6F1** messages. ```json title="Simulator S2F23 Body" [ { "doc":"TRID, Trace Request ID.", "format":"U4", "value":1 }, { "doc":"DSPER, Data sample period.", "format":"A", "value":"000002" }, { "doc":"TOTSMP, Total Samples", "format":"U4", "value":10 }, { "doc":"REPGSZ, Reporting Group Size", "format":"U4", "value":1 }, [ { "doc":"SVID Status Variable ID", "value":1, "format":"U4" }, { "doc":"SVID Status Variable ID", "value":2, "format":"U4" }, { "doc":"SVID Status Variable ID", "value":3, "format":"U4" } ] ] ``` ### Tags Example Using the Simulator This example configures the **S2F14** message to create tags that can be viewed in the Tag Provider. It assumes the equipment connection is connected to a simulator and is using the default SDL file. To capture other messages as tags, the SDL file must be configured to allow tag creation. In this example, the SDL file is updated so that **S2F14** generates tags. 1. On the Gateway, go to the **Connections** section and navigate to **SECS/GEM** > **Equipment**. 2. Expand the **three dots menu** for the equipment connection and select **Edit File** under **SDL File**. 3. Locate the **S2F14** message in the list. 1. Add **SQLTags** as an Auto type object with a value of **true** directly under the S2F14 root. 2. Create an array called **CommonID** directly under the S2F14 root. 1. Add **0: ECV** to the **CommonID** array as an Auto type object. 4. Save the SDL file and restart the equipment connection. 5. After the equipment connection is reestablished, send an **S2F13** message with the body shown below: ```json title="S2F13 Body" [ { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":200 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":201 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":203 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":205 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":206 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":207 } ] ``` ## SECS Messages through Message Handlers Instead of generating tags, SECS messages can invoke a custom Python script using a Message Handler. The Message Handler must have the onSecsGemRealtimeUpdate name, though it can be specified for both the Client Event Scripts and the Gateway Event Scripts. Within the Message Handler, the SECS message will pass information into the payload object. :::note Message Handler Limitations Message Handlers can only process messages that are allowed to originate from equipment, such as **S6F1**. Messages that originate only from the host cannot trigger Message Handlers. ::: | Payload Key | Description | | ------------ | ------------ | | CommonID | The identifier used to associate related messages. | | Equipment | The name of the equipment connection. | | Direction | Indicates whether the message was sent or received. | | RequestResponse | Indicates whether the message is a request or response. | | TxID | The transaction identifier. | | Reply | Indicates whether the message expects a reply. | | Message | The message contents represented as JSON. | This script can handle the message in any way such as storing data in the database or writing to tags. The example below will take the information and create a logger object with it that will then be printed to the console. ```python title="Python - Example of a onSecsGemRealtimeUpdate Message Handler" # This message handler is very simple in that it will create a logger with the SECS message data that prints to the console. commonID = payload['CommonID'] equipment= payload['Equipment'] direction = payload['Direction'] reqResp = payload['RequestResponse'] txId = payload['TxID'] reply = payload['Reply'] message = payload['Message'] msg = "CommonID=" + commonID msg += ", Equipment=" + equipment msg += ", Direction=" + direction msg += ", RequestResponse=" + reqResp msg += ", TxID=" + str(txId) msg += ", Reply=" + str(reply) msg += ", Message=" + message logger = system.util.getLogger("SECSGEM.Gateway.onSecsGemRealtimeUpdate") logger.info(msg) ``` Once an onSecsGemRealtimeUpdate Message Handler has been specified, it needs to be specified within the Gateway. On the Gateway, navigate to **Connections** > **SECS/GEM** > **Settings** to access the SECS/GEM Settings page and specify which project holds the Gateway Message Handler and which project holds the Client Message Handler. These can be the same project or different projects. ![" "](secs-gem-messages/1-image2018-5-1_16-21-11.png) ### Message Handler Example Using the Simulator This example configures the **S2F14** message to call a Gateway Message Handler. It assumes the equipment connection is connected to a simulator and is using the default SDL file. To capture messages using **onSecsGemRealtimeUpdate**, the SDL file must be configured to allow the message to be routed through the Message Handler. In this example, the SDL file is updated so that **S2F14** is processed by the Message Handler. 1. Create a Gateway Message Handler called **onSecsGemRealtimeUpdate**. 2. On the Gateway, go to the **Connections** section and navigate to **SECS/GEM** > **Settings**. 3. Specify the project that contains the Gateway Message Handler in the **Gateway Message Handler Project** setting. 4. Navigate to **SECS/GEM** > **Equipment**. 5. Expand the **three dots menu** for the equipment connection and select **Edit File**. 6. Locate the **S2F14** message in the list. 1. Add **realtime** as an Auto type object with a value of **true** directly under the S2F14 root. 2. Create an array called **CommonID** directly under the S2F14 root. 1. Add **0: ECV** to the **CommonID** array as an Auto type object. 5. Save the SDL file and restart the equipment connection. 6. After the equipment connection is reestablished, send an **S2F13** message with the body shown below: ```json title="S2F13 Body" [ { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":200 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":201 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":203 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":205 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":206 }, { "doc":"ECID, Equipment Constant ID", "format":"U4", "value":207 } ] ``` ## Custom SECS Message Response Handlers For messages that expect a response, SECS/GEM automatically sends a response based on the SDL configuration. You can override this behavior by creating a custom Message Response Handler, which allows responses to be generated entirely through Python scripting. Using the data given to us in the payload, the Message Handler can then manipulate it in any way before calling the [system.secsgem.sendResponse](appendix\scripting-functions\system-secsgem\system-secsgem-sendResponse.md) function, which will send the response back to the equipment. :::note Only one custom response can be configured per stream and function for an equipment connection. Custom response handlers are supported for messages received over the SECS-I (serial) protocol. ::: | Payload Key | Description | | ----------- | ----------- | | Equipment | The name of the equipment connection. | | TxID | The transaction identifier. | | SystemBytes | The system bytes associated with the response. | | Message | The message contents represented as JSON. | To configure a custom response handler, open **Connections** > **SECS/GEM** > **Equipment**, expand the **three dots menu** for the equipment connection, and select **Custom Responses**. Each entry maps a stream and function to a Gateway Message Handler. On the Message Response Handlers page, we can setup a link between the stream function response we want to intercept and which Message Handler will be used to handle it. Each Message Response Handler has the following settings. | Setting | Description | | ------- | ----------- | | Enabled | If true, the specified script message handler will be fired when the specified StreamFunction is encountered. | | Intercept Stream Function | The SECS stream and function type of the message that will be intercepted. Use a value such as "S6F2" | | Gateway Message Handler | The name of the script message handler that will create the SECS response message. This message handler must be created in a project to provide custom responses, and must be a Gateway Event Script message handler. | | Project Name | The project that contains the script message handler specified above. |
